[Liblas-devel] Problems on the libLAS Compilation
Howard Butler hobu.inc at gmail.com
Tue Jul 27 17:24:36 EDT 2010
As the warning in red right below the author info says on the Compilation document, that document is only for the unreleased libLAS 1.6 code.  No document currently exists for the 1.2.1 release, although there are a makefile.vc and nmake.opt files you can use to build that version on windows with.
Howard
On Jul 27, 2010, at 3:41 PM, ping yang wrote:
> Hi, I followed the link:http://liblas.org/compilation.html#using-visual-studio-9-2008-on-windows for the compilation 'Using “Visual Studio 9 2008” on Windows"', I am not sure about the first step, 'Get the source code", actually, I went to the Repository to downloaded the "main" zip file, and I also went to current Release and downloaded liblas-src-1.2.1.tar.gz (md5) , I am confused with these two files because when I ran the cmake-gui, there was an input parameter  "Where is the source code" , I have tried several times, when I used the uncompressed file from liblas-src-1.2.1.tar.gz (md5), there was an CMake error : The source directory " E:/Sourcecode" does not appear to contain CMakeLists.txt. However. when I use the uncompressed file form "Main", another error came up with"Error in configuration process, projects files may be invalid". there comes my question, have someone else have check the procedure that described in the Compilation section? Is there anyone can help me to compile the source code and get the reference file name LibLAS which can be referenced for application( like the "hello world" in the c# Tutorial). _______________________________________________
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
