[Liblas-commits] libpc: a big wad of Oracle writer
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Mar 9 09:21:38 EST 2011
details:   http://hg.liblas.orglibpc/rev/1b0b916218c7
changeset: 189:1b0b916218c7
user:      Howard Butler <hobu.inc at gmail.com>
date:      Wed Mar 09 08:21:32 2011 -0600
description:
diffstat:
 src/drivers/oci/block.hpp  |    6 +-
 src/drivers/oci/writer.cpp |  421 ++++++++++++++++++++++++++++++++++++++++++--
 src/drivers/oci/writer.hpp |   80 +++++++-
 3 files changed, 475 insertions(+), 32 deletions(-)
diffs (truncated from 593 to 300 lines):
diff -r 9bf3a3b2a277 -r 1b0b916218c7 src/drivers/oci/block.hpp
--- a/src/drivers/oci/block.hpp	Tue Mar 08 16:05:29 2011 -0800
+++ b/src/drivers/oci/block.hpp	Wed Mar 09 08:21:32 2011 -0600
@@ -46,10 +46,12 @@
 public:
     Block( chipper::Block const& block);
+    Block(Block const& other) : m_block(other.m_block) {};
 private:
     Block& operator=(const Block&); // nope
-    Block(const Block&); // nope
     chipper::Block const&  m_block;
diff -r 9bf3a3b2a277 -r 1b0b916218c7 src/drivers/oci/writer.cpp
--- a/src/drivers/oci/writer.cpp	Tue Mar 08 16:05:29 2011 -0800
+++ b/src/drivers/oci/writer.cpp	Wed Mar 09 08:21:32 2011 -0600
@@ -34,6 +34,8 @@
 #include <cassert>
+#include <sstream>
+#include <cctype> // toupper
 #include "writer.hpp"
 #include "header.hpp"
@@ -42,29 +44,98 @@
 #include <libpc/exceptions.hpp>
 #include <libpc/libpc_config.hpp>
+#include <cstdlib>
+#include <iostream>
-namespace libpc
+#include <boost/make_shared.hpp>
+namespace libpc { namespace driver { namespace oci {
+Options::Options()
+    m_tree.put("3d", false);
+    m_tree.put("solid", false);
+    m_tree.put("overwrite", false);
+    m_tree.put("debug", false);
+    m_tree.put("verbose", false);
+    m_tree.put("srid", 4269);
+    m_tree.put("capacity", 8000);
+    m_tree.put("precision", 8);
+    m_tree.put("pcid", -1);
+    m_tree.put("connection", std::string(""));
+    m_tree.put("block_table_name", std::string("output"));
+    m_tree.put("block_table_partition_column", std::string(""));
+    m_tree.put("block_table_partition_value", std::string(""));
+    m_tree.put("base_table_name", std::string("hobu"));
+    m_tree.put("cloud_column_name", std::string("cloud"));
+    m_tree.put("header_blob_column_name", std::string("header"));
+    m_tree.put("base_table_aux_columns", std::string(""));
+    m_tree.put("base_table_aux_values", std::string(""));
+    m_tree.put("pre_block_sql", std::string(""));
+    m_tree.put("pre_sql", std::string(""));
+    m_tree.put("post_block_sql", libpc::Bounds<double>());
+bool Options::IsDebug() const
+    bool debug = false;
+    try
+        debug = m_tree.get<bool>("debug");
+    catch (liblas::property_tree::ptree_bad_path const& e) {
+      ::boost::ignore_unused_variable_warning(e);
+    return debug;
+Writer::Writer(Stage& prevStage, Options& options)
+    : Consumer(prevStage)
+    , m_stage(prevStage)
+    , m_chipper(m_stage, options.GetPTree().get<boost::uint32_t>("capacity") )
+    , m_options(options)
+    , m_verbose(false)
-OCIWriter::OCIWriter(Stage& prevStage, boost::uint32_t block_size)
-    : Consumer(prevStage), m_stage(prevStage), m_block_size(block_size)
-    chipper::Chipper c(m_stage, m_block_size );
-    c.Chip();
     return;
+Connection Writer::Connect()
+    std::string connection = m_options.GetPTree().get<std::string>("connection");
+    if (connection.empty())
+        throw libpc_error("Oracle connection string empty! Unable to connect");
-OCIWriter::~OCIWriter()
+    std::string::size_type slash_pos = connection.find("/",0);
+    std::string username = connection.substr(0,slash_pos);
+    std::string::size_type at_pos = connection.find("@",slash_pos);
+    std::string password = connection.substr(slash_pos+1, at_pos-slash_pos-1);
+    std::string instance = connection.substr(at_pos+1);
+    Connection con = boost::make_shared<OWConnection>(username.c_str(),password.c_str(),instance.c_str());
+    if (con->Succeeded())
+        if (m_verbose)
+            std::cout << "Oracle connection succeeded" << std::endl;
+    else
+        throw libpc_error("Oracle connection failed");
+    return con;
+Writer::~Writer()
     return;
-const std::string& OCIWriter::getName() const
+const std::string& Writer::getName() const
     static std::string name("OCI Writer");
     return name;
@@ -75,21 +146,270 @@
-void OCIWriter::writeBegin()
+void Writer::run(std::ostringstream const& command)
+    Statement statement = Statement(m_connection->CreateStatement(command.str().c_str()));
+    // Because of OCIGDALErrorHandler, this is going to throw if there is a
+    // problem.  When it does, the statement should go out of scope and
+    // be destroyed without leaking.
