[Liblas-devel] liblas problems
Howard Butler hobu.inc at gmail.com
Tue Oct 28 00:38:30 EDT 2008
On Oct 23, 2008, at 9:47 AM, Martin Vales wrote:
> Hi:
> today Roberto Antolin and me are working with liblas for first time
> with c++ and .NET. We found several problems with c++ and C APIs:
> - CAPI not exposed in windows. I am using the mateus compilation and
> mi mingw compilation.
> I tried use this file but don´t have the CAPI or i can not see it:
> http://liblas.org/raw-attachment/wiki/1.0.0/liblas-1.0.0-win32.zip
When I look at this file with depends.exe, I can see the C API entry
points.  The liblas_i contains the implib for liblas.  Is this what
you are looking for?
> - CAPI GetPointAt always the same pointer:
Mateusz,
This makes sense right?  &(reader->GetPoint()) is going to get the
address of the reader's current point?   The Python API uses
GetPointAt (C API) and it seems to work ok.
> LAS_DLL const LASPointH LASReader_GetPointAt(const LASReaderH
> hReader, liblas::uint32_t position)
> 291            LASReader *reader = ((LASReader*) hReader);
> 292            if (reader->ReadPointAt((std::size_t) position))
> 294                return (LASPointH) &(reader->GetPoint());
More information about the Liblas-devel mailing list
