[Liblas-commits] laszip: Use explicit std:: prefix for streams, move laszippertes...
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Dec 14 11:12:49 EST 2010
changeset ab8bf5e582b0 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=ab8bf5e582b0
summary: Use explicit std:: prefix for streams, move laszippertest into the tools directory, turn off lasdiff and laszip for now, as these depend on LAStools.
diffstat:
 include/laszip/laszipper.hpp  |   74 +++++-----
 src/CMakeLists.txt            |    6 +-
 src/bytestreamin_istream.hpp  |    9 +-
 src/bytestreamout_ostream.hpp |   84 ++++++-----
 src/laszipper.cpp             |   80 +++++-----
 src/laszippertest.cpp         |  279 -----------------------------------------
 tools/CMakeLists.txt          |   13 +-
 tools/laszippertest.cpp       |  284 ++++++++++++++++++++++++++++++++++++++++++
 8 files changed, 430 insertions(+), 399 deletions(-)
diffs (truncated from 988 to 300 lines):
diff -r b33531f25c48 -r ab8bf5e582b0 include/laszip/laszipper.hpp
--- a/include/laszip/laszipper.hpp	Tue Dec 14 09:46:42 2010 -0600
+++ b/include/laszip/laszipper.hpp	Tue Dec 14 10:12:41 2010 -0600
@@ -1,21 +1,21 @@
- * Project:  integrating laszip into liblas - http://liblas.org -
- * Purpose:
- * Author:   Martin Isenburg
- *           isenburg at cs.unc.edu
- * Copyright (c) 2010, Martin Isenburg
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
+ * Project:  integrating laszip into liblas - http://liblas.org -
+ * Purpose:
+ * Author:   Martin Isenburg
+ *           isenburg at cs.unc.edu
+ * Copyright (c) 2010, Martin Isenburg
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
@@ -39,38 +39,44 @@
   CHANGE HISTORY:
-    12 December 2010 -- created from LASwriter/LASreader after Howard got pushy (-;
+    12 December 2010 -- created from LASwriter/LASreader after Howard got pushy (-;
 #ifndef LAS_ZIPPER_H
 #define LAS_ZIPPER_H
-#include <stdio.h>
-#include <ostream.h>
-#include "laszip.hpp"
+#include <stdio.h>
-class ByteStreamOut;
-class LASwritePoint;
+#ifdef _MSC_VER
+#include <ostream.h>
+#else
+#include <fstream>
+#endif
+#include "laszip.hpp"
+class ByteStreamOut;
+class LASwritePoint;
 class LASzipper
 public:
-  bool open(FILE* outfile, unsigned int num_items, LASitem* items, unsigned int compression=0);
-  bool open(ostream* outstream, unsigned int num_items, LASitem* items, unsigned int compression=0);
-  bool write(unsigned char** point);
-  bool chunk(LASchunk* chunk);
-  bool close(LASchunk* chunk=0);
+  bool open(FILE* outfile, unsigned int num_items, LASitem* items, unsigned int compression=0);
+  bool open(std::ostream* outstream, unsigned int num_items, LASitem* items, unsigned int compression=0);
+  bool write(unsigned char** point);
+  bool chunk(LASchunk* chunk);
+  bool close(LASchunk* chunk=0);
   LASzipper();
   ~LASzipper();
-private:
+private:
   int count;
-  ByteStreamOut* stream;
-  LASwritePoint* writer;
+  ByteStreamOut* stream;
+  LASwritePoint* writer;
 #endif
diff -r b33531f25c48 -r ab8bf5e582b0 src/CMakeLists.txt
--- a/src/CMakeLists.txt	Tue Dec 14 09:46:42 2010 -0600
+++ b/src/CMakeLists.txt	Tue Dec 14 10:12:41 2010 -0600
@@ -37,14 +37,14 @@
 set(LASZIP_CPP
     arithmeticdecoder.cpp
     arithmeticencoder.cpp
-	integercompressor.cpp
+    arithmeticmodel.cpp
+    integercompressor.cpp
     lasreaditemcompressed_v1.cpp
     lasreadpoint.cpp
     lasunzipper.cpp
     laswriteitemcompressed_v1.cpp
     laswritepoint.cpp
-	laszipper.cpp
-	laszippertest.cpp
+    laszipper.cpp
 set(LASZIP_SOURCES
diff -r b33531f25c48 -r ab8bf5e582b0 src/bytestreamin_istream.hpp
--- a/src/bytestreamin_istream.hpp	Tue Dec 14 09:46:42 2010 -0600
+++ b/src/bytestreamin_istream.hpp	Tue Dec 14 10:12:41 2010 -0600
@@ -46,7 +46,11 @@
 #include "bytestreamin.hpp"
+#ifdef _MSC_VER
+#include <istream.h>
+#else
 #include <fstream>
+#endif
 class ByteStreamInIstream : public ByteStreamIn
@@ -81,7 +85,10 @@
     // http://stackoverflow.com/questions/604431/c-reading-unsigned-char-from-file-stream
     // std::ifstream only provides a specialization for char, not unsigned char.
