[Liblas-devel] Building with cmake/nmake - spatial reference failure
Wes Toews wolfsnipes at gmail.com
Tue Mar 16 02:32:52 EDT 2010
hi, I obtained today the GDAL and Geotiff libraries from OSGeo4w, and am
trying to link in the spatial referencing component but of course it bails.
The liblas source was obtained from mercurial today as well, so everything
is as current as it can be (fingers crossed?)
System is Windows XP, 32 bit. Compiling VS2008 from command line.
issuing "cmake -DWITH_GDAL=OFF" then "nmake" creates a successful build
issuing "cmake -DWITH_GDAL=ON -DWITH_GEOTIFF=ON" creates a makefile
succesfully but bails when issuing the nmake build command.
The cmake environment variables I've set as such, if you need any more let
me know.  The nmake feed is copied below.
//Path to a file GDAL_INCLUDE_DIR-NOTFOUND
GDAL_INCLUDE_DIR:PATH=C:/OSGeo4w/apps/gdal-16/include
//Path to a library GDAL_LIBRARY-NOTFOUND
GDAL_LIBRARY:FILEPATH=C:/OSGeo4w/apps/gdal-16/lib/gdal_i.lib
//Path to a file.
GEOTIFF_INCLUDE_DIR:PATH=C:/OSGeo4w/include
//Path to a library.
GEOTIFF_LIBRARY:FILEPATH=C:/OSGeo4w/lib/geotiff_i.lib
//Path to a file PATH=TIFF_INCLUDE_DIR-NOTFOUND
//Path to a library TIFF_LIBRARY-NOTFOUND
TIFF_LIBRARY:FILEPATH=C:/OSGeo4w/lib/libtiff_i.lib
...and this is the nmake feed, any ideas?
C:\Liblas\main>nmake
Microsoft (R) Program Maintenance Utility Version 9.00.30729.01
Copyright (C) Microsoft Corporation.  All rights reserved.
Scanning dependencies of target las
[  3%] Building CXX object src/CMakeFiles/las.dir/lasclassification.cpp.obj
cl : Command line warning D9025 : overriding '/W3' with '/W4'
[  6%] Building CXX object src/CMakeFiles/las.dir/lascolor.cpp.obj
lascolor.cpp
[  9%] Building CXX object src/CMakeFiles/las.dir/laserror.cpp.obj
laserror.cpp
[ 12%] Building CXX object src/CMakeFiles/las.dir/lasformat.cpp.obj
lasformat.cpp
C:\Liblas\main\include\liblas/lasformat.hpp(111) : warning C4244: '=' :
conversi
on from 'const liblas::uint32_t' to 'liblas::uint16_t', possible loss of
data
C:\Liblas\main\src\lasformat.cpp(68) : warning C4244: 'initializing' :
conversio
n from 'liblas::uint32_t' to 'liblas::uint16_t', possible loss of data
C:\Liblas\main\src\lasformat.cpp(83) : warning C4244: 'initializing' :
conversio
[ 15%] Building CXX object src/CMakeFiles/las.dir/lasheader.cpp.obj
lasheader.cpp
c:\osgeo4w\include\geo_config.h(6) : warning C4005: 'STDC_HEADERS' : macro
redef
inition
        c:\osgeo4w\apps\gdal-16\include\cpl_config.h(27) : see previous
definiti
on of 'STDC_HEADERS'
conversi
data
C:\Liblas\main\src\lasheader.cpp(714) : warning C4244: 'argument' :
conversion f
rom 'const liblas::uint32_t' to 'liblas::uint16_t', possible loss of data
C:\Liblas\main\src\lasheader.cpp(717) : warning C4244: 'argument' :
conversion f
C:\Liblas\main\src\lasheader.cpp(720) : warning C4244: 'argument' :
conversion f
C:\Liblas\main\src\lasheader.cpp(723) : warning C4244: 'argument' :
conversion f
[ 18%] Building CXX object src/CMakeFiles/las.dir/laspoint.cpp.obj
laspoint.cpp
redef
inition
definiti
[ 21%] Building CXX object src/CMakeFiles/las.dir/lasreader.cpp.obj
lasreader.cpp
redef
inition
definiti
conversi
data
C:\Liblas\main\src\lasreader.cpp(104) : warning C4101: 'e' : unreferenced
local
variable
C:\Liblas\main\src\lasreader.cpp(116) : warning C4101: 'e' : unreferenced
local
variable
[ 25%] Building CXX object
src/CMakeFiles/las.dir/lasspatialreference.cpp.obj
redef
inition
definiti
C:\Liblas\main\src\lasspatialreference.cpp(371) : warning C4100: 'mode_flag'
: u
nreferenced formal parameter
