[Liblas-commits] hg: Add sorting support to reduce memory use.
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Mar 8 14:37:34 EST 2011
details:   http://hg.liblas.orghg/rev/6e3e617261fe
changeset: 2898:6e3e617261fe
user:      Andrew Bell <andrew.bell.ia at gmail.com>
date:      Tue Mar 08 13:14:06 2011 -0600
description:
Subject: hg: Merge
details:   http://hg.liblas.orghg/rev/294e04679171
changeset: 2899:294e04679171
date:      Tue Mar 08 13:23:04 2011 -0600
description:
Merge
diffstat:
 .hgtags        |    1 +
 CMakeLists.txt                                                               |    4 +-
 apps/las2las.cpp                                                             |   39 +-
 apps/las2oci.cpp                                                             |    2 +-
 apps/lasinfo.cpp                                                             |    4 +-
 cmake/modules/FindLASzip.cmake                                               |    3 +-
 doc/_static/files/libLAS-Howard-Butler-ILMF-2011.pdf                         |    0
 doc/compilation.txt                                                          |    4 +-
 doc/conf.py        |    3 +
 doc/development/index.txt                                                    |    2 +-
 doc/development/release_plan.txt                                             |  190 --
 doc/development/wkt.txt                                                      |  190 ++
 doc/download.txt                                                             |   29 +-
 doc/images/osgeo4w-lasinfo-output.png                                        |    0
 doc/index.txt        |   10 +-
 doc/lastools.txt                                                             |   17 +-
 doc/osgeo4w.txt                                                              |   52 +-
 doc/start.txt        |    9 +-
 doc/tutorial/cpp.txt                                                         |  349 +++-
 doc/zip/index.txt                                                            |   54 -
 hobu-config.bat                                                              |   15 +-
 include/liblas/bounds.hpp                                                    |    2 +-
 include/liblas/capi/las_version.h                                            |    6 +-
 include/liblas/chipper.hpp                                                   |   56 +-
 include/liblas/detail/private_utility.hpp                                    |    2 +-
 include/liblas/external/property_tree/detail/exception_implementation.hpp    |    4 +-
 include/liblas/external/property_tree/detail/file_parser_error.hpp           |    4 +-
 include/liblas/external/property_tree/detail/info_parser_error.hpp           |    4 +-
 include/liblas/external/property_tree/detail/info_parser_read.hpp            |    4 +-
 include/liblas/external/property_tree/detail/info_parser_utils.hpp           |    4 +-
 include/liblas/external/property_tree/detail/info_parser_write.hpp           |    4 +-
 include/liblas/external/property_tree/detail/info_parser_writer_settings.hpp |    4 +-
 include/liblas/external/property_tree/detail/json_parser_error.hpp           |    4 +-
 include/liblas/external/property_tree/detail/json_parser_read.hpp            |    4 +-
 include/liblas/external/property_tree/detail/json_parser_write.hpp           |    4 +-
 include/liblas/external/property_tree/detail/ptree_implementation.hpp        |    4 +-
 include/liblas/external/property_tree/detail/ptree_utils.hpp                 |    4 +-
 include/liblas/external/property_tree/detail/rapidxml.hpp                    |    4 +-
 include/liblas/external/property_tree/detail/xml_parser_error.hpp            |    4 +-
 include/liblas/external/property_tree/detail/xml_parser_flags.hpp            |    4 +-
 include/liblas/external/property_tree/detail/xml_parser_read_rapidxml.hpp    |    4 +-
 include/liblas/external/property_tree/detail/xml_parser_utils.hpp            |    4 +-
 include/liblas/external/property_tree/detail/xml_parser_write.hpp            |    4 +-
 include/liblas/external/property_tree/detail/xml_parser_writer_settings.hpp  |    4 +-
 include/liblas/external/property_tree/exceptions.hpp                         |    4 +-
