[Liblas-devel] Small autoconf patch for Fedora
Howard Butler hobu.inc at gmail.com
Tue Nov 24 09:20:13 EST 2009
On Nov 24, 2009, at 7:20 AM, Mike Grant wrote:
> Fedora* puts libgeotiff's include files in /usr/include/libgeotiff/ and the libraries in /usr/lib{64}/.  The current configure script doesn't check for this (slightly odd) possibility, so I made a tiny change to configure.ac.  The following then works:
> ./configure --with-gdal --with-geotiff=/usr/
> Patch against trunk attached.
> Cheers,
> Mike Grant.
> * tested on Fedora 10, not got 11 or 12 to check.  Downloading a 12 and will confirm later..
Thanks!  I will apply this to the main branch today.
Howard
More information about the Liblas-devel mailing list
