[Liblas-commits] hg: added RFCs to development docs,
with rfc1 present
liblas-commits at liblas.org
Sat Sep 4 00:29:26 EDT 2010
changeset 07d71b9aed4d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=07d71b9aed4d
summary: added RFCs to development docs, with rfc1 present
diffstat:
doc/development/index.txt | 1 +
doc/development/rfc/index.txt | 20 +
doc/development/rfc/rfc_1_verticalcs.txt | 321 +++++++++++++++++++++++++++++++
3 files changed, 342 insertions(+), 0 deletions(-)
diffs (truncated from 360 to 300 lines):
diff -r d3c46c92ab81 -r 07d71b9aed4d doc/development/index.txt
--- a/doc/development/index.txt Thu Sep 02 20:41:15 2010 -0500
+++ b/doc/development/index.txt Sat Sep 04 00:28:43 2010 -0400
@@ -17,6 +17,7 @@
format_elements
Motivation <http://www.youtube.com/watch?v=u6XAPnuFjJc>
Release Plan <release_plan>
+ RFCs <rfc/index>
Authors
diff -r d3c46c92ab81 -r 07d71b9aed4d doc/development/rfc/index.txt
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/doc/development/rfc/index.txt Sat Sep 04 00:28:43 2010 -0400
@@ -0,0 +1,20 @@
+.. _rfcs:
+RFCs
+RFCs (Request For Comments) are documents describing a new feature or
+procedure related to the project. They are used as a focus for discussion
+of complex changes, and once agreed upon serve as a specification.
+.. toctree::
+ :maxdepth: 1
+ rfc_1_verticalcs
diff -r d3c46c92ab81 -r 07d71b9aed4d doc/development/rfc/rfc_1_verticalcs.txt
+++ b/doc/development/rfc/rfc_1_verticalcs.txt Sat Sep 04 00:28:43 2010 -0400
@@ -0,0 +1,321 @@
+ libLAS RFC 1: Vertical Coordinate Systems
+:Author: Frank Warmerdam
+:Contact: warmerdam at pobox.com
+:Date: 1/6/10
+:Status: Proposed
+:Version: libLAS 1.3
+.. contents::
+ :depth: 2
+.. sectnum::
+This page holds resources to handling of vertical coordinate systems (datums
+and units) in LAS files. Traditionally LAS files have not been rigorous with
+regard to recording the vertical datum and vertical units. In actual use I
+(Frank Warmerdam) have been unable to find any existing LAS files (January
+2010) with vertical datum information set, though some do set vertical units
+information.
+With the support of !LizardTech, I have been asked to extend libLAS to support
+reading and writing vertical coordinate system information in LAS files, and
+to the extent practical to establish some reference information on "best
+practices" with regard to describing vertical coordinate systems in LAS files.
+Vertical CS in GeoTIFF
+The planned approach is to store vertical coordinate system in GeoTIFF tags.
+The GeoTIFF specification has always had vertical coordinate system support,
+tied to the EPSG codes for vertical coordinate systems and datums. However,
+traditionally, the vertical coordinate system support in GeoTIFF has also not
+been widely used. So it is hoped that formalization of GeoTIFF tags for
+vertical datums in LAS format would also apply for GeoTIFF in general and any
+other geotiff oriented formats (GeoJP2 for instance). It is anticipated that
+the GeoTIFF representation of a LAS file with a vertical datum set might look
+something like this:
+ Geotiff_Information:
+ Version: 1
+ Key_Revision: 1.0
+ Tagged_Information:
+ End_Of_Tags.
+ Keyed_Information:
+ GTModelTypeGeoKey (Short,1): ModelTypeProjected
+ GTRasterTypeGeoKey (Short,1): RasterPixelIsPoint
+ ProjectedCSTypeGeoKey (Short,1): PCS_WGS84_UTM_zone_15N
+ ProjLinearUnitsGeoKey (Short,1): Linear_Meter
+ VerticalCSTypeGeoKey (Short,1): Unknown-5701
+ VerticalCitationGeoKey (Ascii,7): "Newlyn"
+ VerticalDatumGeoKey (Short,1): Unknown-5101
+ VerticalUnitsGeoKey (Short,1): Linear_Meter
+ End_Of_Keys.
