[Live-demo] Is GIS Vm is compatible with Ubuntu 8.04 (Hardy) ?
Alex Mandel tech_dev at wildintellect.com
Mon Oct 5 13:14:20 EDT 2009
Arun Sharma Tecnics wrote:
> Hello Osgeao team,
> I am one of the team of member of click2try.
> We are trying to prepare GISVM (On xen virtual environment) and willing
> to confirm some of the points.
> a) Is GIS application is supported with Ubuntu 8.04 (Having GNOME) ?
> b) Is GIS application can be installed only on Xubuntu 9.04 or is it
> compatible with Ubuntu 9.04 also ?
> c) Is this application supports on 32bit environment only ? Or Does it
> has support for 64 bit Ubuntu environment ?
> I have some of the more questions related to this , but once i get in
> touch with your team i will be able to communicate more.
> Waiting for your reply.
> Regards,
> Arun Sharma
> Click2try
The scripts we wrote are specific to 9.04 only in that some of the
apt-get commands pull packages that may not be available in previous
versions and install repositories for 9.04 (see the sources.list.d
folder in the svn). Most of them will still work for 8.04 though.
The only parts that might be Xubuntu specific is the command to swap in
the desktop background and possibly the creation of the desktop icons(
but I think those should work on Gnome)
While we've tested it on 32bit, I think it might be ok on 64 bit
assuming the packages are available and you might need the ia32 libs
installed.
Thanks,
Alex
More information about the Live-demo mailing list
