[Liblas-commits] hg: 10 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Dec 14 11:21:41 EST 2010
changeset f7651149ee11 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=f7651149ee11
summary: try to avoid including geotiff/gdal include files from public liblas include files
changeset 3505a0cdc72c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=3505a0cdc72c
summary: small fix for LASSRS_SetGTIF return type
changeset ce32a527954f in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=ce32a527954f
summary: preliminary pass on rfc2
changeset aeb3e5714db7 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=aeb3e5714db7
summary: preliminary implementation of RFC 2
changeset 9b91c2f30e9b in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=9b91c2f30e9b
summary: upstream merge
changeset 723b5d005a6d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=723b5d005a6d
summary: proposed update to show how to run tests more directly
changeset 9ef8cffc9fb0 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=9ef8cffc9fb0
summary: updated to reflect WKT VLR and changes in WKT due to not going through geotiff
changeset 198697ed10ec in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=198697ed10ec
summary: update with various details
changeset 868e8b544b25 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=868e8b544b25
summary: final pass on srs overhaul - rfc2
changeset 71d43b1f074b in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=71d43b1f074b
summary: merge
diffstat:
 CMakeLists.txt                                 |   38 +-
 apps/CMakeLists.txt                            |   40 +-
 apps/las2las.cpp                               |    3 +-
 apps/las2txt.cpp                               |  623 +++++++++++++++++++++++++
 apps/laskernel.cpp                             |   31 +-
 apps/laskernel.hpp                             |    3 +-
 apps/oci_util.cpp                              |   48 +-
 apps/oci_util.hpp                              |    2 +-
 cmake/modules/BuildOSGeo4W.cmake               |    1 +
 doc/compilation.txt                            |   15 +-
 doc/development/buildbot.txt                   |   55 ++-
 doc/development/rfc/index.txt                  |    1 +
 doc/development/rfc/rfc_2_spatialreference.txt |  174 ++++++
 doc/tutorial/cpp.txt                           |   30 +-
 hobu-config.bat                                |    7 +-
 include/liblas/capi/las_version.h              |    6 +-
 include/liblas/capi/liblas.h                   |   13 +-
 include/liblas/detail/fwd.hpp                  |    1 +
 include/liblas/detail/reader/cachedreader.hpp  |   22 +-
 include/liblas/detail/reader/header.hpp        |    1 -
 include/liblas/detail/reader/point.hpp         |    3 +-
 include/liblas/detail/reader/reader.hpp        |   29 +-
 include/liblas/detail/writer/base.hpp          |   10 +-
 include/liblas/detail/writer/writer.hpp        |    2 -
 include/liblas/lasreader.hpp                   |   50 +-
 include/liblas/lasspatialreference.hpp         |   65 +-
 include/liblas/lastransform.hpp                |    1 +
 include/liblas/lasversion.hpp                  |   58 +--
 include/liblas/laswriter.hpp                   |   15 +-
 include/liblas/liblas.hpp                      |   20 +-
 include/liblas/utility.hpp                     |    2 +-
 python/setup.py                                |    4 +-
 schemas/LAS.xsd                                |    2 +-
 schemas/las.xml                                |  247 +---------
 src/CMakeLists.txt                             |    3 +-
 src/detail/reader/cachedreader.cpp             |  116 +++-
 src/detail/reader/header.cpp                   |    2 +-
 src/detail/reader/point.cpp                    |   18 +-
 src/detail/reader/reader.cpp                   |  156 ++++-
 src/detail/writer/base.cpp                     |    4 +-
 src/detail/writer/header.cpp                   |  121 ++--
 src/detail/writer/point.cpp                    |   22 +-
 src/detail/writer/writer.cpp                   |    6 -
 src/las_c_api.cpp                              |   87 ++-
 src/lasfilter.cpp                              |   19 +-
 src/lasindex.cpp                               |   38 +-
 src/lasreader.cpp                              |  274 +---------
 src/lasspatialreference.cpp                    |  174 ++++++-
 src/lasversion.cpp                             |  113 ++++
 src/laswriter.cpp                              |   70 +--
 test/unit/lasheader_test.cpp                   |    2 +
 test/unit/lasreader_test.cpp                   |   27 +-
 test/unit/lasspatialreference_test.cpp         |  149 +++++-
 test/unit/laswriter_test.cpp                   |   36 +-
 54 files changed, 1968 insertions(+), 1091 deletions(-)
diffs (truncated from 4722 to 300 lines):
diff -r 4bf2a228da87 -r 71d43b1f074b CMakeLists.txt
--- a/CMakeLists.txt	Fri Nov 19 12:46:35 2010 -0800
+++ b/CMakeLists.txt	Tue Dec 14 11:17:23 2010 -0500
@@ -150,8 +150,17 @@
 # Boost C++ Libraries support - required
 message(STATUS "Searching for Boost 1.38+ - done")
-set(Boost_USE_STATIC_LIBS   ON)
-set(Boost_USE_MULTITHREADED ON)
+# Default to using static, multithreaded libraries for
+# linking under MSVC.  This is because we show users how to
+# use boostpro.com installer and install those options when linking
+# on windows in the compilation documentation.
