[Liblas-devel] libgeotiff / cpl / libspatialreference.hpp changes
Mon Nov 15 10:15:06 EST 2010
Julien Malik wrote:
> Hello,
> I encountered this bug, as did a lot of OrfeoToolbox users since we
> updated to liblas 1.6.0b2.
> It affects at least Ubuntu 10.04, 10.10, OpenSuse 11.2, 11.3 and OpenBSD
> 4.8+
> I personnally use ubuntu 10.10 with gdal/geotiff from ubuntugis/unstable
> repo, which gives me recent versions (gdal 1.7.2 and geotiff 1.2.5), and
> it still does not work.
Julien,
Note that while these are reasonably recent, they are not current.
> So currently, gdal/geotiff support in liblas seems broken. I tested with
> yesterday's trunk.
> Just wanted to know if this problem will be addressed before the next
> release ?
> Or you will rely on the end-user to hand-modify a geotiff header (which
> he may not have access to) ?
I will investigate if there is a cleaner mechanism of handling this
issue.  Would you like to file a ticket with liblas's trac on the
problem so we can keep track of progress?
Best regards,
More information about the Liblas-devel mailing list
