[Live-demo] Installing Arramagong as the main OS
Cameron Shorter cameron.shorter at gmail.com
Mon Nov 23 05:44:14 EST 2009
The steps for building your own LiveDVD are explained here:
http://wiki.osgeo.org/wiki/GISVM_Build#Creating_the_GIS_Virtual_Machine
You will find that the steps are almost the same for installing all the
GIS applications on an Ubuntu 9.04 based system.
vega_l at yahoo.com wrote:
> I think I've found the scripts from a page with title "osgeo - Revision 2722", I'm guessing these the latest version.
> About the order in which they should be executed, I guess the logs.tar.gz will provide some guidance.
> I'm already using Ubuntu 9.04 (64 bit version), and I've installed R, QGIS and GRASS from its default repositories. I'm thinking I should first uninstall them completely before start installing the new versions if I don't want any incompatibility or package dependencies issues.
> I'll give it a try next weekend.
> Thanks for the answer!
> --- El lun 23-nov-09, Alex Mandel <tech_dev at wildintellect.com> escribió:
>> De: Alex Mandel <tech_dev at wildintellect.com>
>> Asunto: Re: [Live-demo] Installing Arramagong as the main OS
>> A: vega_l at yahoo.com
>> Cc: live-demo at lists.osgeo.org
>> Fecha: lunes, 23 noviembre, 2009, 6:15 am
>> vega_l at yahoo.com
>> wrote:
>>> Good afternoon.
>>> I've been using GRASS in Arramagong for a while, and I
>> think it is an excellent piece of software to use open
>> source GIS tools.
>>> My question is simple. I'm related to the Ubuntu
>> system and its installation process, and I would like to
>> install Arramagong as the system by default into my
>> secondary PC.
>>> Choosing "System/Install Xubuntu GNU Linux" will
>> install the system into a disk partition?
>>> Can I use the Live CD to install it? If I do it, the
>> GIS tools I'm using from the virtual machine version will be
>> installed along with Xubuntu?
>>> Thank you in advance!
>>> Luis Alberto Vega.
>> Theoretically, the answer is yes. However we did not have
>> time to test
>> the install option on the disc thouroughly, and the few
>> attempts made by
>> some were not successful (has anyone done it
>> successfully?). There are
>> at least 2 other options though,
>> 1. Download the Virtual Machine version and run it in any
>> other the
>> freely available virtual machine tools (Virtual Box, Vmware
>> Player,
>> Vmware Server, Parallels, etc) - depending on your primary
>> operating
>> system this solution may vary slightly. The advantage here
>> is no need to
>> reboot your computer to use it, the disadvantage - it's a
>> little
>> trickier to setup shared drives, and you need a decent
>> computer with
>> plenty of ram.
>> 2. Install any of the Ubuntu 9.04 line-up(Ubuntu, Xubuntu,
>> Kubuntu) and
>> run the scripts that we used to build the live disc to
>> repeat the
>> installation. Or do the installation of just the tools you
>> want. GRASS
>> is actually pretty easy to install from online
>> repositories.
>> Thanks for you interest,
>> Alex
>       ____________________________________________________________________________________
> ¡Obtén la mejor experiencia en la web!
> Descarga gratis el nuevo Internet Explorer 8.
> http://downloads.yahoo.com/ieak8/?l=e1
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