+if(WIN32)
+  if (MSVC)
+    set(Boost_USE_STATIC_LIBS   ON)
+    set(Boost_USE_MULTITHREADED ON)
+  endif(MSVC)
+endif(WIN32)
 # NOTE: Add iostreams to COMPONENTS list to enable bigfile_boost_iostreams_test
 find_package(Boost 1.38 COMPONENTS program_options REQUIRED)
@@ -164,6 +173,23 @@
 mark_as_advanced(CLEAR Boost_LIBRARY_DIRS)
 link_directories(${Boost_LIBRARY_DIRS})
+# libxml2 support - optional, default=ON
+set(WITH_LIBXML2 FALSE CACHE BOOL "Choose if libxml2 support should be built ")
+if(WITH_LIBXML2)
+    find_package(LibXml2)
+    mark_as_advanced(CLEAR LIBXML2_INCLUDE_DIR)
+    mark_as_advanced(CLEAR LIBXML2_LIBRARIES)
+    if(LIBXML2_FOUND)
+        include_directories(${LIBXML2_INCLUDE_DIR})
+        add_definitions(-DHAVE_LIBXML2=1)
+    endif()
+endif()
 # GeoTIFF support - optional, default=OFF
 set(WITH_GEOTIFF FALSE CACHE BOOL "Choose if GeoTIFF support should be built")
@@ -332,7 +358,7 @@
 # Version information
 SET(CPACK_PACKAGE_VERSION_MAJOR "1")
 SET(CPACK_PACKAGE_VERSION_MINOR "6")
-SET(CPACK_PACKAGE_VERSION_PATCH "0b2")
+SET(CPACK_PACKAGE_VERSION_PATCH "0b3")
 SET(OSGEO4W_UPSTREAM_RELEASE "1")
 SET(CPACK_SOURCE_GENERATOR "TGZ;ZIP;TBZ2")
@@ -364,6 +390,6 @@
 add_custom_target(dist COMMAND ${CMAKE_MAKE_PROGRAM} package_source)
-#if (WIN32)
-#    include(BuildOSGeo4W)
-#endif(WIN32)
+if (WIN32)
+    include(BuildOSGeo4W)
+endif(WIN32)
diff -r 4bf2a228da87 -r 71d43b1f074b apps/CMakeLists.txt
--- a/apps/CMakeLists.txt	Fri Nov 19 12:46:35 2010 -0800
+++ b/apps/CMakeLists.txt	Tue Dec 14 11:17:23 2010 -0500
@@ -19,6 +19,7 @@
 set(LASMERGE lasmerge)
 set(LAS2LAS las2las)
 set(LAS2LAS_OLD las2las-old)
+set(LAS2TXT_OLD las2txt-old)
 set(LAS2TXT las2txt)
 set(TXT2LAS txt2las)
 set(TS2LAS ts2las)
@@ -47,8 +48,8 @@
 endif()
 set(LIBLAS_UTILITIES
-    ${LASINFO_OLD} ${LASINFO} ${LASMERGE} ${LAS2LAS} ${LAS2TXT} ${TXT2LAS}
-    ${LAS2OGR}  ${LAS2OCI} ${LAS2LAS} ${LAS2LAS_OLD} ${LASBLOCK} ${TS2LAS})
+    ${LASINFO_OLD} ${LASINFO} ${LASMERGE} ${LAS2LAS} ${LAS2TXT_OLD} ${TXT2LAS}
+    ${LAS2OGR}  ${LAS2OCI} ${LAS2LAS} ${LAS2LAS_OLD} ${LASBLOCK} ${TS2LAS}  ${LAS2TXT} )
 # TODO: Experimental and requires testing --mloskot
 # Generate user-specific settings for Visual Studio project
@@ -82,15 +83,8 @@
-set (LASKERNEL_SOURCES laskernel.cpp)
-add_library(${LASKERNEL_LIB_NAME} SHARED ${LASKERNEL_SOURCES})
-target_link_libraries(${LASKERNEL_LIB_NAME}
-                      ${LIBLAS_LIB_NAME})
-install(TARGETS ${LASKERNEL_LIB_NAME}
-  RUNTIME DESTINATION ${LIBLAS_BIN_DIR}
-  LIBRARY DESTINATION ${LIBLAS_LIB_DIR}
-  ARCHIVE DESTINATION ${LIBLAS_LIB_DIR})
+#    add_executable(lasschematest lasschematest.cpp laskernel.cpp)
