Fwd: [Liblas-devel] txt2las - psid only 1 byte?
Volker Wichmann wichmann at laserdata.at
Mon Jun 8 03:56:43 EDT 2009
I just did a fresh svn checkout (trunk, rev. 1294) and get an error from
configure:
checking for debug enabled... no
checking for GDAL... no
checking for libgeotiff... no
checking for spatialindex RTree.h... no
checking for libspatialindex... no
./configure: line 21461: syntax error near unexpected token
`$ORACLE_OCI_REQ_VERSION'
./configure: line 21461: `AX_LIB_ORACLE_OCI($ORACLE_OCI_REQ_VERSION)'
Any help appreciated,
Volker
Volker Wichmann wrote:
> Howard,
> thanks for taking a look and applying a fix. I will report back next
> week as soon as I have build a version from trunk.
> Volker
> Howard Butler wrote:
>> oops, forgot to CC the list.
>> Begin forwarded message:
>>> From: Howard Butler <hobu.inc at gmail.com>
>>> Date: June 5, 2009 10:27:20 AM CDT
>>> To: Volker Wichmann <wichmann at laserdata.at>
>>> Subject: Re: [Liblas-devel] txt2las - psid only 1 byte?
>>> On Jun 5, 2009, at 4:48 AM, Volker Wichmann wrote:
>>>> Hi,
>>>> I have troubles converting an ASCII file with point source ids >
>>>> 254 to LAS 1.1 using the txt2las tool (version 1.2.0b3). It seems
>>>> to me, that the point source id is not written as unsigned short
>>>> (2  bytes) but as unsigned char (1 byte) resulting psid=0. Is
>>>> anybody  experiencing the same problem?
>>> I have filed a ticket on this item.  Please continue to track its
>>> development and improvement there (register for the site if you
>>> haven't already).  I have applied what I think is the fix to trunk
>>> if you have opportunity to build that.
>>> http://liblas.org/ticket/139
>>>> PS: I obtain correct results using the old lastools txt2las from
>>>> Martin Isenburg
>>> I so very wish I could make a convincing case to Martin to have him
>>> base his LAStools on libLAS.  I have tried very, very hard to do
>>> so,  but I can't seem to make a compelling case.  It is unfortunate
>>> that  we maintain essentially a fork of his utilities that have
>>> different  capabilities than his.
>> Liblas-devel mailing list
>> Liblas-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
