[Liblas-devel] 0.9.0 Released
Howard Butler hobu.inc at gmail.com
Mon Mar 17 11:21:21 EDT 2008
Pete,
I have released a new version that should fix las2las and also
txt2las.  Please give it a test when you get a chance.
Thanks,
Howard
On Mar 5, 2008, at 2:03 PM, Kollasch, Pete [DNR] wrote:
> Howard,
> I have done some further checking of the liblas command line
> utilities,
> with results similar to before.  I have yet to succeed in getting a
> data
> file out of the las2las command that has more than header data in
> it.  I
> have tried a huge variety of command line options (-, --, etc.),
> with no
> success.
> I am confused by the difference between the counts by return as
> shown in
> the header and as shown by the check option of lasinfo.  When I do
> las2las the first stage completes, and gives information about how
> many
> points were removed -- the numbers generally seems to agree well with
> the counts from the header.
> Have tried lots of other options, that seem to work well.
> I will be out of the office virtually all of next week.
> Pete.
> -----Original Message-----
> From: liblas-devel-bounces at mail.hobu.net
> [mailto:liblas-devel-bounces at mail.hobu.net] On Behalf Of Howard Butler
> Sent: Tuesday, February 26, 2008 4:18 PM
> To: liblas-devel at mail.hobu.net
> Subject: [Liblas-devel] 0.9.0 Released
> All,
> I am pleased to announce the release of 0.9.0.  A tarball with a
> source release and Windows binaries are provided.  See
> http://liblas.org/wiki/0.9.0
>  to download a copy.
> The utility of the release is pretty much limited to library work if
> you are a software developer, or Martin's command line utilities.
> Documentation for the command line utilities can be found in
> http://liblas.org/browser/tags/0.9.0/doc
>  or by adding the --help switch to the utility.
> Howard
> Liblas-devel mailing list
> Liblas-devel at mail.hobu.net
> http://mail.hobu.net/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