+ End_Of_Geotiff.
+Note that VerticalCSTypeGeoKey 5701 is "ODN height", a vertical coordinate
+system from the EPSG coordinate reference system table. The vertical
+coordinate system 5701 is based on vertical datum 5101 (Ordnance Datum Newlyn)
+from the EPSG datum table. The 5701 vertical coordinate system also specifies
+use of meters as the vertical linear measure.
+So there are four GeoTIFF tags related to vertical coordinate system information:
+ * VerticalCSTypeGeoKey: an EPSG coordinate system code of type vertical
+ (normally 5600-5799).
+ * VerticalCitationGeoKey: a description of the vertical coordinate system,
+ often the EPSG user name for the VerticalCS.
+ * VerticalDatumGeoKey: An EPSG vertical datum code (normally 5000 to 5299).
+ * VerticalUnitsGeoKey: An EPSG units code (normally 9000 to 9199, 9001=meter)
+Interesting things to note:
+ * There does not appear to be a VerticalUnitSizeGeoKey allowing user defined
+ vertical units similarly to the ProjLinearSizeGeoKey, so it is not
+ appropriate to use KvUserDefined for VerticalUnitsGeoKey.
+ * The libgeotiff epsg_vertcs.inc file seems to imply that the vertical datum
+ codes in the range 5000 to 5299 should be considered vertical coordinate
+ systems which they are not in the EPSG data model. It is not clear whether
+ this is something that changed in the EPSG data model after the initiation
+ of the GeoTIFF specification, or if it was an error by the
+ GeoTIFF/libgeotiff authors. This mismatch is why Unknown-5101 above is not
+ reported as Newlyn directly. Spec issue reported at
+ http://trac.osgeo.org/geotiff/ticket/24
+ * The EPSG and OGC models include an EPSG code for a composite coordinate
+ system. The composite coordinate system is a collection of a horizontal
+ coordinate system (like PCS_WGS84_UTM_zone_15N) and a vertical coordinate
+ system (like 5701 - ODN height). An example is
+ [http://spatialreference.org/ref/epsg/7405/html EPSG:7405] - OSGB36 /
+ British National Grid + ODN. There is no way to represent this in a GeoTIFF
+ tag.
+Vertical CS in OGC WKT
+As noted above, EPSG and OGC have a concept of a compound coordinate system.
+An example from the CT 1.0 specification (OGC 09-001) looks like this:
+ COMPD_CS["OSGB36 / British National Grid + ODN",
+ PROJCS["OSGB 1936 / British National Grid",
+ GEOGCS["OSGB 1936",
+ DATUM["OSGB_1936",
+ SPHEROID["Airy 1830",6377563.396,299.3249646,
+ AUTHORITY["EPSG","7001"]],
+ TOWGS84[375,-111,431,0,0,0,0],
+ AUTHORITY["EPSG","6277"]],
+ PRIMEM["Greenwich",0,
+ AUTHORITY["EPSG","8901"]],
+ UNIT["DMSH",0.0174532925199433,
+ AUTHORITY["EPSG","9108"]],
+ AXIS["Lat",NORTH],
+ AXIS["Long",EAST],
+ AUTHORITY["EPSG","4277"]],
+ PROJECTION["Transverse_Mercator"],
+ PARAMETER["latitude_of_origin",49],
+ PARAMETER["central_meridian",-2],
+ PARAMETER["scale_factor",0.999601272],
+ PARAMETER["false_easting",400000],
+ PARAMETER["false_northing",-100000],
+ UNIT["metre",1,
+ AUTHORITY["EPSG","9001"]],
+ AXIS["E",EAST],
+ AXIS["N",NORTH],
+ AUTHORITY["EPSG","27700"]],
+ VERT_CS["Newlyn",
+ VERT_DATUM["Ordnance Datum Newlyn",2005,
+ AUTHORITY["EPSG","5101"]],
+ UNIT["metre",1,
+ AXIS["Up",UP],
+ AUTHORITY["EPSG","5701"]],
+ AUTHORITY["EPSG","7405"]]
+The VERT_CS portion is analogous to the information we store in GeoTIFF file
+about vertical coordinate systems, though we have no mechanism to hold the
+overall name or authority code of the COMPD_CS wrapper.
