[Liblas-devel] Building with cmake/nmake - spatial reference failure
Howard Butler hobu.inc at gmail.com
Tue Mar 16 16:10:19 EDT 2010
Wes,
If you pull down the latest, I think I have fixed this issue (along with cleaning up many warnings).
Howard
On Mar 16, 2010, at 1:32 AM, Wes Toews wrote:
> hi, I obtained today the GDAL and Geotiff libraries from OSGeo4w, and am trying to link in the spatial referencing component but of course it bails.  The liblas source was obtained from mercurial today as well, so everything is as current as it can be (fingers crossed?)
> System is Windows XP, 32 bit. Compiling VS2008 from command line.
> issuing "cmake -DWITH_GDAL=OFF" then "nmake" creates a successful build
> issuing "cmake -DWITH_GDAL=ON -DWITH_GEOTIFF=ON" creates a makefile succesfully but bails when issuing the nmake build command.
> The cmake environment variables I've set as such, if you need any more let me know.  The nmake feed is copied below.
> //Path to a file GDAL_INCLUDE_DIR-NOTFOUND
> GDAL_INCLUDE_DIR:PATH=C:/OSGeo4w/apps/gdal-16/include
> //Path to a library GDAL_LIBRARY-NOTFOUND
> GDAL_LIBRARY:FILEPATH=C:/OSGeo4w/apps/gdal-16/lib/gdal_i.lib
> //Path to a file.
> GEOTIFF_INCLUDE_DIR:PATH=C:/OSGeo4w/include
> //Path to a library.
> GEOTIFF_LIBRARY:FILEPATH=C:/OSGeo4w/lib/geotiff_i.lib
> //Path to a file PATH=TIFF_INCLUDE_DIR-NOTFOUND
> //Path to a library TIFF_LIBRARY-NOTFOUND
> TIFF_LIBRARY:FILEPATH=C:/OSGeo4w/lib/libtiff_i.lib
> ...and this is the nmake feed, any ideas?
> C:\Liblas\main>nmake
> Microsoft (R) Program Maintenance Utility Version 9.00.30729.01
> Copyright (C) Microsoft Corporation.  All rights reserved.
> Scanning dependencies of target las
> [  3%] Building CXX object src/CMakeFiles/las.dir/lasclassification.cpp.obj
> cl : Command line warning D9025 : overriding '/W3' with '/W4'
> [  6%] Building CXX object src/CMakeFiles/las.dir/lascolor.cpp.obj
> lascolor.cpp
> [  9%] Building CXX object src/CMakeFiles/las.dir/laserror.cpp.obj
> laserror.cpp
> [ 12%] Building CXX object src/CMakeFiles/las.dir/lasformat.cpp.obj
> lasformat.cpp
> C:\Liblas\main\include\liblas/lasformat.hpp(111) : warning C4244: '=' : conversi
> on from 'const liblas::uint32_t' to 'liblas::uint16_t', possible loss of data
> C:\Liblas\main\src\lasformat.cpp(68) : warning C4244: 'initializing' : conversio
> n from 'liblas::uint32_t' to 'liblas::uint16_t', possible loss of data
> C:\Liblas\main\src\lasformat.cpp(83) : warning C4244: 'initializing' : conversio
> [ 15%] Building CXX object src/CMakeFiles/las.dir/lasheader.cpp.obj
> lasheader.cpp
> c:\osgeo4w\include\geo_config.h(6) : warning C4005: 'STDC_HEADERS' : macro redef
> inition
>         c:\osgeo4w\apps\gdal-16\include\cpl_config.h(27) : see previous definiti
> on of 'STDC_HEADERS'
> C:\Liblas\main\src\lasheader.cpp(714) : warning C4244: 'argument' : conversion f
> C:\Liblas\main\src\lasheader.cpp(717) : warning C4244: 'argument' : conversion f
> C:\Liblas\main\src\lasheader.cpp(720) : warning C4244: 'argument' : conversion f
> C:\Liblas\main\src\lasheader.cpp(723) : warning C4244: 'argument' : conversion f
> [ 18%] Building CXX object src/CMakeFiles/las.dir/laspoint.cpp.obj
> laspoint.cpp
> inition
> [ 21%] Building CXX object src/CMakeFiles/las.dir/lasreader.cpp.obj
> lasreader.cpp
> inition
> C:\Liblas\main\src\lasreader.cpp(104) : warning C4101: 'e' : unreferenced local
> variable
> C:\Liblas\main\src\lasreader.cpp(116) : warning C4101: 'e' : unreferenced local
> variable
> [ 25%] Building CXX object src/CMakeFiles/las.dir/lasspatialreference.cpp.obj
