Re: [Liblas-devel] IDE used/good for using Liblas
Ivan Lucena ivan.lucena at pmldnet.com
Wed Jun 22 09:32:40 EDT 2011
Thejus,
If ( OS != Win )
  netbeans.org
See example of how to set it up: http://trac.osgeo.org/gdal/wiki/BuildingOnUnixWithNetBeansIDE
All it does is to parse your C/C++ code in order to do auto-completion, goto definition, find usage, refactoring and things like that. You don't to create a project definition because it will use the original makefiles. You can also use netbeans as a SVN, CVS or Mercurial front-end. For debugging it will use the GDB installed in your system.
Regards,
Ivan
>  -------Original Message-------
>  From: thejus kambi <thejus.kambi at gmail.com>
>  To: liblas-devel at lists.osgeo.org
>  Subject: [Liblas-devel] IDE used/good for using Liblas
>  Sent: Jun 22 '11 08:01
>  Hello,
>  It could be a very basic question, Please bear with me, I am new to c++.
>  Could you suggest me a good IDE for using liblas?
>  Thanks in advance,
>  Thejus
>  _______________________________________________
>  Liblas-devel mailing list
>  [LINK: compose.php?to=Liblas-devel at lists.osgeo.org]
>  [LINK: http://lists.osgeo.org/mailman/listinfo/liblas-devel]
More information about the Liblas-devel mailing list