+#    target_link_libraries(lasschematest ${APPS_CPP_DEPENDENCIES} ${LIBXML2_LIBRARIES})
 # Build lasinfo
 if(LASINFO_OLD)
@@ -106,21 +100,27 @@
     target_link_libraries(${LAS2LAS_OLD} ${LIBLAS_C_LIB_NAME})
 endif()
 if(LAS2LAS)
-    add_executable(${LAS2LAS} las2las.cpp )
-    target_link_libraries(${LAS2LAS} ${APPS_CPP_DEPENDENCIES} ${LASKERNEL_LIB_NAME})
+    add_executable(${LAS2LAS} las2las.cpp laskernel.cpp)
+    target_link_libraries(${LAS2LAS} ${APPS_CPP_DEPENDENCIES} )
 endif()
 if(LASINFO)
-    add_executable(${LASINFO} lasinfo.cpp )
-    target_link_libraries(${LASINFO} ${APPS_CPP_DEPENDENCIES} ${LASKERNEL_LIB_NAME} )
+    add_executable(${LASINFO} lasinfo.cpp laskernel.cpp )
+    target_link_libraries(${LASINFO} ${APPS_CPP_DEPENDENCIES}  )
 endif()
 # Build las2txt
+if(LAS2TXT_OLD)
+    set(LAS2TXT_OLD_SRC lascommon.c ${LAS2TXT}.c)
+    add_executable(${LAS2TXT_OLD} ${LAS2TXT_OLD_SRC})
+    target_link_libraries(${LAS2TXT_OLD} ${LIBLAS_C_LIB_NAME})
+endif()
 if(LAS2TXT)
-    set(LAS2TXT_SRC lascommon.c ${LAS2TXT}.c)
-    add_executable(${LAS2TXT} ${LAS2TXT_SRC})
-    target_link_libraries(${LAS2TXT} ${LIBLAS_C_LIB_NAME})
+    add_executable( ${LAS2TXT}  las2txt.cpp laskernel.cpp )
+    target_link_libraries(${LAS2TXT} ${APPS_CPP_DEPENDENCIES}  )
 endif()
 # Build txt2las
@@ -157,8 +157,8 @@
 # Build las2oci
 if(LAS2OCI)
-    add_executable(${LAS2OCI} las2oci.cpp oci_wrapper.cpp kdx_util.cpp oci_util.cpp )
-    target_link_libraries(${LAS2OCI} ${APPS_CPP_DEPENDENCIES} ${ORACLE_LIBRARY} ${LASKERNEL_LIB_NAME})
+    add_executable(${LAS2OCI} las2oci.cpp oci_wrapper.cpp kdx_util.cpp oci_util.cpp laskernel.cpp )
+    target_link_libraries(${LAS2OCI} ${APPS_CPP_DEPENDENCIES} ${ORACLE_LIBRARY} )
 endif()
 if(BIGFILE_TEST)
diff -r 4bf2a228da87 -r 71d43b1f074b apps/las2las.cpp
--- a/apps/las2las.cpp	Fri Nov 19 12:46:35 2010 -0800
+++ b/apps/las2las.cpp	Tue Dec 14 11:17:23 2010 -0500
@@ -68,7 +68,8 @@
     if (min_offset)
-        liblas::property_tree::ptree tree = reader.Summarize();
+        liblas::property_tree::ptree tree = SummarizeReader(reader);
         try
             header.SetOffset(tree.get<double>("summary.points.minimum.x"),
diff -r 4bf2a228da87 -r 71d43b1f074b apps/las2txt.cpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/apps/las2txt.cpp	Tue Dec 14 11:17:23 2010 -0500
@@ -0,0 +1,623 @@
+ * Project: libLAS -- C/C++ read/write library for LAS LIDAR data
+ * Purpose: LAS translation to ASCII text with optional configuration
+ * Author:  Martin Isenburg isenburg at cs.unc.edu
+ * Author:  Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2010, Howard Butler, hobu.inc at gmail.com
+ * See LICENSE.txt in this source distribution for more information.