 include/liblas/external/property_tree/id_translator.hpp                      |    4 +-
 include/liblas/external/property_tree/info_parser.hpp                        |    4 +-
 include/liblas/external/property_tree/ini_parser.hpp                         |    4 +-
 include/liblas/external/property_tree/json_parser.hpp                        |    4 +-
 include/liblas/external/property_tree/ptree.hpp                              |    4 +-
 include/liblas/external/property_tree/ptree_fwd.hpp                          |    4 +-
 include/liblas/external/property_tree/ptree_serialization.hpp                |    4 +-
 include/liblas/external/property_tree/stream_translator.hpp                  |    4 +-
 include/liblas/external/property_tree/string_path.hpp                        |    4 +-
 include/liblas/external/property_tree/xml_parser.hpp                         |    4 +-
 include/liblas/liblas.hpp                                                    |   35 +-
 include/liblas/transform.hpp                                                 |    1 +
 liblas-osgeo4w-init.bat                                                      |    2 +-
 liblas-osgeo4w-start.bat.tmpl                                                |    6 +-
 python/README.txt                                                            |   94 +
 python/scripts/oci2las.py                                                    |   92 +-
 python/setup.py                                                              |   18 +-
 python/tests/Header.txt                                                      |    2 +-
 src/c_api.cpp        |  370 ++--
 src/chipper.cpp                                                              |  186 +-
 src/detail/reader/reader.cpp                                                 |    3 +-
 src/detail/zippoint.cpp                                                      |  762 +++++-----
 src/gt_citation.h                                                            |   50 +
 src/gt_wkt_srs.cpp                                                           |   74 +-
 src/gt_wkt_srs.h                                                             |   46 +
 src/gt_wkt_srs_for_gdal.h                                                    |   48 +
 src/header.cpp                                                               |    2 +-
 src/point.cpp        |   60 +-
 src/spatialreference.cpp                                                     |   35 +
 src/tifvsi.h        |   39 +
 src/variablerecord.cpp                                                       |    2 +-
 test/unit/point_test.cpp                                                     |   27 +-
 test/unit/variablerecord_test.cpp                                            |    2 +-
 78 files changed, 1909 insertions(+), 1210 deletions(-)
diffs (truncated from 4937 to 300 lines):
diff -r 109c69fe418c -r 294e04679171 .hgtags
--- a/.hgtags	Thu Jan 27 09:30:18 2011 -0600
+++ b/.hgtags	Tue Mar 08 13:23:04 2011 -0600
@@ -13,3 +13,4 @@
 d779dd09e547cd56c48ae5d3da3959193fc07cb0 1.0.0b1
 e4baaf6287a20b01e0fbe3632a37c3c559ca9ca2 0.9.6
 f93c63e4384fd4ad3fae69b72db3643455539919 1.0.1
+d1bf7693076ccd8245bd98acea9a1a10553be066 1.6.0
diff -r 109c69fe418c -r 294e04679171 CMakeLists.txt
--- a/CMakeLists.txt	Thu Jan 27 09:30:18 2011 -0600
+++ b/CMakeLists.txt	Tue Mar 08 13:23:04 2011 -0600
@@ -11,11 +11,11 @@
 SET(LIBLAS_VERSION_MAJOR "1")
 SET(LIBLAS_VERSION_MINOR "6")
-SET(LIBLAS_VERSION_PATCH "0b4")
+SET(LIBLAS_VERSION_PATCH "0")
 set(VERSION "${LIBLAS_VERSION_MAJOR}.${LIBLAS_VERSION_MINOR}.${LIBLAS_VERSION_PATCH}")
 SET(LIBLAS_LIB_SOVERSION "2.0.0")
 SET(LIBLAS_C_LIB_SOVERSION "2.0.0")
-SET(OSGEO4W_UPSTREAM_RELEASE "2")
+SET(OSGEO4W_UPSTREAM_RELEASE "1")
 if(WIN32)
   # Name of C++ library
diff -r 109c69fe418c -r 294e04679171 apps/las2las.cpp
--- a/apps/las2las.cpp	Thu Jan 27 09:30:18 2011 -0600
+++ b/apps/las2las.cpp	Tue Mar 08 13:23:04 2011 -0600
@@ -88,6 +88,24 @@
             std::cout << std::endl;
         reader.Reset();
+        // If we have any reprojection going on, we have to reset the offsets
+        // of the HeaderPtr that is applied to the points as they are reprojected
+        // or things will get screwed up when we go to re-assign the header
