[Liblas-devel] Number of points by return
Mateusz Loskot mateusz at loskot.net
Wed Jan 2 10:35:37 EST 2008
Kollasch, Pete [DNR] wrote:
> That rule is fully consistent with my understanding of how LiDAR data
> works.
Pete,
Thanks for confirmation.
> The only reason I would hesitate to assume it as a rule would be if
> making the assumption would cause reading data from a broken data set to
> fail.  If using the assumption causes a failure to read an inconsistent
> dataset, that's not very robust.
Yes, I agree with your opinion.
Perhaps only warning should be issued if verbose mode requested,
so user is well-informed.
Best regards
Mateusz Loskot
http://mateusz.loskot.net
More information about the Liblas-devel mailing list