-  stream->read(bytes, num_bytes);
+    // WARNING, unsafe cast!!! -- hobu
+  stream->read( (char*)bytes, num_bytes);
   return !!(stream->good());
diff -r b33531f25c48 -r ab8bf5e582b0 src/bytestreamout_ostream.hpp
--- a/src/bytestreamout_ostream.hpp	Tue Dec 14 09:46:42 2010 -0600
+++ b/src/bytestreamout_ostream.hpp	Tue Dec 14 10:12:41 2010 -0600
@@ -16,44 +16,48 @@
-  FILE:  bytestreamout_ostream.hpp
-  CONTENTS:
-  PROGRAMMERS:
-    martin isenburg at cs.unc.edu
-  COPYRIGHT:
-    copyright (C) 2010  martin isenburg at cs.unc.edu
-    This software is distributed in the hope that it will be useful,
-    but WITHOUT ANY WARRANTY; without even the implied warranty of
-    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
-  CHANGE HISTORY:
+  FILE:  bytestreamout_ostream.hpp
+  CONTENTS:
+  PROGRAMMERS:
+    martin isenburg at cs.unc.edu
+  COPYRIGHT:
+    copyright (C) 2010  martin isenburg at cs.unc.edu
+    This software is distributed in the hope that it will be useful,
+    but WITHOUT ANY WARRANTY; without even the implied warranty of
+    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
+  CHANGE HISTORY:
     12 December 2010 -- created from ByteStreamOutOstream after Howard got pushy (-;
-#ifndef BYTE_STREAM_OUT_OSTREAM_H
-#define BYTE_STREAM_OUT_OSTREAM_H
+#ifndef BYTE_STREAM_OUT_OSTREAM_H
+#define BYTE_STREAM_OUT_OSTREAM_H
 #include "bytestreamout.hpp"
+#ifdef _MSC_VER
-class ByteStreamOutOstream : public ByteStreamOut
+#else
+#include <fstream>
+#endif
+class ByteStreamOutOstream : public ByteStreamOut
 public:
-  ByteStreamOutOstream(ostream* stream);
+  ByteStreamOutOstream(std::ostream* stream);
 /* write a single byte                                       */
-  bool putByte(unsigned char byte);
+  bool putByte(unsigned char byte);
 /* write an array of bytes                                   */
   bool putBytes(unsigned char* bytes, unsigned int num_bytes);
 /* returns how many bytes were written                       */
@@ -63,11 +67,11 @@
 /* destructor                                                */
   ~ByteStreamOutOstream(){};
 private:
-  ostream* stream;
-  long start;
+  std::ostream* stream;
+  std::ios::pos_type start;
-ByteStreamOutOstream::ByteStreamOutOstream(ostream* stream)
+ByteStreamOutOstream::ByteStreamOutOstream(std::ostream* stream)
   this->stream = stream;
   resetCount();
@@ -81,18 +85,20 @@
 bool ByteStreamOutOstream::putBytes(unsigned char* bytes, unsigned int num_bytes)
-  stream->write(bytes, num_bytes);
+  stream->write((char*)bytes, num_bytes);
 unsigned int ByteStreamOutOstream::byteCount() const
-  return (stream->tellp() - start);
+  std::ios::pos_type end = stream->tellp();
+  std::ios::off_type size = end - start;
+  return static_cast<unsigned int>(size);
 void ByteStreamOutOstream::resetCount()
   start = stream->tellp();
-#endif
+#endif
diff -r b33531f25c48 -r ab8bf5e582b0 src/laszipper.cpp
--- a/src/laszipper.cpp	Tue Dec 14 09:46:42 2010 -0600
+++ b/src/laszipper.cpp	Tue Dec 14 10:12:41 2010 -0600
@@ -16,33 +16,33 @@
-  FILE:  laszipper.cpp
-  CONTENTS:
-    see corresponding header file
-  PROGRAMMERS:
-  COPYRIGHT:
More information about the Liblas-commits mailing list
