[Liblas-devel] error link in compile Error
=?GBK?B?tejUrNPC?= dianyuanyong at 126.com
Tue Dec 27 00:34:19 EST 2011
hi,all
i'also have the same error with the philipp  when compliation with vs2010 and win7 .
firstly ,i use the laszip.lib in the osgeo4w ,the path is c:\osgeo4w\lib,but the error is the same of the philipp.
sceondly, i delete the laszip.lib  in  c:\osgeo4w\lib,delete laszip.dll in c:\osgeo4w\bin
              and then  i  download the source code of  laszip 2.0.2 and complie it ,and then put the laszip.lib into
               c:\osgwo4w\lib , laszip.dll to c:\osgeo4w\bin, and update the .hpp in c:\osgeo4w\include
              but the result is the same of the philipp.
can you help me?
philipp 's email is followed:
Hi all,
I want to compile libLAS with Visual Studio 2010 under Windows 7 (x86).
I¡¯ve installed all the necessary dependencies (boost with all Variants,
OSGeo4W with gdal-devel, geotiff, oci, ...) and used the default
Directories to be as synchron as possible with the install-guide.
But I get this error all time:
Error      70           error LNK1120: 1 unresolved externals
C:\dev\libLAS\bin\Debug\liblas.dll         liblas
Error      69           error LNK2019: unresolved external symbol "public:
char const * __thiscall LASitem::get_name(void)const "
(?get_name at LASitem@@QBEPBDXZ) referenced in function "public: class
liblas::property_tree::basic_ptree<class std::basic_string<char,struct
std::char_traits<char>,class std::allocator<char> >,class
std::basic_string<char,struct std::char_traits<char>,class
std::allocator<char>>,struct std::less<class std::basic_string<char,struct
std::char_traits<char>,class std::allocator<char> > > > __thiscall
liblas::Header::GetPTree(void)const "
(?GetPTree at Header at liblas@@QBE?AV?$basic_ptree at V?$basic_string at DU?$char_traits at D at std@@V?$allocator at D at 2@@std@@V12 at U?$less at V?$basic_string at DU?$char_traits at D at std@@V?$allocator at D at 2@@std@@@2@@property_tree at 2 at XZ)
     C:\dev\libLAS\src\header.cpp.obj          liblas
Any idea ?
Thanks for any help,
philipp
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20111227/1dc4d028/attachment.html
More information about the Liblas-devel mailing list
