[Liblas-commits] libpc: checkpoint
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Mar 8 19:05:38 EST 2011
details:   http://hg.liblas.orglibpc/rev/b4db8be8ea0f
changeset: 186:b4db8be8ea0f
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Mon Mar 07 20:52:36 2011 -0800
description:
checkpoint
Subject: libpc: added cheesy decimation filter
details:   http://hg.liblas.orglibpc/rev/d472a33cd79c
changeset: 187:d472a33cd79c
date:      Tue Mar 08 16:04:11 2011 -0800
description:
Subject: libpc: viewer work
details:   http://hg.liblas.orglibpc/rev/9bf3a3b2a277
changeset: 188:9bf3a3b2a277
date:      Tue Mar 08 16:05:29 2011 -0800
description:
viewer work
diffstat:
 csharp/PCView/MainWindow.xaml.cs           |  228 +++++++++++++++++++++++++---
 csharp/PCView/PCView.csproj                |    7 +
 csharp/PCView/PointCloudRenderEngine.cs    |   45 ++---
 csharp/PCView/Trackball.cs                 |   80 ++++++++++
 csharp/libpc_swig_cpp/libpc.i              |   37 ++++-
 csharp/libpc_swig_cs/libpc_swig_cs.csproj  |    2 +
 csharp/libpc_swig_test/TestLiblasReader.cs |   12 +-
 include/libpc/DecimationFilter.hpp         |   64 ++++++++
 src/CMakeLists.txt                         |    2 +
 src/DecimationFilter.cpp                   |   79 ++++++++++
 test/unit/CMakeLists.txt                   |    1 +
 test/unit/DecimationFilterTest.cpp         |   77 +++++++++
 12 files changed, 570 insertions(+), 64 deletions(-)
diffs (truncated from 872 to 300 lines):
diff -r f769b2b31a74 -r 9bf3a3b2a277 csharp/PCView/MainWindow.xaml.cs
--- a/csharp/PCView/MainWindow.xaml.cs	Mon Mar 07 16:31:08 2011 -0800
+++ b/csharp/PCView/MainWindow.xaml.cs	Tue Mar 08 16:05:29 2011 -0800
@@ -40,7 +40,9 @@
     using System.Windows.Documents;
     using System.Windows.Input;
     using SlimDX;
+    using Libpc;
+    using System;
     /// <summary>
     /// Implements the MouseExample test.
     /// </summary>
@@ -50,6 +52,7 @@
         private Point m_downPoint;
         private bool m_isMoving = false;
         private string m_positionString;
+        private Trackball m_trackball;
         /// <summary>
         /// Initializes a new instance of the Mouse class.
@@ -70,8 +73,25 @@
             this.DataContext = this;
-            Vector4[] points = CreateData();
-            m_renderEngine.SetPoints(points);
+            float minx, miny, minz, maxx, maxy, maxz;
+            Vector4[] points = CreateFileData(out minx, out miny, out minz, out maxx, out maxy, out maxz);
+            //Vector4[] points = CreateRandomData(out minx, out miny, out minz, out maxx, out maxy, out maxz);
+            float rangeX = maxx - minx;
+            float rangeY = maxy - miny;
+            float rangeZ = maxz - minz;
+            float largestRange = Math.Max(rangeX, Math.Max(rangeY, rangeZ));
+            m_renderEngine.TranslationVector = new Vector3(-minx, -miny, -minz);
+            m_renderEngine.ScaleVector = new Vector3(1 / largestRange, 1 / largestRange, 1 / largestRange);
+            m_renderEngine.SetPoints(points, minx, miny, minz, maxx, maxy, maxz);
+            m_trackball = null;
+            // world coords
+            m_renderEngine.CameraPosition = new Vector3(0.5f, 0.5f, -10.0f);
+            m_renderEngine.TargetPosition = new Vector3(0.5f, 0.5f, 0.5f);
             return;
@@ -99,47 +119,78 @@
         #region mouse handlers
         private void Mouse_MouseDown(object sender, MouseButtonEventArgs e)
+            Point point = e.GetPosition(x_contentControl);
+            if (m_trackball == null)
+                m_trackball = new Trackball((float)x_contentControl.ActualWidth, (float)x_contentControl.ActualHeight);
             if (e.LeftButton == MouseButtonState.Pressed)
-                m_downPoint = e.GetPosition(x_contentControl);
+                m_downPoint = point;
+                m_trackball.PreviousPoint = m_downPoint;
+                m_isMoving = true;
+            if (e.RightButton == MouseButtonState.Pressed)
                 m_isMoving = true;