> inition
> C:\Liblas\main\src\lasspatialreference.cpp(371) : warning C4100: 'mode_flag' : u
> nreferenced formal parameter
> c:\liblas\main\src\lasspatialreference.cpp(552) : warning C4702: unreachable cod
> e
> [ 28%] Building CXX object src/CMakeFiles/las.dir/lasvariablerecord.cpp.obj
> [ 31%] Building CXX object src/CMakeFiles/las.dir/laswriter.cpp.obj
> laswriter.cpp
> inition
> [ 34%] Building CXX object src/CMakeFiles/las.dir/detail/reader/header.cpp.obj
> header.cpp
> inition
> [ 37%] Building CXX object src/CMakeFiles/las.dir/detail/reader/point.cpp.obj
> point.cpp
> inition
> [ 40%] Building CXX object src/CMakeFiles/las.dir/detail/reader/reader.cpp.obj
> reader.cpp
> inition
> [ 43%] Building CXX object src/CMakeFiles/las.dir/detail/writer/base.cpp.obj
> base.cpp
> inition
> [ 46%] Building CXX object src/CMakeFiles/las.dir/detail/writer/header.cpp.obj
> header.cpp
> inition
> [ 50%] Building CXX object src/CMakeFiles/las.dir/detail/writer/point.cpp.obj
> point.cpp
> inition
> [ 53%] Building CXX object src/CMakeFiles/las.dir/detail/writer/writer.cpp.obj
> writer.cpp
> inition
> C:\Liblas\main\src\detail\writer\writer.cpp(193) : warning C4100: 'header' : unr
> [ 56%] Building CXX object src/CMakeFiles/las.dir/gt_citation.cpp.obj
> gt_citation.cpp
> inition
> c:\liblas\main\src\gt_citation.cpp(196) : warning C4706: assignment within condi
> tional expression
> [ 59%] Building CXX object src/CMakeFiles/las.dir/gt_wkt_srs.cpp.obj
> gt_wkt_srs.cpp
> inition
> C:\Liblas\main\src\gt_wkt_srs.cpp(724) : warning C4244: '=' : conversion from 'i
> nt' to 'short', possible loss of data
> C:\Liblas\main\src\gt_wkt_srs.cpp(751) : warning C4244: '=' : conversion from 'i
> [ 62%] Building CXX object src/CMakeFiles/las.dir/tifvsi.cpp.obj
> tifvsi.cpp
> Linking CXX static library ..\bin\Debug\las.lib
> [ 62%] Built target las
> Scanning dependencies of target las_c
> [ 65%] Building CXX object src/CMakeFiles/las_c.dir/las_c_api.cpp.obj
> las_c_api.cpp
> inition
> C:\Liblas\main\src\las_c_api.cpp(210) : warning C4297: 'OpenInput' : function as
> sumed not to throw an exception but does
>         The function is extern "C" and /EHc was specified
> C:\Liblas\main\src\las_c_api.cpp(746) : warning C4244: '=' : conversion from 'un
> signed int' to 'liblas::uint16_t', possible loss of data
> C:\Liblas\main\src\las_c_api.cpp(2073) : warning C4800: 'liblas::uint8_t' : forc
> ing value to bool 'true' or 'false' (performance warning)
> C:\Liblas\main\src\las_c_api.cpp(2074) : warning C4800: 'liblas::uint8_t' : forc
> C:\Liblas\main\src\las_c_api.cpp(2138) : warning C4800: 'liblas::uint8_t' : forc
> C:\Liblas\main\src\las_c_api.cpp(2162) : warning C4800: 'liblas::uint8_t' : forc
> Linking CXX shared library ..\bin\Debug\las_c.dll
>    Creating library ..\bin\Debug\las_c.lib and object ..\bin\Debug\las_c.exp
> las.lib(gt_wkt_srs.cpp.obj) : error LNK2019: unresolved external symbol __imp__s
> trnicmp referenced in function _GTIFGetOGISDefn
> las.lib(gt_citation.cpp.obj) : error LNK2001: unresolved external symbol __imp__
> strnicmp
> tricmp referenced in function _GTIFGetOGISDefn
> stricmp
> ..\bin\Debug\las_c.dll : fatal error LNK1120: 2 unresolved externals
> LINK Pass 1 failed. with 1120
> NMAKE : fatal error U1077: '"C:\Program Files\CMake 2.8\bin\cmake.exe"' : return
>  code '0xffffffff'
> Stop.
> NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio 9.0\VC\BIN
> \nmake.exe"' : return code '0x2'
> Stop.
> Stop.
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
