[Live-demo] Version numbers
Cameron Shorter cameron.shorter at lisasoft.com
Thu Oct 1 20:56:47 EDT 2009
Thanks for your feedback Richardo. Your suggestions make sense.
Alex,
In that case, can we please name the VM release:
arramagong-vm-2.0.3
Ricardo Pinho wrote:
> Hi,
>> Richardo,
>> For the virtual machine, we have been adding "gisvm" into the tag.
>> Ie: arramagong-gisvm-2.0.3
>> Do
> you want gisvm to be specifically associated like the above,
>> or do you
> want to create a separate gisvm which is different from arramagong?
>> Eg: We could have:
>> arramgong-vm-2.0.3
>> andgisvm-2.0.3.1 or similar.
>> What are your thoughts.
> You all have done a GREAT WORK on this community project!
> (I probably missed a lot because I couldn't keep up with you)
> But this is how I see things :
> This Live-Demo initiative  had a clear objective: To produce a LiveDVD for FOSS4G 2009! (following the tradition of previous events)
> But on that process, you have used VM to build it, to discover the potential of Virtualization.
> I really agree that FOSS4G should start to have a VM alternative distribution. Attendees  will benefit a lot from it!
> So to make both versions related (because they are!) to the public, I really
> think you should use the same prefix:
> arramagong-2.0.3-livedvd.iso
> arramagong-2.0.3-vm.7z
> If you think that using GISVM name can in anyway benefit this release, I will not oppose on using it (for example):
> arramagong-2.0.3-gisvm.7z
> But I really don't want to be accused of using others work on the benefit of GISVM name.
> It has been a pleasure to help you guys, the best I could, and to see the success of it.
> And since you have build a VM final version for this event, I really don't see the point of making a GISVM release for it!
> Unless it has a completely new approach, like GISVM Server! (that's why I have released it)
> GISVM has it's own life, and I will try to make it last for many other FOSS events.
> Sometime after the FOSS4G2009 there will be a new GISVM version out of the existing scripts!
> Because there are many things to improve...
> In the mean time I will download  2.0.3 version, and hope to have deep  look on it this weekend.
> And you can count on my comments and suggestions if I find anything to wrong.
> Cheers,
> Ricardo Pinho
> http://gisvm.com
> ----- Mensagem original ----
> De: Cameron Shorter <cameron.shorter at lisasoft.com>
> Para: tech at wildintellect.com
> Cc: "live-demo at lists.osgeo.org" <live-demo at lists.osgeo.org>
> Enviadas: Quinta-feira, 1 de Outubro de 2009 23:06:34
> Assunto: Re: [Live-demo] Version numbers
> Alex, minor suggestions re naming convention, (I've been following what I believe to be close to ubuntu conventions)
> * Only use lower case.
> Use:
> arramagong-livedvd-2.0.3 (note no "Final" in the name)
> In retrospect, I suspect we should have:
> arramagong-2.0.3-livedvd.iso rather than arramagong-livedvd-2.0.3.iso
> Richardo,
> Do you want gisvm to be specifically associated like the above, or do you want to create a separate gisvm which is different from arramagong?
> Eg: We could have:
> arramgong-vm-2.0.3
> and
> Alex Mandel wrote:
>> For those who have access to the download server edit the index.html,
>> please keep in mind that file is in svn, so it's best if you make
>> changes on your machine, commit them and then svn up on the osgeo
>> server. Otherwise edits may be lost, clobbered or otherwised mixed up.
>> FYI, 2.0.3-Final links are now active.
>> No torrent till we resolve best approach. VM's sometime over the weekend.
>> Thanks,
>> Alex
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
> -- Cameron Shorter
> Geospatial Systems Architect
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
>       ____________________________________________________________________________________
> Veja quais são os assuntos do momento no Yahoo! +Buscados
> http://br.maisbuscados.yahoo.com
Cameron Shorter
More information about the Live-demo mailing list