         private void Mouse_MouseUp(object sender, MouseButtonEventArgs e)
-            m_isMoving = false;
+            if (e.LeftButton == MouseButtonState.Pressed)
+                m_isMoving = false;
         private void Mouse_MouseMove(object sender, MouseEventArgs e)
-            Point mouse = e.GetPosition(x_contentControl);
-            Vector3 world = m_renderEngine.ConvertToWorldCoordinates(mouse, (float)x_contentControl.ActualWidth, (float)x_contentControl.ActualHeight);
-            PositionString = string.Format(
-                CultureInfo.InvariantCulture,
-                "[{0},{1}]  X={2}  Y={3}  Z={4}",
-                mouse.X,
-                mouse.Y,
-                world.X.ToString("F1", CultureInfo.InvariantCulture),
-                world.Y.ToString("F1", CultureInfo.InvariantCulture),
-                world.Z.ToString("F1", CultureInfo.InvariantCulture));
+                Vector3 world = m_renderEngine.ConvertToWorldCoordinates(point, (float)x_contentControl.ActualWidth, (float)x_contentControl.ActualHeight);
+                PositionString = string.Format(
+                    CultureInfo.InvariantCulture,
+                    "[{0},{1}]  X={2}  Y={3}  Z={4}",
+                    point.X,
+                    point.Y,
+                    world.X.ToString("F1", CultureInfo.InvariantCulture),
+                    world.Y.ToString("F1", CultureInfo.InvariantCulture),
+                    world.Z.ToString("F1", CultureInfo.InvariantCulture));
                 if (m_isMoving)
-                    Point currPoint = e.GetPosition(x_contentControl);
-                    Vector3 camera = m_renderEngine.CameraPosition;
-                    Vector3 target = m_renderEngine.TargetPosition;
-                    camera.X += (float)(m_downPoint.X - currPoint.X) / 100.0f;
-                    target.X += (float)(m_downPoint.X - currPoint.X) / 100.0f;
-                    camera.Y += -(float)(m_downPoint.Y - currPoint.Y) / 100.0f;
-                    target.Y += -(float)(m_downPoint.Y - currPoint.Y) / 100.0f;
-                    m_renderEngine.CameraPosition = camera;
-                    m_renderEngine.TargetPosition = target;
-                    m_downPoint = currPoint;
+                    Matrix rotation = m_trackball.Update(point);
+                    m_renderEngine.RotationMatrix = rotation;
+                if (m_isMoving)
+                    float x = (float)(m_downPoint.X - point.X);
+                    float y = -(float)(m_downPoint.Y - point.Y);
+                    Vector3 vc = m_renderEngine.CameraPosition;
+                    Vector3 vt = m_renderEngine.TargetPosition;
+                    vc.X += x / 100;
+                    vc.Y += y / 100;
+                    vt.X += x / 100;
+                    vt.Y += y / 100;
+                    m_renderEngine.CameraPosition = vc;
+                    m_renderEngine.TargetPosition = vt;
@@ -148,14 +199,126 @@
         private void Mouse_MouseWheel(object sender, MouseWheelEventArgs e)
+            ////float s = (float)e.Delta / 100;
+            ////if (s < 0) s = 1 / -s;
+            ////m_renderEngine.Scale *= Matrix.Scaling(s,s,s);
+            //m_renderEngine.Scale = m_trackball.Scale(e.Delta);
-            camera.Z += e.Delta / 100.0f;
+            camera.Z += e.Delta / (120.0f * 1);
+            if (camera.Z >= m_renderEngine.TargetPosition.Z) return;
+            return;
         #endregion
-        private Vector4[] CreateData()
+        private DecimationFilter m_filter = null; // BUG: swig scoping issue
+        private LiblasReader m_reader = null;
+        private Vector4[] CreateFileData(out float minx, out float miny, out float minz, out float maxx, out float maxy, out float maxz)
+            //string file = "../../test/data/1.2-with-color.las";
+            string file = "../../test/data/hobu.las";
+            Vector4 red = new Vector4(1, 0, 0, 1);
+            Vector4 green = new Vector4(0, 1, 0, 1);
+            Vector4 blue = new Vector4(0, 0, 1, 1);
+            List<Vector4> points = new List<Vector4>();
