[Live-demo] Installation issues of GISVM on xubuntu 8.04
Aneel aneel.r at tecnics.com
Wed Oct 7 09:33:43 EDT 2009
On Tue, 2009-10-06 at 09:29 -0700, Alex Mandel wrote:
> Aneel wrote:
> > Hello OSgeo Team,
> > Let me introduce myself. I am Aneel from click2try team.
> > I have tried to install GISVM on xubuntu 8.04 (32-bit) on Xen
> > hypervisor. While installation of GISVM, i found below errors.  Please
> > guide me to resolve these issues.
> Are you using the trunk, or the 2.0.3 tag from svn?
We are using trunk
> > Error1:
> > deegree_start.sh: FAILED
> > md5sum: WARNING: 1 of 1 computed checksum did NOT match
> > ERROR [install_deegree.sh]: download of deegree_start.sh failed.
> > Finished: ./install_deegree.sh
> Interesting, that just means that for some reason the hash check to
> confirm the download failed.
> Try:
> cd /tmp/build_deegree
> wget -c
> http://download.deegree.org/LiveDVD/FOSS4G2009/deegree-2.2_tomcat-6.0.20.tar.gz
> and then rerun the deegree script in the bin folder
> sudo ./install_deegree.sh
Still same issue
> > Error2:
> > createdb: database creation failed: ERROR:  template database "-E" does
> > not exist
> > createlang: could not connect to database template_postgis: FATAL:
> > database "template_postgis" does not exist
> > UPDATE 0
> > psql: FATAL:  database "template_postgis" does not exist
> Ah there's an error on ln 92 of install_postgis.sh, it should read:
> sudo -u $USER_NAME createdb -E UTF8 template_postgis
> no -T, that was a mistake
Above fix solved my issues
> > Error3: for install_desktop.sh
> > CRITICAL **: Failed to init libxfconf: dbus-launch failed to autolaunch
> > D-Bus session: Autolaunch error: X11 initialization failed.
> To be expected, setting the background and screen stretch are coded for
> XFCE in this particular case. Take a look in the install_desktop. These
> steps can be done by hand and commented out.
> ln 34-40
This will be done manually as suggested by you
> > Regards
> > Aneel Kumar
> > click2try
> Thanks,
> Alex
At the end of main.sh script execution, i got below lines. This was on
xubuntu 9.04
1059:documentation and any error corrections provided by Sun
(collectively
1575:ERROR [install_deegree.sh]: download of deegree_start.sh failed.
1587:tar: Error is not recoverable: exiting
now
1589:tar: Error exit delayed from previous errors
6144:  libgpg-error-dev libice-dev libicu-dev libjpeg62-dev libkadm55
libkrb5-dev
6175:  libgpg-error-dev libice-dev libicu-dev libjpeg62-dev libkadm55
libkrb5-dev
6269:Get:81 http://archive.ubuntu.com jaunty/main libgpg-error-dev
1.4-2ubuntu7 [35.1kB]
6458:Selecting previously deselected package libgpg-error-dev.
6459:Unpacking libgpg-error-dev
(from .../libgpg-error-dev_1.4-2ubuntu7_i386.deb) ...
6609:Setting up libgpg-error-dev (1.4-2ubuntu7) ...
12168:
inflating: /tmp/geokettle_downloads/geokettle-3.2.0-20090609-bin/samples/transformations/Data Validator - all usecases with error handling.ktr
12196:
inflating: /tmp/geokettle_downloads/geokettle-3.2.0-20090609-bin/samples/transformations/files/GetXMLData - test 3 - error handling.xml
12388:
extracting: /tmp/geokettle_downloads/geokettle-3.2.0-20090609-bin/ui/images/error-hop.png
12521:
extracting: /tmp/geokettle_downloads/geokettle-3.2.0-20090609-bin/ui/images/show-error-lines.png
13532:dpkg: error
processing /tmp/maptiler_downloads/maptiler_1.0.beta1_all.deb
(--install):
13533: subprocess dpkg-deb --control returned error exit status 2
13537:ERROR: Installation of the MapTiler failed.
