[Liblas-devel] GPS Time and inverted height
Martin Isenburg martin.isenburg at gmail.com
Wed Jun 15 09:51:32 EDT 2011
hi,
the las2las version from LAStools [*] can do both Q1 and Q2.
for Q1 you can set a gps-time of 0.0 for each point with
las2las -i lasformat0.las -o lasformat1.las  -point_type 1
or for LAS points with RGB values
las2las -i lasformat2.las -o lasformat3.las  -point_type 3
for Q2 you can invert the height with
las2las -i lidar.las -o lidar_inverted.las -scale_z -1.0
cheers,
martin @lastools
[*] http://www.cs.unc.edu/~isenburg/lastools
On Wed, Jun 15, 2011 at 6:18 AM, Howard Butler <hobu.inc at gmail.com> wrote:
> On Jun 15, 2011, at 4:33 AM, Julian Olszewski wrote:
> > Sorry for asking two questions within the same thread.
> No problem.
> > Q1: Is there any way to populate a las file with "fake" GPS Time.
> Not with libLAS at this time.  las2las can only do translation on XYZ
> values at this point.  You could do it yourself using the Python bindings
> and a little bit of scripting (it would be much slower, of course).
> > The software I use require GPS Time - it's mandatory otherwise I won't be
> able to load the data
> Which software is this?  It would seem that it could do the faking itself
> if it didn't find time values.
> > Q2: Can I invert the height or multiply by -1?
> See above.
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110615/b98c9e39/attachment.html
More information about the Liblas-devel mailing list
