[Liblas-devel] invalid point(s)
Mateusz Loskot mateusz at loskot.net
Tue Sep 29 10:22:28 EDT 2009
M S wrote:
> Greetings All.  Thanks for such a great set of tools.
> In processing some .las files, they range from year 2004 to 2006.  All
> the 2004 and 2005 tiles ran without issue (from what I can tell at
> this point), but when it gets to the year 2006 data, I get the
> following error.
> "Not able to fetch point:  Failed to write point because it was
> invalid (2) from from method LASWriter_WritePoint"
> It occurs while eliminating a class called "Unclassified" from the
> original .las file.
> I'm running version 1.2.0.
It sounds like a problem specific to data you're processing.
Any chance to provide us with sample file so we can try to
reproduce the problem?
Also, please verify if you're suffering of this known issue:
http://liblas.org/ticket/147
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
More information about the Liblas-devel mailing list
