[Liblas-devel] Extracting specific classes with Python
Howard Butler hobu.inc at gmail.com
Tue Sep 29 12:15:31 EDT 2009
All,
A user requested that las2las have options to extract specific classes
into a new file rather than using the elimination approach that it
currently uses.  Unfortunately, the new release won't be out for a
while, and because las2las tracks Martin's tools, I'm a bit hesitant
to start adding lots of divergent options.  One thing libLAS has that
LAStools doesn't is Python bindings, however, and this task is quite
simple in Python.
http://liblas.org/wiki/PyExtractClass
The following command line invocation would use the above script to
extract classifications 1 and 2 from the input.las file to the
output.las file...
python grab_classes.py --input input.las --output output.las  --
classifications 1,2
Enjoy,
Howard
More information about the Liblas-devel mailing list
