[Liblas-devel] Las2Oci problems
T.J.F. Commandeur daboytom101 at hotmail.com
Mon Apr 18 15:57:45 EDT 2011
With copied I indeed mean from the source code. I guess this, given the
(somewhat vague?) reaction of Martin, is indeed not possible to use. If you
are interested to still take a look maybe to get some ideas the offer still
stands.
Just to clarify some more, the idea was to test if blocks containing less
than the maximum would penalize a lot query time once in the SDO_PC type of
Oracle.
Since now I cannot get my data into the database it is not possible to test
this.
Regards,
Tom
-----Oorspronkelijk bericht-----
Van: Michael P. Gerlek [mailto:mpg at flaxen.com]
Verzonden: maandag 18 april 2011 16:18
Aan: 'T.J.F. Commandeur'; 'Howard Butler'
CC: liblas-devel at lists.osgeo.org
Onderwerp: RE: [Liblas-devel] Las2Oci problems
> Of course I am willing to provide the source code. Mostly is copied/based
on
> SPfinalizer. To whom and where could I send the source to?
Tom:
When you say "copied", do you mean you directly used Martin's source code?
If so, we cannot accept you contribution, unless Martin's code is also open
source with an OSI-approved license on it (preferably BSD).  The provenance
of much of Martin's code is not clear, and libLAS/libPC has to be very
careful about where we get our code from.  If you only based your code on
something like a published paper of his, however, that would be okay.
That being said, if your code meets these requirements then please just make
sure your copyright appears on each of the files and you can send it to me
(mpg at flaxen.com).
Thanks -
-mpg
More information about the Liblas-devel mailing list