c:\liblas\main\src\lasspatialreference.cpp(552) : warning C4702: unreachable
cod
e
[ 28%] Building CXX object src/CMakeFiles/las.dir/lasvariablerecord.cpp.obj
[ 31%] Building CXX object src/CMakeFiles/las.dir/laswriter.cpp.obj
laswriter.cpp
redef
inition
definiti
[ 34%] Building CXX object
src/CMakeFiles/las.dir/detail/reader/header.cpp.obj
header.cpp
redef
inition
definiti
[ 37%] Building CXX object
src/CMakeFiles/las.dir/detail/reader/point.cpp.obj
point.cpp
redef
inition
definiti
conversi
data
[ 40%] Building CXX object
src/CMakeFiles/las.dir/detail/reader/reader.cpp.obj
reader.cpp
redef
inition
definiti
conversi
data
[ 43%] Building CXX object src/CMakeFiles/las.dir/detail/writer/base.cpp.obj
base.cpp
redef
inition
definiti
[ 46%] Building CXX object
src/CMakeFiles/las.dir/detail/writer/header.cpp.obj
header.cpp
redef
inition
definiti
[ 50%] Building CXX object
src/CMakeFiles/las.dir/detail/writer/point.cpp.obj
point.cpp
redef
inition
definiti
conversi
data
[ 53%] Building CXX object
src/CMakeFiles/las.dir/detail/writer/writer.cpp.obj
writer.cpp
redef
inition
definiti
C:\Liblas\main\src\detail\writer\writer.cpp(193) : warning C4100: 'header' :
unr
[ 56%] Building CXX object src/CMakeFiles/las.dir/gt_citation.cpp.obj
gt_citation.cpp
redef
inition
definiti
c:\liblas\main\src\gt_citation.cpp(196) : warning C4706: assignment within
condi
tional expression
[ 59%] Building CXX object src/CMakeFiles/las.dir/gt_wkt_srs.cpp.obj
gt_wkt_srs.cpp
redef
inition
definiti
C:\Liblas\main\src\gt_wkt_srs.cpp(724) : warning C4244: '=' : conversion
from 'i
nt' to 'short', possible loss of data
C:\Liblas\main\src\gt_wkt_srs.cpp(751) : warning C4244: '=' : conversion
from 'i
[ 62%] Building CXX object src/CMakeFiles/las.dir/tifvsi.cpp.obj
tifvsi.cpp
Linking CXX static library ..\bin\Debug\las.lib
[ 62%] Built target las
Scanning dependencies of target las_c
[ 65%] Building CXX object src/CMakeFiles/las_c.dir/las_c_api.cpp.obj
las_c_api.cpp
redef
inition
definiti
conversi
data
C:\Liblas\main\src\las_c_api.cpp(210) : warning C4297: 'OpenInput' :
function as
sumed not to throw an exception but does
        The function is extern "C" and /EHc was specified
C:\Liblas\main\src\las_c_api.cpp(746) : warning C4244: '=' : conversion from
'un
signed int' to 'liblas::uint16_t', possible loss of data
C:\Liblas\main\src\las_c_api.cpp(2073) : warning C4800: 'liblas::uint8_t' :
forc
ing value to bool 'true' or 'false' (performance warning)
C:\Liblas\main\src\las_c_api.cpp(2074) : warning C4800: 'liblas::uint8_t' :
forc
C:\Liblas\main\src\las_c_api.cpp(2138) : warning C4800: 'liblas::uint8_t' :
forc
C:\Liblas\main\src\las_c_api.cpp(2162) : warning C4800: 'liblas::uint8_t' :
forc
Linking CXX shared library ..\bin\Debug\las_c.dll
   Creating library ..\bin\Debug\las_c.lib and object ..\bin\Debug\las_c.exp
las.lib(gt_wkt_srs.cpp.obj) : error LNK2019: unresolved external symbol
__imp__s
trnicmp referenced in function _GTIFGetOGISDefn
las.lib(gt_citation.cpp.obj) : error LNK2001: unresolved external symbol
__imp__
strnicmp
__imp__s
tricmp referenced in function _GTIFGetOGISDefn
__imp__
stricmp
..\bin\Debug\las_c.dll : fatal error LNK1120: 2 unresolved externals
LINK Pass 1 failed. with 1120
NMAKE : fatal error U1077: '"C:\Program Files\CMake 2.8\bin\cmake.exe"' :
return
 code '0xffffffff'
Stop.
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
9.0\VC\BIN
\nmake.exe"' : return code '0x2'
Stop.
9.0\VC\BIN
Stop.
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20100315/09552f87/attachment-0001.html
More information about the Liblas-devel mailing list
