[Liblas-devel] /GR and /Zi in nmake.opt
Erik Jacobsen jacobsen at powline.com
Thu Sep 25 14:25:56 EDT 2008
Hello Howard,
With respect to /GR, I appreciate the explanation for why it is the way
it is.  I'll live with it, but you might want to put a comment in
nmake.opt stating that you are using a nonstandard calling convention
and removing /GR should be the first thing tried to resolve linker errors.
/Z7 predates /Zi (.pdb) so it will be available in compilers prior to
MSVC 7.1.  MSDN actually suggests using it for libraries:
http://msdn.microsoft.com/en-us/library/958x11bc(VS.80).aspx
Erik
On 9/25/2008 13:19, Howard Butler wrote:
> On Sep 25, 2008, at 1:06 PM, Erik Jacobsen wrote:
>> Hello Mateusz,
>> Thank you for looking at that so quickly.  As long as I am making
>> suggestions, I have two more both relating to building with MSVC
>> version 9, SP1 using makefile.vc and nmake.opt:
>> 1) Please consider removing /GR from OPTFLAGS.  Using a non-default
>> calling convention produces somewhat puzzling linker errors when
>> attempting to statically link against libLas.
> IIRC, I needed /GR to be able to link libLAS against the OSGeo4W GDAL
> and GeoTIFF DLLs.  Static linkage of libLAS is not our typical usage
> scenario.  Please consider registering for the wiki and creating a
> page that describes how to build libLAS statically for those
> interested...  Because I want to be able to easily generate official
> libLAS windows releases targeted at OSGeo4W using msvc 7.1/8, I don't
> see us removing /GR.
>> 2) Please consider using /Z7 for debug info in OPTFLAGS instead of
>> /Zi.  /Z7 produces C7 style debugging information which is directly
>> embedded in the library eliminating the need for a separate .pdb file.
> Does /Z7 work for msvc 7.1/8 as well?  It would be wonderful to have a
> -g like option instead of those damn .pdb files everywhere.
> Howard
Erik Jacobsen, Power Line Systems, Inc.
Email: jacobsen at powline.com
Phone: (608) 238-2171 x104
Fax:   (608) 238-9241
Web:   http://www.powline.com/
More information about the Liblas-devel mailing list