+    statement->Execute();
+void Writer::WipeBlockTable()
+    std::ostringstream oss;
+    std::string block_table_name = m_options.GetPTree().get<std::string>("block_table_name");
+    std::string base_table_name = m_options.GetPTree().get<std::string>("base_table_name");
+    std::string cloud_column_name = m_options.GetPTree().get<std::string>("cloud_column_name");
+    oss << "DELETE FROM " << block_table_name;
+    try {
+        run(oss);
+    } catch (libpc_error const&)
+        // if we failed, let's try dropping the spatial index for the block_table_name
+        oss.str("");
+        if (m_options.IsDebug())
+            std::cout << "Dropping index " << block_table_name
+                      << "_cloud_idx for block_table_name"
+                      << std::endl;
+        oss << "DROP INDEX " << block_table_name << "_cloud_idx" ;
+        run(oss);
+        oss.str("");
+        run(oss);
+        oss.str("");
+    oss.str("");
+    // These need to be uppercase to satisfy the PLSQL function
+    cloud_column_name = to_upper(cloud_column_name);
+    base_table_name = to_upper(base_table_name);
+    oss << "declare\n"
+           "begin \n"
+           "  mdsys.sdo_pc_pkg.drop_dependencies('"
+           << base_table_name <<
+           << cloud_column_name <<
+           "'); end;";
+    run(oss);
+    oss.str("");
+    oss << "DROP TABLE" << block_table_name;
+    run(oss);
+    oss.str("");
+    // Oracle upper cases the table name when inserting it in the
+    // USER_SDO_GEOM_METADATA.  We'll use std::transform to do it.
+    // See http://forums.devx.com/showthread.php?t=83058 for the
+    // technique
+    block_table_name = to_upper(block_table_name);
+    oss << "DELETE FROM USER_SDO_GEOM_METADATA WHERE TABLE_NAME='" << block_table_name << "'" ;
+    run(oss);
+void Writer::CreateBlockIndex()
+    bool is3d = m_options.GetPTree().get<bool>("3d");
+    oss << "CREATE INDEX "<< block_table_name << "_cloud_idx on "
+        << block_table_name << "(blk_extent) INDEXTYPE IS MDSYS.SPATIAL_INDEX";
+    if (is3d)
+        oss <<" PARAMETERS('sdo_indx_dims=3')";
+    run(oss);
+    oss.str("");
+    oss << "CREATE INDEX " << block_table_name <<"_objectid_idx on "
+        << block_table_name << "(OBJ_ID,BLK_ID) COMPRESS 2" ;
+    run(oss);
+    oss.str("");
+bool Writer::BlockTableExists()
+    char szTable[OWNAME]= "";
+    oss << "select table_name from user_tables where table_name like upper('%%"<< block_table_name <<"%%') ";
+    Statement statement = Statement(m_connection->CreateStatement(oss.str().c_str()));
+    statement->Define(szTable);
+    try {
+    } catch (libpc_error const& ) {
+        // Assume for now that an error returned here is OCI_NODATA, which means
+        // the table doesn't exist.  If this really isn't the case, we're going
+        // to get more legit message further down the line.
+        return false;
+    return true;
+void Writer::CreateBlockTable()
+    oss << "CREATE TABLE " << block_table_name << " AS SELECT * FROM MDSYS.SDO_PC_BLK_TABLE";
+    run(oss);
+    m_connection->Commit();
+bool Writer::IsGeographic(boost::int32_t srid)
+    typedef boost::shared_ptr<long> shared_long;
+    typedef boost::shared_ptr<char> shared_char;
+    // char* kind = (char* ) malloc (OWNAME * sizeof(char));
+    shared_char kind = boost::shared_ptr<char>(new char[OWNAME]);
+    oss << "SELECT COORD_REF_SYS_KIND from MDSYS.SDO_COORD_REF_SYSTEM WHERE SRID = :1";
+    shared_long p_srid = boost::shared_ptr<long>(new long);
+    *p_srid = srid;
+    // p_srid[0] = srid;
+    statement->Bind(p_srid.get());
+    statement->Define(kind.get());
More information about the Liblas-commits mailing list
