[Liblas-devel] libLAS issue on Os X
Howard Butler hobu.inc at gmail.com
Thu Jul 12 08:35:33 PDT 2012
Antoine,
Can you try boost 1.49 or less? I don't think 1.50 has been tested yet with liblas...
Howard
On Jul 12, 2012, at 10:24 AM, Antoine Cottin wrote:
> Good morning,
> I try to install libLAS 1.7 on Mac OsX 10.6.8 (kernel Darwin 10.8.0)
> When I try to make it, I have the following error output:
> % cmake -G "Unix Makefiles" .
> -- The C compiler identification is GNU
> -- The CXX compiler identification is GNU
> -- Checking whether C compiler has -isysroot
> -- Checking whether C compiler has -isysroot - yes
> -- Checking whether C compiler supports OSX deployment target flag
> -- Checking whether C compiler supports OSX deployment target flag - yes
> -- Check for working C compiler: /usr/bin/gcc
> -- Check for working C compiler: /usr/bin/gcc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Checking whether CXX compiler has -isysroot
> -- Checking whether CXX compiler has -isysroot - yes
> -- Checking whether CXX compiler supports OSX deployment target flag
> -- Checking whether CXX compiler supports OSX deployment target flag - yes
> -- Check for working CXX compiler: /usr/bin/c++
> -- Check for working CXX compiler: /usr/bin/c++ -- works
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - done
> -- Setting libLAS build type - Release
> -- Searching for Boost 1.38+ - done
> -- Boost version: 1.50.0
> -- Found the following Boost libraries:
> --   program_options
> --   thread
> -- Enable libLAS utilities to build - done
> -- Enable libLAS unit tests to build - done
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /Users/nous/Sources/liblas_1.7
> % make
> /Users/nous/Sources/boost_1_50_0/boost/math/special_functions/binomial.hpp:65:
> instantiated from here
> /Users/nous/Sources/boost_1_50_0/boost/math/special_functions/gamma.hpp:174:
> warning: comparing floating point with == or != is unsafe
> make[2]: *** [src/CMakeFiles/las.dir/chipper.cpp.o] Error 1
> make[1]: *** [src/CMakeFiles/las.dir/all] Error 2
> make: *** [all] Error 2
> I did some Google searches, but I didn't find anything on this, or at least any good answers.
> Any idea what would be the issue ?
> Thanks
> Regards,
> Antoine Cottin, Ph.D.
> University of Southern Mississippi
> Department of Marine Science
> 1020 Balch Blvd.
> Stennis Space Center, MS 39529
> Phone : (228) 688-2325
> Fax : (228) 688-1121
> Email : antoine.cottin at usm.edu
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/liblas-devel/attachments/20120712/b232d721/attachment.pgp>
More information about the Liblas-devel mailing list