+#include <liblas/liblas.hpp>
+#include "laskernel.hpp"
+#include <liblas/utility.hpp>
+#include <boost/cstdint.hpp>
+#include <boost/foreach.hpp>
+#include <boost/array.hpp>
+#include <boost/lexical_cast.hpp>
+#include <string>
+using namespace liblas;
+using namespace std;
+#ifdef _WIN32
+#define compare_no_case(a,b,n)  _strnicmp( (a), (b), (n) )
+#else
+#define compare_no_case(a,b,n)  strncasecmp( (a), (b), (n) )
+#endif
+std::string GetLabels(std::string const& parse_string,
+                    std::string const& delimiter)
+    std::ostringstream output;
+    boost::uint32_t i = 0;
+    for (;;)
+        switch (parse_string[i])
+        /* // the x coordinate */
+        case 'x':
+            output << "\"X\"";
+            break;
+        /* // the y coordinate */
+        case 'y':
+            output << "\"Y\"";
+            break;
+        /* // the z coordinate */
+        case 'z':
+            output << "\"Z\"";
+            break;
+        /* // the raw x coordinate */
+        case 'X':
+            output << "\"Raw X\"";
+            break;
+        /* // the raw y coordinate */
+        case 'Y':
+            output << "\"Raw Y\"";
+            break;
+        /* // the raw z coordinate */
+        case 'Z':
+            output << "\"Raw Z\"";
+            break;
+        /* // the gps-time */
+        case 't':
+            output << "\"Time\"";
+            break;
+        /* // the intensity */
+        case 'i':
+            output << "\"Intensity\"";
+            break;
+        /* the scan angle */
+        case 'a':
+            output << "\"Scan Angle\"";
+            break;
+        /* the number of the return */
+        case 'r':
+            output << "\"Return Number\"";
+            break;
+        /* the classification */
+        case 'c':
+            output << "\"Classification\"";
+            break;
+        /* the classification name */
+        case 'C':
+            output << "\"Classification Name\"";
+            break;
+        /* the user data */
+        case 'u':
+            output << "\"User Data\"";
+            break;
+        /* the number of returns of given pulse */
+        case 'n':
+            output << "\"Number of Returns\"";
+            break;
+        /* the red channel color */
+        case 'R':
+            output << "\"Red\"";
+            break;
+        /* the green channel color */
+        case 'G':
+            output << "\"Green\"";
+            break;
+        /* the blue channel color */
+        case 'B':
+            output << "\"Blue\"";
+            break;
+        case 'M':
+            output << "\"ID\"";
+            break;
+        case 'p':
+            output << "\"Point Source ID\"";
+            break;
+        /* the edge of flight line flag */
+        case 'e':
+            output << "\"Flight Line Edge\"";
+            break;
+        /* the direction of scan flag */
+        case 'd':
+            output << "\"Scan Direction\"";
+            break;
+        i++;
+        if (parse_string[i])
More information about the Liblas-commits mailing list
