[Liblas-devel] GPS time and intensity?
Jason Woolard Jason.Woolard at noaa.gov
Mon Oct 13 20:34:14 EDT 2008
The time update seems to be working fine with my files but I was able to
raise an error with the sample Serpent_Mound_Model_LAS_Data.las file
from Martin's site.
The error is:
File "C:\Python25\lib\site-packages\liblas\point.py", line 185, in get_time
    return datetime.datetime(lt[0],lt[1],lt[2],lt[3],lt[4],lt[5],ms)
ValueError: microsecond must be in 0..999999
The Serpent LAS sample does have data to 6 decimal places while my files
only have data to three places. Other than that the files seem to be the
same.
Howard Butler wrote:
> On Oct 13, 2008, at 1:13 PM, Jason Woolard wrote:
>> On the GPS time issue, I think it's definitely important to have more
>> precision than the nearest second. The GPS/Inertial or trajectory
>> data is usually measured at ~200 Hz and one of the useful things
>> about having the GPS time stamp is the ability to match up a
>> particular pulse with the corresponding time in the vehicle
>> trajectory or scanner angle data. Commercial topographic lidar
>> systems are now pulsing at 100 kHz + so having the times rounded to a
>> second would mean you could potentially have 100,000 points or more
>> with identical times. In addition, the time stamp will be even more
>> important as laser waveform data becomes more mainstream.
> Jason,
> After thinking about this a bit, I think the problem is just related
> to the Python bindings throwing out the fractional seconds.  I took a
> crack at fixing this in the Python bindings
> http://liblas.org/changeset/945
> Here's a ticked to track the changes:
> http://liblas.org/ticket/83
> If you could use subversion to build from trunk or the 1.0 branch and
> test that things are behaving correctly, it would be greatly appreciated.
> Thanks,
> Howard
More information about the Liblas-devel mailing list