+        // as we write the points with the min-offset
+        std::vector<liblas::TransformPtr> transforms = reader.GetTransforms();
+        std::vector<liblas::TransformPtr> new_transforms;
+        for (std::size_t i = 0; i < transforms.size(); i++)
+            liblas::TransformPtr transform = transforms[i];
+            if (dynamic_cast<liblas::ReprojectionTransform*>(transform.get()))
+                dynamic_cast<liblas::ReprojectionTransform*>(transform.get())->SetHeaderPtr(liblas::HeaderPtr(new liblas::Header(header)));
+            new_transforms.push_back(transform);
+        reader.SetTransforms(new_transforms);
     std::ostream* ofs = NULL;
@@ -118,13 +136,24 @@
     boost::int32_t split_bytes_count = 1024*1024*split_mb;
     boost::uint32_t split_points_count = 0;
     int fileno = 2;
+    liblas::HeaderPtr ptr = liblas::HeaderPtr(new liblas::Header(header));
     while (reader.ReadNextPoint())
-        liblas::Point const& p = reader.GetPoint();
-        summary->AddPoint(p);
-        writer->WritePoint(p);
+        if (min_offset)
+            liblas::Point p = reader.GetPoint();
+            summary->AddPoint(p);
+            p.SetHeaderPtr(ptr);
+            writer->WritePoint(p);
+        else
+            liblas::Point const& p = reader.GetPoint();
         if (verbose)
             term_progress(std::cout, (i + 1) / static_cast<double>(size));
         i++;
diff -r 109c69fe418c -r 294e04679171 apps/las2oci.cpp
--- a/apps/las2oci.cpp	Thu Jan 27 09:30:18 2011 -0600
+++ b/apps/las2oci.cpp	Tue Mar 08 13:23:04 2011 -0600
@@ -707,7 +707,7 @@
         if (vm.count("help"))
-            std::cout << GetInvocationHeader()<<file_options<<"\n"<<transform_options<<"\n"<<filtering_options<<"\n";
+            std::cout << GetInvocationHeader()<<file_options<<"\n"<<transform_options<<"\n"<<header_options<<"\n"<<filtering_options<<"\n";
             std::cout <<"\nFor more information, see the full documentation for las2oci at:\n";
             std::cout << " http://liblas.org/utilities/las2oci.html\n";
diff -r 109c69fe418c -r 294e04679171 apps/lasinfo.cpp
--- a/apps/lasinfo.cpp	Thu Jan 27 09:30:18 2011 -0600
+++ b/apps/lasinfo.cpp	Tue Mar 08 13:23:04 2011 -0600
@@ -204,7 +204,7 @@
                 if (output_xml) {
                     liblas::property_tree::ptree tree;
-                    tree = p.GetPTree();
+                    tree.add_child("points.point", p.GetPTree());
                     liblas::property_tree::write_xml(std::cout, tree);
                     exit(0);
@@ -236,7 +236,7 @@
                             verbose
-        liblas::Header const& header = reader.GetHeader();
+        header = reader.GetHeader();
         // Add the header to the summary so we can get more detailed
         // info
diff -r 109c69fe418c -r 294e04679171 cmake/modules/FindLASzip.cmake
--- a/cmake/modules/FindLASzip.cmake	Thu Jan 27 09:30:18 2011 -0600
+++ b/cmake/modules/FindLASzip.cmake	Tue Mar 08 13:23:04 2011 -0600
@@ -44,7 +44,8 @@
   /usr/include
   /usr/local/include
   /tmp/lasjunk/include
-  ${OSGEO4W_ROOT_DIR}/include)
+  ${OSGEO4W_ROOT_DIR}/include
+  NO_DEFAULT_PATH)
 SET(LASZIP_NAMES ${OSGEO4W_IMPORT_LIBRARY} laszip)
diff -r 109c69fe418c -r 294e04679171 doc/_static/files/libLAS-Howard-Butler-ILMF-2011.pdf
Binary file doc/_static/files/libLAS-Howard-Butler-ILMF-2011.pdf has changed
diff -r 109c69fe418c -r 294e04679171 doc/compilation.txt
--- a/doc/compilation.txt	Thu Jan 27 09:30:18 2011 -0600
+++ b/doc/compilation.txt	Tue Mar 08 13:23:04 2011 -0600
@@ -255,12 +255,12 @@
-    $ lasinfo -c ../test/data/TO_core_last_zoom.las
+    $ lasinfo ../test/data/TO_core_last_clip.las
       Header Summary
-      File Name: ../test/data/TO_core_last_zoom.las
+      File Name: ../test/data/TO_core_last_clip.las
       Version:                    1.0
       Source ID:                  0
       Reserved:                   0
diff -r 109c69fe418c -r 294e04679171 doc/conf.py
--- a/doc/conf.py	Thu Jan 27 09:30:18 2011 -0600
+++ b/doc/conf.py	Tue Mar 08 13:23:04 2011 -0600
@@ -214,6 +214,9 @@
 pdf_language = "en_US"
 pdf_fit_mode = "overflow"
 pdf_use_toc = True
+pdf_splittables = True
+pdf_appendices = []
+pdf_baseurl = 'http://liblas.org'
