[Liblas-devel] Re: Vertical Datum Transformation
Jason Woolard Jason.Woolard at noaa.gov
Fri Oct 29 13:22:16 EDT 2010
hi Ali,
There are a couple of ways to go about this. What I've done in the past is:
- Run las2txt on the LAS files
- Convert the ellipsoid heights to orthometric heights using VDatum. BTW- you can invoke a command line version of VDatum. The details and software are at:
http://vdatum.noaa.gov/docs/userguide_cmd.html
-Run txt2las on the output from VDatum
It's a little convoluted but if you know a little Python or a similar language this can be done in pretty much one step.
Good luck!
liblas-devel-request at lists.osgeo.org wrote:
> Send Liblas-devel mailing list submissions to
> 	liblas-devel at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/liblas-devel
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	liblas-devel-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Liblas-devel digest..."
> Today's Topics:
>    1. Re: las2txt question (Howard Butler)
>    2. Re: Re: las2txt question (Etienne Bellemare)
>    3. Vertical Datum Transformation (Ibraheem Ali)
> Message: 1
> Date: Thu, 28 Oct 2010 15:22:29 -0500
> From: Howard Butler <hobu.inc at gmail.com>
> Subject: [Liblas-devel] Re: las2txt question
> To: Randy Bucciarelli <randy at cdip.ucsd.edu>
> Cc: "Liblas-devel at lists.osgeo.org" <liblas-devel at lists.osgeo.org>
> Message-ID: <3EBAF779-6E53-49C9-8705-CB1B9661D549 at gmail.com>
> Content-Type: text/plain; charset=us-ascii
> On Oct 28, 2010, at 3:16 PM, Randy Bucciarelli wrote:
>> Hi Howard,
>> Is there a way to format resulting precision of values from the output of las2txt?
>> Or does 'las2txt' simply output the precision of the values how there were initially stored when creating LAS files?
> There isn't, but I agree there should be an option to set/override the precision of x/y/z values (independently)  I have rewritten lasinfo and las2las using the new C++ API, and I think las2txt should also be rewritten as well.  In summary output and other venues in those rewritten utilities, I have tried to respect the specified scale/precision of the dimension if it was set in the header.
> Rewriting las2txt similarly to lasinfo and las2las is in my queue, but I probably won't get to it for a bit.
> Howard
> PS, this question should be asked on the list, and I have forwarded it there.
> Message: 2
> Date: Thu, 28 Oct 2010 16:44:53 -0400
> From: Etienne Bellemare <etiennebr at gmail.com>
> Subject: Re: [Liblas-devel] Re: las2txt question
> To: "Liblas-devel at lists.osgeo.org" <liblas-devel at lists.osgeo.org>
> Message-ID:
> 	<AANLkTikdhOeOVoKDew3V=TK1kP-tzJbVEwu-egf__9Cf at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Good point, I'd like to suggest also the ability to specify the header
> separated the same way the fields are going to be. It will create a much
> more consistent file. e.g. for the moment you can't use tab to seperate
> header even if your fields are. Having the ability to set a name for the
> header could be a nice feature too.
> Thanks again,
> Etienne
> On Thu, Oct 28, 2010 at 4:22 PM, Howard Butler <hobu.inc at gmail.com> wrote:
>>> Hi Howard,
>> las2txt?
>> Howard
>> there._______________________________________________
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20101028/1e66bed7/attachment-0001.html
> Message: 3
> Date: Fri, 29 Oct 2010 09:21:36 -0600
> From: Ibraheem Ali <ialhakeem at gmail.com>
> Subject: [Liblas-devel] Vertical Datum Transformation
> To: liblas-devel at lists.osgeo.org
> Message-ID:
> 	<AANLkTin-SzgrpAALbVLc9BXaQTn5afsF0o-D=zJ+1yo+ at mail.gmail.com>
> Dear All,
> I'm a bit fresh with all LiDAR data processing and analysis.
> I've got recently a bunch of LiDAR "las" format files, and their Vertical
> datum is ellipsoidal "WGS 84". The vertical datum is not defined within the
> las files, it was givin to me as a fact from the vendor.
> I need to convert these files to NAVD88 Vertical Datum, and I basically need
> to perform the following steps:
>  1- Define the vertical datum (WGS 84) ellipsoidal within the files
> 2- Transform to NAVD 88
> I've got the "liblas" with "OSGeo w4", but I can not find a clear
> descriptions to the datums available or sample code regarding the above
> mentioned issue
> I would ask you kindly to help me with this, and would you please direct me
> to the right documentations?
> Thank you very much
> Ali
> URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20101029/caa86e11/attachment-0001.html
> End of Liblas-devel Digest, Vol 34, Issue 9
More information about the Liblas-devel mailing list
