[Liblas-commits] hg: exception instead of excepion
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Sep 28 12:05:13 EDT 2010
changeset a5eb61966315 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a5eb61966315
summary: exception instead of excepion
diffstat:
 include/liblas/lasreader.hpp |  30 +++++++++++++++---------------
 include/liblas/laswriter.hpp |   2 +-
 2 files changed, 16 insertions(+), 16 deletions(-)
diffs (107 lines):
diff -r c7748a59fad4 -r a5eb61966315 include/liblas/lasreader.hpp
--- a/include/liblas/lasreader.hpp	Tue Sep 28 11:00:13 2010 -0500
+++ b/include/liblas/lasreader.hpp	Tue Sep 28 11:05:08 2010 -0500
@@ -69,7 +69,7 @@
     /// Consructor initializes reader with input stream as source of LAS records.
     /// @param ifs - stream used as source of LAS records.
-    /// @excepion std::runtime_error - on failure state of the input stream.
+    /// @exception std::runtime_error - on failure state of the input stream.
     Reader(std::istream& ifs);
     Reader(std::istream& ifs, boost::uint32_t cache_size);
     Reader(std::istream& ifs, boost::uint32_t cache_size, Header& header);
@@ -78,68 +78,68 @@
     /// User-defined consructor initializes reader with input stream and
     /// a header to override the values in the file
     Reader(std::istream& ifs, Header& header);
     /// Destructor.
-    /// @excepion nothrow
+    /// @exception nothrow
     ~Reader();
     /// Provides read-only access to header of LAS file being read.
     Header const& GetHeader() const;
     /// Provides read-only access to current point record.
     Point const& GetPoint() const;
     /// Provides read-only access to collection of variable-length records.
     std::vector<VariableRecord> const& GetVLRs() const;
     /// Allow fetching of the stream attached to the reader.
     std::istream& GetStream() const;
     /// Checks if end-of-file has been reached.
     bool IsEOF() const;
     /// Fetches next point record in file.
-    /// @excepion may throw std::exception
+    /// @exception may throw std::exception
     bool ReadNextPoint();
     /// Fetches n-th point record from file.
     bool ReadPointAt(std::size_t n);
     /// Reinitializes state of the reader.
     void Reset();
     /// Move to the specified point to start
     /// ReadNextPoint operations
     bool seek(std::size_t n);
     /// Reproject data as they are written if the Reader's reference is
     /// different than the Header's.
     bool SetSRS(const SpatialReference& ref);
     /// Override the spatial reference of the Reader's Header for
     /// writing purposes.
     bool SetInputSRS(const SpatialReference& ref);
     bool SetOutputSRS(const SpatialReference& ref);
     /// Provides index-based access to point records.
     /// The operator is implemented in terms of ReadPointAt method
     /// and is not const-qualified because it updates file stream position.
     Point const& operator[](std::size_t n);
     /// Sets filters that are used to determine whether or not to
diff -r c7748a59fad4 -r a5eb61966315 include/liblas/laswriter.hpp
--- a/include/liblas/laswriter.hpp	Tue Sep 28 11:00:13 2010 -0500
+++ b/include/liblas/laswriter.hpp	Tue Sep 28 11:05:08 2010 -0500
@@ -66,7 +66,7 @@
     /// Consructor initializes reader with specified output stream and header specification.
     /// @param ofs - stream used as destination for LAS records.
     /// @param header - specifies obligatory properties of LAS file.
     Writer(std::ostream& ofs, Header const& header);
     /// Destructor does not close file attached to the output stream
More information about the Liblas-commits mailing list
