[Liblas-commits] hg: add full help listing
liblas-commits at liblas.org
Tue Sep 28 12:07:38 EDT 2010
changeset f5c582719379 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=f5c582719379
summary: add full help listing
diffstat:
doc/utilities/las2las2.txt | 118 ++++++++++++++++++++++++++++++++++++++++++++-
1 files changed, 117 insertions(+), 1 deletions(-)
diffs (136 lines):
diff -r a5eb61966315 -r f5c582719379 doc/utilities/las2las2.txt
--- a/doc/utilities/las2las2.txt Tue Sep 28 11:05:08 2010 -0500
+++ b/doc/utilities/las2las2.txt Tue Sep 28 11:07:33 2010 -0500
@@ -22,7 +22,7 @@
While `lasinfo` can do a few simple operations like
updating header information, more drastic changes, like removing points or
altering values, will require :ref:`las2las2 <las2las2>`. :ref:`las2las` is expected to be used for
-modifying single files at a time, and some :ref:`las2las` operations require multiple
+modifying single files at a time, and some :ref:`las2las2 <las2las2>` operations require multiple
read passes through the points. Some examples of operations `las2las` can be
used for include:
@@ -236,6 +236,122 @@
removes all VLRs from in.las when writing the new output.las file.
+Help listing
+ las2las (libLAS 1.6.0 with GeoTIFF 1.3.0 GDAL 1.8dev)
+ las2las2 options:
+ -h [ --help ] produce help message
+ --split-mb arg (=0) Split file into multiple files with each
+ being this size in MB or less. If this
+ value is 0, no splitting is done
+ --split-pts arg (=0) Split file into multiple files with each
+ being this many points or less. If this
+ -i [ --input ] arg input LAS file
+ -o [ --output ] arg (=output.las) output LAS file
+ -v [ --verbose ] Verbose message output
+ Header modification options:
+ --a_srs arg Coordinate system to assign to input LAS file
+ --a_vertcs arg Override vertical coordinate system information. Use
+ --a_vertcs "verticalCSType [citation [verticalDatum
+ [verticalUnits]]]"
+ For example: --a_vertcs 5703 "North American Vertical
+ Datum of 1988 (NAVD88)" 5103 9001
+ --offset arg A list of offsets to set on the output file:
+ --offset 0 0 0
+ --scale arg A list of scales to set on the output file:
+ --scale 0.1 0.1 0.00001
+ -f [ --format ] arg Set the LAS format of the new file (only 1.0-1.2
+ supported at this time):
+ --format 1.2
+ -f 1.1
+ --pad-header arg Add extra bytes to the existing header
+ --min-offset Set the offset of the header to the minimums of all
+ values in the file. Note that this requires multiple
+ read passes through the file to achieve.
+ --file-creation arg Set the header's day/year. Specify either as "1 2010"
+ for the first day of 2010, or as "now" to specify the
+ current day/year
+ --add-schema Add the liblas.org schema VLR record to the file.
+ Transformation options:
+ --t_srs arg Coordinate system to reproject output LAS file to. Use
+ --a_srs or verify that your input LAS file has a
+ coordinate system according to lasinfo
+ Filtering options:
+ -e [ --extent ] arg Extent window that points must fall within to keep.
+ For example,
+ -e minx miny maxx maxy
+ or
+ -e minx miny minz maxx maxy maxz
+ -t [ --thin ] arg (=0) Simple decimation-style thinning.
+ Thin the file by removing every t'th point from the
+ file.
+ --last_return_only Keep last returns (cannot be used with
+ --first_return_only)
+ --first_return_only Keep first returns (cannot be used with
+ --keep-returns arg A list of return numbers to keep in the output file:
+ --keep-returns 1 2 3
+ --drop-returns arg Return numbers to drop.
+ For example, --drop-returns 2 3 4 5
+ --valid_only Keep only valid points
+ --keep-classes arg A list of classifications to keep:
+ --keep-classes 2 4 12
+ --keep-classes 2
+ --drop-classes arg A comma-separated list of classifications to drop:
+ --drop-classes 1,7,8
+ --drop-classes 2
+ --keep-intensity arg Range in which to keep intensity.
+ The following expression types are supported:
+ --keep-intensity 0-100
+ --keep-intensity <200
+ --keep-intensity >400
+ --keep-intensity >=200
+ --drop-intensity arg Range in which to drop intensity.
+ --drop-intensity <200
+ --drop-intensity >400
+ --drop-intensity >=200
+ --keep-time arg Range in which to keep time.
+ --keep-time 413665.2336-414092.8462
+ --keep-time <414094.8462
+ --keep-time >413665.2336
+ --keep-time >=413665.2336
+ --drop-time arg Range in which to drop time.
+ --drop-time <413666.2336
+ --drop-time >413665.2336
+ --drop-time >=413665.2336
+ --keep-scan-angle arg Range in which to keep scan angle.
+ --keep-scan-angle 0-100
+ --keep-scan-angle <100
+ --keep-scan-angle <=100
+ --drop-scan-angle arg Range in which to drop scan angle.
+ --drop-scan-angle <30
+ --drop-scan-angle >100
+ --drop-scan-angle >=100
+ --keep-color arg Range in which to keep colors.
+ Define colors as two 3-tuples (R,G,B-R,G,B):
+ --keep-color '0,0,0-125,125,125'
+ --drop-color arg Range in which to drop colors.
+ --drop-color '255,255,255-65536,65536,65536'
+ For more information, see the full documentation for las2las2 at:
+ http://liblas.org/utilities/las2las2.html
.. _`GDAL`: http://www.gdal.org
.. _`LAStools`: http://www.cs.unc.edu/~isenburg/lastools/
\ No newline at end of file
More information about the Liblas-commits
