[Liblas-devel] liblas and gdal
Mateusz Loskot mateusz at loskot.net
Sat Mar 15 17:00:21 EDT 2008
creta kano wrote:
> The use case for liblas and gdal is that gdal would be able to read,
> write, and subset las files in its native format.  Gdal should be
> able to also read and write metadata from a las file.  Gdal should be
> be able to convert a las file to gridded coverage such as geotiff to
> support a preview of the data.
Sophia,
Thank you for these specification.
In near future, there is a plan to implement libLAS driver for GDAL.
In the meantime, we've started implementation of simple utility -
las2ogr based on Matthew Perry's pylas.py script
http://liblas.org/browser/trunk/apps/las2ogr.cpp
This program will provide users with ability to do following:
1. Convert LAS file to Shapefile
2. Interpolate cloud of points stored in Shapefile to raster
    using gdal_grid (http://gdal.org/gdal_grid.html)
I understand this is not exactly what you are describing, but I think it
might be somewhat helpful.
All your comments are very in place and will help us to implement these
feature. Howard is away for a few days, but I'm sure he will reply with
more detailed plan when he is back.
Greetings
Mateusz Loskot
http://mateusz.loskot.net
More information about the Liblas-devel mailing list
