[Liblas-devel] Problem linking a simple main with OSGEO LIBLAS library [VC9-Release]
Howard Butler hobu.inc at gmail.com
Thu Nov 18 10:54:45 EST 2010
On Nov 17, 2010, at 2:05 PM, nicolas david wrote:
> Hi Otmane
> Hi List;
> I have problem linking a simple executable with the liblas library liblas_c.lib
> provided in OSGEO4W.
> If you want to link with liblas_c.lib, I think you must use the C api, and use include file "capi/liblas.h"
> When I browse the symbols with DependencyWalker, i can find all the symbols not found..
> Am I missing something
>  I think you try to link C++ code with C lib without using "extern C" keyword..
> I tried to link with the liblas.lib, but  it asks me for  boost-serialization libs
> Perhaps a stupid question, but why don't you install this boost-serialization libs ?  ( with boostpro installer , for example.)
> Moreover, you should try to use the FindBoost.cmake Module http://www.cmake.org/cmake/help/cmake-2-8-docs.html#module:FindBoost rather than using you own FindXXX
The goal with the OSGeo4W build is to not have to worry about linking anything but OSGeo4W libraries.  I thought that I was linking statically when creating liblas.lib, and boost-serialization and boost-program-options were statically linked and included.  It would seem this is not the case :(
Additionally, liblas_c.lib should be a static compile of everything in liblas.lib + the C API, and I wished to support the approach that Otmane had attempted and failed with.
I will do some investigation to see what might be happening.
Howard
More information about the Liblas-devel mailing list
