[Liblas-devel] GPS time and intensity?
Jason.Woolard at noaa.gov Jason.Woolard at noaa.gov
Sun Oct 12 09:21:42 EDT 2008
Thanks Mateusz. Most of the LAS files I've seen have more precision than to the nearest second. I guess whether it's needed or not depends on what you are doing.
I just checked one of the sample LAS files and it has GPS time data out to 6 decimal places.
Just wanted to check on that since my input gps time wasn't matching my gps output time.
----- Original Message -----
Date: Sunday, October 12, 2008 7:09 am
Subject: Re: [Liblas-devel] GPS time and intensity?
To: Jason Woolard <Jason.Woolard at noaa.gov>
Cc: liblas-devel at mail.hobu.net
> Jason Woolard pisze:
> > Two more quick questions. I can't seem to pull the intensity from a
> LAS
> > file. The documentation shows intensity in the LASPoint class. Has
> that
> > been implemented? I'm getting a Traceback error in Python 2.5 with
> > intensity while x,y,z return_number and classification are all
> coming
> > across fine.
> Jason,
> I'm not an expert of the bindings for Python but as I see, intensity
> getter/setter is missing:
> Let's wait for Howard to confirm.
> > Also, the GPS time seems to be rounding to the nearest second . My
> input
> > file has data to 3 decimal places. Is there any way to carry that
> > precision over?
> As I can tell from what I see in the code, get_time method returns 8
> elements of struct_time (range [0:7]). All these elements are integers
> and number of seconds is represented as integer. By the nature of
> functions like localtime, gmtime, etc. fractions of second is lost.
> Aren't LiDAR observations (pulses) measured in seconds with fractions
> ignored?
> Best regards,
> Mateusz Loskot,
> Charter Member of OSGeo,
More information about the Liblas-devel mailing list
