[Liblas-devel] [liblas] Hello world
"Martín RV (OPENGeoMap)" martin at opengeomap.org
Wed Apr 9 14:28:50 EDT 2008
> Hi:
>> libLAS also sports a C API.  It is rather laborious and verbose to
>> use, but if C is your thing, it should fit the bill quite well.  See
>> the applications like lasinfo and txt2las to see how to use it.
> I see that hehe. You have many c++ skills hehe. This sounds like
> mozilla c++ binding to c hehe.
>> libLAS in known to build on gcc4+ (linux and osx) and msvc 2003/2005.
> mingw in the gcc windows native version. I want see if it´s posible
> compile your project in mingw :-[
> If you see Qt source code for example  it´s prepared for Mingw.
> Other projects like mysql or firefox use msvc also. I have a tool in
> mingw to convert DLLs to mingw. I used it to mysql and works fine.
>> libLAS started with Martin's library, and in fact, the command line
>> utilities like las2las and lasinfo in
>> http://liblas.org/browser/trunk/apps  are direct ports of his utilities.
>> We (well, Mateusz mostly) rewrote most of the internal library stuff
>> that actually handles manipulating the LAS format data, however.
>> The  major reason for this is that Martin's code was not really
>> organized  as a library that was expected to be embedded in other
>> applications.   There were no facilities for error handling other
>> than printf  statements, for example.  I think libLAS has a really
>> nice  architecture (Martin's library code was little more than some
>> structs)  and provides some great flexibility (working with
>> std::streams for  example).  I am quite satisfied with it.
> Yes I understood the fork.
>> BTW, libLAS is growing another API as we speak -- Python, which
>> builds  on the C API and uses Python's ctypes for a direct interface.
>> http://liblas.org/browser/trunk/python
> =-O  Great !!
> Ruby bindings would be nice 8-) .
> People talks very well about swig:
> http://www.swig.org/
>> Howard
> Regards.
More information about the Liblas-devel mailing list
