[Liblas-devel] estimating lines and samples
Tisham tisham at eleceng.adelaide.edu.au
Tue Feb 8 08:15:00 EST 2011
Hi David,
Is this a gridded terrain image i.e. an interpolated terrain from the
unevenly sampled lidar ? or is this a representation of the return
intensity ? I would recommend tin generation and gridding follwed by
some rough statistics on deviation from actual ground point values.
For the interpolated intensity I am not sure what would be the best test.
Cheers,
Tisham.
On 8/02/2011 5:11 AM, David Burken wrote:
> All,
> I'm writing a plugin for ossim to form an image from las files.  This
> will be open sourced as soon as it's useful.  Does anyone have any
> advise on how to choose a grid resolution which will determine the
> lines and samples?  I thought about using the square root of the
> number of points for a return and then scaling by ratio of the
> bounding box.  It would be nice to pick a grid size that gets at least
> one point for grid.  Any ideas?
> Thanks in advance,
> Dave
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
