[rttopo-dev] Tolerance 0 support in master branch
a.furieri at lqt.it a.furieri at lqt.it
Tue Sep 6 06:21:04 PDT 2016
On Tue, 6 Sep 2016 13:42:48 +0200, Andrea Peri wrote:
> (sorry my email was hard to understand due tomy poor english, and to
> smartphone)
> So try to resend with some adjust:
> Hi Alessandro.
> You are reason.
> But dont forget that rt-topology is an youger libraries and do some
> change (without support previous version) to allow a robustness
> beaviour now is reasonable.
> Tolerance 0 is most clear associable to a no one kind of rounding
> rather than to a dinamic tolerance (as is now).
> I guess is no too heavy a change applied to test-suite moving from 0
> to -1 actual settings.
> Could do it myself ?
Hi Andrea,
you are right; manually patching the current testcases so to
correctly support the most recent librttopo changes shouldn't
be difficult at all.
it should require just few trivial changes in both
-/test/check_topology2d.c  and -/test/check_topology3d.c
sources
bye Sandro
More information about the librttopo-dev mailing list
