[Liblas-devel] Throwing out_of_range exceptions on read
Howard Butler hobu.inc at gmail.com
Mon Apr 28 00:30:06 EDT 2008
On Apr 27, 2008, at 5:52 PM, Mateusz Loskot wrote:
> Howard Butler wrote:
>> Mateusz,
>> Mark in Florida has some 1.1 LAS files that have points with Scan
>> Angle Ranks that are outside the -90/90 range that the specification
>> says.
> Hobu,
> Seems, Mark's file does not follow the LAS specification.
> Is that possible?
Yes, I agree.  I think the file is out of spec.
> If yes, then I think it would be worth to know what's the generator of
> such file and provide appropriate warning/comment in libLAS FAQ.
The offending software writes 1.1 files with the following:
   Project ID/GUID:           '00000000-0000-0000-0000-000000000776'
   System Identifier:         'NIIRS10'
   Generating Software:       'LIDAR1 tiled'
>> I just commented out the check for now:
>> http://liblas.org/browser/trunk/src/laspoint.cpp#L113
> OK
>> This begs the question, what do we do for reading invalid input?
> I would prefer to keep validating it.
I don't know that we can keep validating it *where* we validate
currently -- in the getter/setter methods of LASPoint.
Maybe we could have something like
-- ReadNextPoint(bool validate)
-- if (validate) {LASPoint::validate();}
and have LASPoint::validate toss an exception.  This way we can do it
on write as well.  I'm not sure out_of_range is the best exception to
throw either.
Some things that might be good candidates for validate():
  - Invalid time values
  - Scan angle rank
  - flight edge not being 1 or 0
  - invalid classifcation values
  - invalid scan direction
>> Scan angle doesn't really mean too much, so for this case, following
>> the spec exactly isn't going to be a deal, especially if there are
>> other writers out there who aren't following. But for other items,
>> especially the flags attributes, this is a big deal.
> Your suggestion sounds reasonable to me. However, I'd like to
> propose some modifications (below) :-)
>> Any ideas on a reasonable tact to take?  Liberal in what we read and
>> strict in what we write?
> 1. The ASPRS LAS format is suppose to be a data exchange format,
> so we always must [sic] write in strict mode. IMHO, if LAS writers
> are very  relaxed, then interoperability - a very principle of ASPRS
> LAS format - will be on paper only.
Such is the fallacy of all standards :)  I think we should have
LASWriter do validate() on write, and we should not allow folks to
circumvent this with a flag.  It adds a few checks and might cost some
raw write performance, but it is just pushing the existing test that
lives in the LASPoint methods around so it isn't a net gain or loss in
performance.
> 2. I'd vote for libLAS reading in semi-relaxed mode by default, what
> actually you are suggesting above, but in strict mode on request (a
> configuration setting, a program parameter, etc.).
For read operations, I think we should have a flag that allows you to
use relaxed reading, but we should default to validate() on read as
well, IMO.  For translation operations like las2las, this might mean
throwing out points that aren't to spec, because write() isn't going
to allow it.  I would have las2las provide summary in that instance.
The only way to get people to write files in spec are to tell them
they're writing it out of spec :)  Also, I would venture a guess that
libLAS is the first LAS format library out there to really care about
validating the parts of the base spec we implement.
> 3. While reading LAS file in semi-relaxed, the library should always
> print a warning to stdout.
I have changed all of the utilities to emit text output to stderr
because stdin/stdout can be used for regular file i/o for some of
them.  IMO, the library shouldn't print error messages anywhere, and
it should notify the application that there's an error or warning and
let it decide what to do.  I already have stuff in the C API's error
handling to be able to deal with this, I think.
Anyone else with thoughts on this issue, please chime in.  I don't
want to box folks in because a lot of times you don't control who's
giving you LAS files to deal with.  On the other hand, I don't want to
perpetuate crappy broken data either...
Howard
More information about the Liblas-devel mailing list
