[Liblas-devel] RE: Building the .net/mono bindings
Martin Rodriguez mrodriguez at stereocarto.com
Mon Aug 18 02:20:42 EDT 2008
Hi:
Is it mandatory this??
I don´t know use autotools. I try it, but finally I can not. In my work I
used rake (only for ruby), rant, scons and waf. Someone of this tools can be
used?
I don´t know NMAKE neither. Can we find other tools?
Perhaps ruby tools are not suitable, but tools based in python I think coulb
be valid because in all linux distributions python come installed and in
windows is easy to install. Besides with arc gis python is installed by
default.
Regards.
-----Mensaje original-----
De: Howard Butler [mailto:hobu.inc at gmail.com]
Enviado el: Friday, August 15, 2008 5:30 AM
Para: liblas-devel at mail.hobu.net
CC: Martin Rodriguez
Asunto: Building the .net/mono bindings
Martin,
libLAS officially supports autotools for *nix and nmake for windows as
build environments.  Any code that is committed will need to build
with both of these tools in order to be included in any binary
distributions that will be made (I currently plan to target OSGeo4W
for a Windows build and let the *nix packagers pick up the library for
any other distributions).  Additionally, *I* will not support msvc
project files, so if a user came with a build complaint, I would
immediately forward it to you.
Please write a makefile.vc file similar to the GDAL one for the C#
bindings
<http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/makefile.vc
 > and place it in the csharp directory.  You can see that this
makefile uses csc to build the c# components, uses sn to sign the dll,
and defines the linkage between the bindings dlls (pinvoke stuff) and
the pure C# code.  Please move your project file that is currently in
the csharp directory to the build/msvc80 directory and include it in
the project(s) there as appropriate.  Make sure to test that
everything builds correctly before committing any code.
If you are not a linux developer, I can help with the autotools
stuff.  Let me know.
Howard
More information about the Liblas-devel mailing list