+ * The VERT_DATUM keyword includes a name and a datum type code (2005 in this
+ case). The set from the specification is specified in on page 58, section
+ 12.3.8 which is roughly captured in [wiki:OGCVerticalDatumTypes OGC
+ Vertical Datum Types].
+ * For reference, the same compound coordinate system is handled similarly in
+ [http://spatialreference.org/ref/epsg/7405/html Geotools]
+ * GDAL/OGR, used to process libLAS OGC WKT does not currently have meaningful
+ support for vertical or compound coordinate systems.
+Vertical CS in PROJ.4
+PROJ.4 currently has no support for vertical coordinate systems, nor any way
+of representing them.
+Sample Data
+A standard sample file has been prepared demonstrating good practice setting a
+vertical cs. The geotiff tags look like:
+ Version: 1
+ Key_Revision: 1.0
+ End_Of_Tags.
+ GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
+ ProjectedCSTypeGeoKey (Short,1): PCS_WGS84_UTM_zone_17N
+ VerticalCSTypeGeoKey (Short,1): Unknown-5703
+ VerticalCitationGeoKey (Ascii,38): "North American Vertical Datum of 1988"
+ VerticalDatumGeoKey (Short,1): Unknown-5103
+ End_Of_Keys.
+ End_Of_Geotiff.
+The test file is available at:
+http://hg.liblas.org/main/raw-file/tip/test/data/srs_vertcs.las
+Proposed LASSpatialReference Interfaces
+The LASSpatialReference class is used to manipulate the spatial references
+which are considered to include the vertical coordinate system. It is proposed
+to add the following interfaces.
+LASSpatialReference::SetVerticalCS
+This is a fairly low level method to set the vertical coordinate system
+information on the spatial reference (setting the appropriate geokeys), and
+updating the VLR.
+.. code-block:: cpp
+ /// Sets the vertical coordinate system using geotiff key values.
+ /// This operation should normally be done after setting the horizontal
+ /// portion of the coordinate system with something like SetWKT(),
+ /// SetProj4(), SetGTIF() or SetFromUserInput()
+ /// \param verticalCSType - An EPSG vertical coordinate system code,
+ /// normally in the range 5600 to 5799, or -1 if one is not available.
+ /// \param citation - a textual description of the vertical coordinate
+ /// system or an empty string if nothing is available.
+ /// \param verticalDatum - the EPSG vertical datum code, often in the
+ /// range 5100 to 5299 - implied by verticalCSType if that is provided, or
+ /// -1 if no value is available.
+ /// \param verticalUnits - the EPSG vertical units code, often 9001 for Metre.
+ void LASSpatialReference::SetVerticalCS( int verticalCSType,
+ std::string const& citation,
+ int verticalDatum,
+ int verticalUnits )
+It is mainly intended for those wishing to extend coordinate system
+information from another source (WKT, PROJ.4, an existing las file) with
+vertical cs data in a convenient fashion. This will be used to implement
+-a_vertcs in las2las.
+LASSpatialReference::GetWKT()
+This method will be modified to support read with or without the compound
+coordinate system.
+ enum WKTModeFlag
+ eHorizontalOnly = 1,
+ eCompoundOK = 2
+ /// Returns the OGC WKT describing Spatial Reference System.
+ /// If GDAL is linked, it uses GDAL's operations and methods to determine
+ /// the WKT. If GDAL is not linked, no WKT is returned.
+ /// \param mode_flag May be eHorizontalOnly indicating the WKT will not
+ /// include vertical coordinate system info (the default), or
+ /// eCompoundOK indicating the the returned WKT may be a compound
+ /// coordinate system if there is vertical coordinate system info
+ /// available.
+ std::string GetWKT( WKTModeFlag mode_flag = eHorizontalOnly ) const;
+Note, that while eHorizontalOnly is the default, this is just to avoid
+compatibility problems. eCompoundOK is the general version of the function and
+returns a COMPD_CS coordinate system with the vertical coordinate system if
+there is vertical information available, otherwise is just returns the normal
+horizontal coordinate system.
+Internally this is implemented by improvements to GTIFGetOGISDefn() in GDAL.
+LASSpatialReference::SetWKT()
More information about the Liblas-commits