 # Example configuration for intersphinx: refer to the Python standard library.
 intersphinx_mapping = {'http://docs.python.org/': None}
diff -r 109c69fe418c -r 294e04679171 doc/development/index.txt
--- a/doc/development/index.txt	Thu Jan 27 09:30:18 2011 -0600
+++ b/doc/development/index.txt	Tue Mar 08 13:23:04 2011 -0600
@@ -17,8 +17,8 @@
    format_elements
    Motivation <http://www.youtube.com/watch?v=u6XAPnuFjJc>
    2010 Annual Report <annual_report_2010>
-   Release Plan <release_plan>
    RFCs <rfc/index>
+   LAS 1.4 WKT Proposal <wkt>
 Authors
diff -r 109c69fe418c -r 294e04679171 doc/development/release_plan.txt
--- a/doc/development/release_plan.txt	Thu Jan 27 09:30:18 2011 -0600
+++ /dev/null	Thu Jan 01 00:00:00 1970 +0000
@@ -1,194 +0,0 @@
-.. _release_plan:
-libLAS 1.6.0 Release Notes and Schedule
-:Author: Howard Butler
-:Contact: hobu.inc at gmail dot com
-:Date: 10/12/2010
-.. contents::
-    :depth: 3
-    :backlinks: none
-Even though there has not been a major release of libLAS since April of 2009,
-development has continued on the library. A number of new features, updates,
-and bug fixes have been developed for the next libLAS release, to be called
-`libLAS 1.6`. This section outlines some of the work that has (or will) gone
-on.
-Major features
-The following are upcoming major features for libLAS 1.6.
-Significant internal refactoring of C++ reading/writing code
-The C++ reader and writer code of libLAS was a bit inflexible, and contained
-significant duplication. Giant updates would be required to the code as the
-ASPRS LAS standard committee adds new versions of the
-specification.  Additionally, the old code's design was a bit rigid for
-adding more generic things.
-The reduction in duplication means going to only one place to make changes to
-the code.  In addition to not repeating ourselves, it provides us more
-flexibility to add new features and extensibility to allow the reader and
-writers to be overridden by user code.
-Rudimentary LAS 1.3 support
-Support for reading and writing LAS 1.3 *point* data is not provided in
-libLAS 1.6.  Support for reading point formats 4 or 5 is not yet complete,
-however.
-Generic interfaces
-A number of generic interfaces have been added to libLAS to support dynamic
-polymorphism. See <liblas/liblas.hpp> for the C++ interfaces. By implementing
-these interfaces, you can add your own reader/writer implementations as well
-as provide custom filtering and transformation capability.
-Schema description support
-Though it is specifically allowed by the standard but not widely implemented,
-it is possible to store extra data attached to each point after the requisite
-PointFormat data are stored. There is neither a regularized way to describe
-these data nor a way to capture metadata about this. To this end, I have
-proposed an XML schema document that could be stored in a VLR as well as
-schema-aware reader and writer implementations that can utilize that VLR to
-work with the data. See <https://lidarbb.cr.usgs.gov/index.php?showtopic=9075>
-for more details on the initial proposal of schema support.
-Alternative formats
-Support for reading the TerraSolid bin format as well as writing the
-Oracle Point Cloud format will be provided for libLAS 1.6, but this code will
-be moving to a new home shortly.  See `libPC`_ for more details on these
-developments
-Generic spatial indexing
-A octree-based spatial index was developed for libLAS to speed up random,
-bounding-box-based queries to LAS files. It is released as part of libLAS 1.6,
-but its full implementation within the library is not yet complete. The index
-can store its data within VLRs (requires a file rewrite) in addition to
-in a file alongside the .las file.
-Rewritten :ref:`lasinfo <lasinfo>` and :ref:`las2las <las2las>`
-:ref:`lasinfo <lasinfo>` and :ref:`las2las <las2las>` have been completely
-rewritten to take advantage of faster access and summary methods within the
-libLAS C++ API.  In addition to nearly double the speed of the previous
-libLAS-provided lasinfo and las2las implementations, both applications
-gained a number of features including much more expressive filtering and
-more detailed header and file transformation.  The old versions of :ref:`lasinfo <lasinfo_old>`
-and :ref:`las2las <las2las_old>` are still available to people who have
-embedded them in processes and applications.  They are now called ``lasinfo-old`` and
-``las2las-old``.
-Migration to CMake
-libLAS has migrated to CMake to manage compilation. See `libLAS Compilation
-<http://liblas.org/compilation.html>`__ for specific details how to use CMake
-to build libLAS from source.
-Minor features
-Caching reader
-A reader implementation that provides data caching will be provided at
-libLAS 1.6. If your data reading involves reading the data in multiple passes
-through the file, you can utilize the cached reader to cache the points
-(up to the size of the entire file) for faster repeated and random access.
-Seek support
-It is now possible to seek to a specific point in the file and start reading
-points.  This can significantly speed up the "random sampling" access strategy
More information about the Liblas-commits mailing list
