[Live-demo] Installing Arramagong as the main OS
vega_l at yahoo.com vega_l at yahoo.com
Sun Nov 22 23:59:19 EST 2009
I think I've found the scripts from a page with title "osgeo - Revision 2722", I'm guessing these the latest version.
About the order in which they should be executed, I guess the logs.tar.gz will provide some guidance.
I'm already using Ubuntu 9.04 (64 bit version), and I've installed R, QGIS and GRASS from its default repositories. I'm thinking I should first uninstall them completely before start installing the new versions if I don't want any incompatibility or package dependencies issues.
I'll give it a try next weekend.
Thanks for the answer!
--- El lun 23-nov-09, Alex Mandel <tech_dev at wildintellect.com> escribió:
> De: Alex Mandel <tech_dev at wildintellect.com>
> Asunto: Re: [Live-demo] Installing Arramagong as the main OS
> A: vega_l at yahoo.com
> Cc: live-demo at lists.osgeo.org
> Fecha: lunes, 23 noviembre, 2009, 6:15 am
> vega_l at yahoo.com
> wrote:
> > Good afternoon.
> > I've been using GRASS in Arramagong for a while, and I
> think it is an excellent piece of software to use open
> source GIS tools.
> > My question is simple. I'm related to the Ubuntu
> system and its installation process, and I would like to
> install Arramagong as the system by default into my
> secondary PC.
> > Choosing "System/Install Xubuntu GNU Linux" will
> install the system into a disk partition?
> > Can I use the Live CD to install it? If I do it, the
> GIS tools I'm using from the virtual machine version will be
> installed along with Xubuntu?
> > Thank you in advance!
> > Luis Alberto Vega.
> Theoretically, the answer is yes. However we did not have
> time to test
> the install option on the disc thouroughly, and the few
> attempts made by
> some were not successful (has anyone done it
> successfully?). There are
> at least 2 other options though,
> 1. Download the Virtual Machine version and run it in any
> other the
> freely available virtual machine tools (Virtual Box, Vmware
> Player,
> Vmware Server, Parallels, etc) - depending on your primary
> operating
> system this solution may vary slightly. The advantage here
> is no need to
> reboot your computer to use it, the disadvantage - it's a
> little
> trickier to setup shared drives, and you need a decent
> computer with
> plenty of ram.
> 2. Install any of the Ubuntu 9.04 line-up(Ubuntu, Xubuntu,
> Kubuntu) and
> run the scripts that we used to build the live disc to
> repeat the
> installation. Or do the installation of just the tools you
> want. GRASS
> is actually pretty easy to install from online
> repositories.
> Thanks for you interest,
> Alex
      ____________________________________________________________________________________
¡Obtén la mejor experiencia en la web!
Descarga gratis el nuevo Internet Explorer 8.
http://downloads.yahoo.com/ieak8/?l=e1
More information about the Live-demo mailing list