+            istream istr = Utils.openFile(file);
+            m_reader = new LiblasReader(istr);
+            Stage stage = m_reader;
+                int np = (int)m_reader.getNumPoints();
+                if (np > 100000)
+                    int step = np / 100000;
+                    m_filter = new DecimationFilter(m_reader, step);
+                    stage = m_filter;
+            Header header = stage.getHeader();
+            Bounds_double bounds = header.getBounds();
+            minx = (float)bounds.getMinimum(0);
+            miny = (float)bounds.getMinimum(1);
+            minz = (float)bounds.getMinimum(2);
+            maxx = (float)bounds.getMaximum(0);
+            maxy = (float)bounds.getMaximum(1);
+            maxz = (float)bounds.getMaximum(2);
+            // 1.2-with-color
+            //minx 635619.9f
+            //miny 848899.7f
+            //minz 406.59f
+            //maxx 638982.563
+            //maxy 853535.438
+            //maxz 586.38
+            ulong numPoints = stage.getNumPoints();
+            //numPoints = Math.Min(numPoints, 100000);
+            Schema schema = stage.getHeader().getSchema();
+            SchemaLayout layout = new SchemaLayout(schema);
+            PointData data = new PointData(layout,(uint)numPoints);
+            uint numRead = stage.read(data);
+            uint offsetX = (uint)schema.getDimensionIndex(Dimension.Field.Field_X);
+            uint offsetY = (uint)schema.getDimensionIndex(Dimension.Field.Field_Y);
+            uint offsetZ = (uint)schema.getDimensionIndex(Dimension.Field.Field_Z);
+            uint offsetR = (uint)schema.getDimensionIndex(Dimension.Field.Field_Red);
+            uint offsetG = (uint)schema.getDimensionIndex(Dimension.Field.Field_Green);
+            uint offsetBG = (uint)schema.getDimensionIndex(Dimension.Field.Field_Blue);
+            for (uint index=0; index<numRead; index++)
+                Int32 xraw = data.getField_Int32(index, offsetX);
+                Int32 yraw = data.getField_Int32(index, offsetY);
+                Int32 zraw = data.getField_Int32(index, offsetZ);
+                float x = (float)schema.getDimension(offsetX).getNumericValue_Int32(xraw);
+                float y = (float)schema.getDimension(offsetY).getNumericValue_Int32(yraw);
+                float z = (float)schema.getDimension(offsetZ).getNumericValue_Int32(zraw);
+                if (index == 0)
+                    minx = maxx = x;
+                    miny = maxy = y;
+                    minz = maxz = z;
+                else
+                    minx = Math.Min(x, minx);
+                    miny = Math.Min(y, miny);
+                    minz = Math.Min(z, minz);
+                    maxx = Math.Max(x, maxx);
+                    maxy = Math.Max(y, maxy);
+                    maxz = Math.Max(z, maxz);
+                UInt16 r = data.getField_UInt16(index, offsetX);
+                UInt16 g = data.getField_UInt16(index, offsetY);
+                UInt16 b = data.getField_UInt16(index, offsetZ);
+                points.Add(new Vector4(x, y, z, 1));
+                float rf = (float)r / 65535.0f;
+                float gf = (float)g / 65535.0f;
+                float bf = (float)b / 65535.0f;
+                points.Add(new Vector4(rf, gf, bf, 1));
+                //points.Add(blue);
+            Utils.closeFile(istr);
+            return points.ToArray();
+        private Vector4[] CreateRandomData(out float minx, out float miny, out float minz, out float maxx, out float maxy, out float maxz)
@@ -178,6 +341,13 @@
                 points.Add(new Vector4(r, g, b, 1));
+            minx = 0;
+            miny = 0;
+            minz = 0;
+            maxx = 100;
+            maxy = 100;
+            maxz = 100;
diff -r f769b2b31a74 -r 9bf3a3b2a277 csharp/PCView/PCView.csproj
--- a/csharp/PCView/PCView.csproj	Mon Mar 07 16:31:08 2011 -0800
+++ b/csharp/PCView/PCView.csproj	Tue Mar 08 16:05:29 2011 -0800
@@ -107,6 +107,7 @@
More information about the Liblas-commits mailing list
