[Liblas-devel] libLAS 0.9.3 Released
Howard Butler hobu.inc at gmail.com
Fri Apr 11 02:36:18 EDT 2008
All,
I am pleased to announce the release of libLAS 0.9.3.  This release
focused on Python bindings and Python autotests for the library.  The
new Python bindings are located in ./python, and the Windows binaries
include a zip file and a .exe installer that can be installed in a
Python 2.5 installation.
To see how to use the Python bindings, take a look at the
doctests .txt files located in http://liblas.org/browser/trunk/python/tests
   They are built around the concept of a "file", much like the
LASFile interface, with some more Python sugar (like iterator support
so you can do 'for point in file:'.  I would like to add
__geo_interface__ support to them in the near future, but I thought I
would get them out there so people can test.
The only requirement to use the Python bindings is the ctypes library,
which is standard in 2.5+.  If you install your own copy of ctypes,
you should be able to use the bindings all the way back to Python
2.3.  I have only tested them on 2.5 in both OS X and Windows, however.
Other changes to the library include:
- Adding LASReader_GetPointAt to support fetching a point at any
location in the file
- Some tweaks to the windows makefiles
- Fix a copy/paste typo in LASPoint_GetFlightLineEdge (thanks Python
autotests)
http://liblas.org/wiki/0.9.3/
Howard
More information about the Liblas-devel mailing list
