[Liblas-devel] .NET bindings and Beta3
Howard Butler hobu.inc at gmail.com
Mon Sep 29 23:54:35 EDT 2008
Steve,
The .NET bindings are available if you are building from source, but
because there is no NMAKE file or GNU automake stuff, it will not be
available in the Windows builds that I make.  There's nothing from
preventing you from using it, however, as long as you are able to
build things on your own.
Martin,
I think time is quickly running out on getting the .NET building stuff
completed in time for 1.0.0 final -- at least nmake or automake
support that works in such a way that I include the bindings in any
packaging efforts I undertake.  You could always make a libLAS .NET
bindings release and attach it to the 1.0.0 release page as a .zip
file.  Maybe that solution would be sufficient for most folks.
All,
Unless I hear otherwise in the next couple of days, I plan to release
1.0.0 final the end of this week.
Howard
On Sep 29, 2008, at 9:48 PM, Steve Harwin wrote:
> Hi,
> Thanks for your prompt reply Martin,  I will hold off a little while
> longer then and give a chance to complete your tests.
> My main first step will be to use the LASReader to read in a LAS
> file.  Writing can come later.
> "WRT" means "with respect to".
> I will watch this list to see when the .NET bindings are in a state
> that you feel is sufficient for me to get started on my integration.
> Thanks
> Steve
> -----Original Message-----
> From: Martin (OpenGeoMap) [mailto:martin at opengeomap.org]
> Sent: Monday, 29 September 2008 5:45 PM
> To: Steve Harwin
> Cc: liblas-devel at mail.hobu.net
> Subject: Re: [Liblas-devel] .NET bindings and Beta3
> Hi:
>> Hi,
>> What was the final decision WRT the .NET bindings that Martin was
>> working on?  I have been eagerly awaiting Beta3 as I thought it would
>> include what I need to integrate libLAS into my .NET app.  Did I miss
>> something?  Should I build from source?
> What WRT is????.
> In my job i use visual studio 2008 pro, but like you see i add a
> visual
> 2005 xpress solution to be more permisive with people.
> Compile is very easy in this way.
> Like you know monodevelop and visual studio now share the MSBuild
> system
> and therefore you can compile it in linux also.
> http://www.monodevelop.com/Release_notes_for_MonoDevelop_2.0_Alpha_1#MSBuild_File_format
> You can compile with MSBuild by console.
> http://msdn.microsoft.com/en-us/magazine/cc163589.aspx
> To compile the dotnet bindings you don´t need liblas support but  you
> will need add to the same folder than dotnet bindings the native
> library
> if you want work....
> I am trying use the same system than proj.NET,  sharpmap or  math.NET
> but we need add support to autotools and NMake.
> In the source code you have a CAPI.cs file. In this file you need
> modify
> the line where you write the .DLL name for every liblas version.
>> I have previously used LASTools and found it very helpful, so libLAS
>> via c# would be even better.
> c# rocks!!!
>> Thanks for all your efforts, once libLAS is integrated into Eonfusion
>> we will be able to do a thorough test and I will let you know of any
>> issues.
> Yesterday i was working in the bindings to complete mateus test with
> NUNIT. I don´t believe by now you can do many things because i am
> doing
> some changes in the API.
> Liblas have much more work done than me because the C++ API have
> more time.
> This week i hope have a nice screenshot with my complete NUNIT in
> green
> color ;-) .
>> Steve
>> *Steve Harwin*
>> Senior Software Engineer
>> Eonfusion & Landscape Mapper
>> Myriax Pty Ltd
>> GPO Box 1387
>> Hobart Tas 7001
>> Australia
>> Tel: +61 3 6231 5588
>> Fax: +61 3 6234 1822
>> E-mail: steveh at myriax.com <mailto:steveh at myriax.com>
>> http://www.eonfusion.myriax.com
>> http://www.landscapemapper.com
>> http://www.myriax.com
>> Liblas-devel mailing list
>> Liblas-devel at mail.hobu.net
>> http://mail.hobu.net/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
