[Liblas-devel] Throwing out_of_range exceptions on read
Mateusz Loskot mateusz at loskot.net
Sun Apr 27 18:52:23 EDT 2008
Howard Butler wrote:
> Mateusz,
> Mark in Florida has some 1.1 LAS files that have points with Scan
> Angle Ranks that are outside the -90/90 range that the specification
> says.
Hobu,
Seems, Mark's file does not follow the LAS specification.
Is that possible?
If yes, then I think it would be worth to know what's the generator of
such file and provide appropriate warning/comment in libLAS FAQ.
> I just commented out the check for now:
> http://liblas.org/browser/trunk/src/laspoint.cpp#L113
OK
> This begs the question, what do we do for reading invalid input?
I would prefer to keep validating it.
> Scan angle doesn't really mean too much, so for this case, following
> the spec exactly isn't going to be a deal, especially if there are
> other writers out there who aren't following. But for other items,
> especially the flags attributes, this is a big deal.
Your suggestion sounds reasonable to me. However, I'd like to propose
some modifications (below) :-)
> Any ideas on a reasonable tact to take?  Liberal in what we read and
> strict in what we write?
1. The ASPRS LAS format is suppose to be a data exchange format,
so we always must [sic] write in strict mode. IMHO, if LAS writers are
very  relaxed, then interoperability - a very principle of ASPRS LAS
format - will be on paper only.
2. I'd vote for libLAS reading in semi-relaxed mode by default, what
actually you are suggesting above, but in strict mode on request (a
configuration setting, a program parameter, etc.).
3. While reading LAS file in semi-relaxed, the library should always
print a warning to stdout.
How do you like it?
A general comment:
Hobu, as you've seen, when talking about standards, I always vote for
100% of strictness :-) However, I understand some aspects of standards
have different relevance, so less important things can be relaxed.
Greetings
Mateusz Loskot
http://mateusz.loskot.net
More information about the Liblas-devel mailing list
