[Liblas-devel] GPS time and intensity?
Howard Butler hobu.inc at gmail.com
Mon Oct 13 15:04:53 EDT 2008
On Oct 13, 2008, at 1:13 PM, Jason Woolard wrote:
> On the GPS time issue, I think it's definitely important to have
> more precision than the nearest second. The GPS/Inertial or
> trajectory data is usually measured at ~200 Hz and one of the useful
> things about having the GPS time stamp is the ability to match up a
> particular pulse with the corresponding time in the vehicle
> trajectory or scanner angle data. Commercial topographic lidar
> systems are now pulsing at 100 kHz + so having the times rounded to
> a second would mean you could potentially have 100,000 points or
> more with identical times. In addition, the time stamp will be even
> more important as laser waveform data becomes more mainstream.
Jason,
After thinking about this a bit, I think the problem is just related
to the Python bindings throwing out the fractional seconds.  I took a
crack at fixing this in the Python bindings
http://liblas.org/changeset/945
Here's a ticked to track the changes:
http://liblas.org/ticket/83
If you could use subversion to build from trunk or the 1.0 branch and
test that things are behaving correctly, it would be greatly
appreciated.
Thanks,
Howard
More information about the Liblas-devel mailing list
