[Liblas-devel] Dealing with "bad" data
Volker Wichmann wichmann at laserdata.at
Thu Nov 4 13:31:44 EDT 2010
Am 04.11.2010 18:22, schrieb Mateusz Loskot:
> On 04/11/10 17:06, Volker Wichmann wrote:
>> provide a utility which tries to fix broken files but always throw an
>> exception in case a file is not compliant to the specification
> For me, the two parts of this stay in contradiction.
> Always throwing if file is not compliant, means never accept broken
> data.
Yes, this is what I'm in favour.
> Never accept broken data, implies not try to fix it.
Yes, I think this is not something which libLAS needs to deal with.
> Whatever it is called, strict and transitional mode (enable/disable with
> single switch for libLAS utility) or a separate utility trying to
> recover whatever is recoverable from broken data...
> The job of implementing those utils repairing broken data produced by
> companies loosely interpreting ASPRS LAS will be on expanses of libLAS.
I think this is in contradiction - in case you implement some fallback
mechanisms in libLAS you will already provide something like a "tool". I
fully agree that it is impossible to provide a utility which allows to
fix almost all broken files - but I think such a utility could be more
easily extended to catch specific errors than libLAS core. Why not start
with a utility that catches the issues mentioned by Howard?
best regards,
Volker
More information about the Liblas-devel mailing list