13950:  libgpg-error-dev libblas-dev x11proto-xinerama-dev
gnome-cards-data
14110:  libgpg-error-dev libblas-dev x11proto-xinerama-dev
gnome-cards-data
14187:  libgpg-error-dev libblas-dev x11proto-xinerama-dev
gnome-cards-data
15078:  x11proto-kb-dev libglib2.0-dev libgpg-error-dev
15223:  x11proto-kb-dev libglib2.0-dev libgpg-error-dev
15273:psycopg/psycopgmodule.c:23:20: error: Python.h: No such file or
directory
15275:./psycopg/python.h:27:26: error: structmember.h: No such file or
directory
15276:./psycopg/python.h:30:4: error: #error "psycopg requires Python >=
2.4"
15278:./psycopg/psycopg.h:55: error: expected ')' before '*' token
15279:./psycopg/psycopg.h:56: error: expected ')' before '*' token
15280:./psycopg/psycopg.h:59: error: expected '=', ',', ';', 'asm' or
'__attribute__' before '*' token
15281:./psycopg/psycopg.h:63: error: expected '=', ',', ';', 'asm' or
15282:./psycopg/psycopg.h:102: error: expected '=', ',', ';', 'asm' or
15283:./psycopg/psycopg.h:110: error: expected '=', ',', ';', 'asm' or
15284:./psycopg/psycopg.h:113: error: expected ')' before '*' token
15285:./psycopg/psycopg.h:116: error: expected ')' before '*' token
15287:./psycopg/connection.h:44: error: expected '=', ',', ';', 'asm' or
'__attribute__' before 'connectionType'
15288:./psycopg/connection.h:52: error: expected
specifier-qualifier-list before 'PyObject_HEAD'
15290:./psycopg/cursor.h:36: error: expected '=', ',', ';', 'asm' or
'__attribute__' before 'cursorType'
15291:./psycopg/cursor.h:39: error: expected specifier-qualifier-list
15293:./psycopg/lobject.h:36: error: expected '=', ',', ';', 'asm' or
'__attribute__' before 'lobjectType'
15294:./psycopg/lobject.h:39: error: expected specifier-qualifier-list
before 'PyObject'
15296:./psycopg/typecast.h:35: error: expected '=', ',', ';', 'asm' or
15297:./psycopg/typecast.h:40: error: expected '=', ',', ';', 'asm' or
'__attribute__' before 'typecastType'
15298:./psycopg/typecast.h:43: error: expected specifier-qualifier-list
15299:./psycopg/typecast.h:58: error: expected specifier-qualifier-list
before 'typecast_function'
15300:./psycopg/typecast.h:65: error: expected '=', ',', ';', 'asm' or
15301:./psycopg/typecast.h:66: error: expected '=', ',', ';', 'asm' or
15302:./psycopg/typecast.h:69: error: expected '=', ',', ';', 'asm' or
15303:./psycopg/typecast.h:70: error: expected '=', ',', ';', 'asm' or
15304:./psycopg/typecast.h:75: error: expected ')' before '*' token
15305:./psycopg/typecast.h:76: error: expected ')' before '*' token
15306:./psycopg/typecast.h:79: error: expected '=', ',', ';', 'asm' or
15307:./psycopg/typecast.h:82: error: expected '=', ',', ';', 'asm' or
15308:./psycopg/typecast.h:86: error: expected '=', ',', ';', 'asm' or
15310:./psycopg/microprotocols.h:37: error: expected '=', ',', ';',
'asm' or '__attribute__' before '*' token
15311:./psycopg/microprotocols.h:48: error: expected ')' before '*'
token
15312:./psycopg/microprotocols.h:50: error: expected ')' before '*'
token
15313:./psycopg/microprotocols.h:52: error: expected '=', ',', ';',
15314:./psycopg/microprotocols.h:54: error: expected '=', ',', ';',
15315:./psycopg/microprotocols.h:57: error: expected '=', ',', ';',
15317:./psycopg/microprotocols_proto.h:35: error: expected '=', ',',
';', 'asm' or '__attribute__' before 'isqlquoteType'
15318:./psycopg/microprotocols_proto.h:38: error: expected
15320:./psycopg/adapter_qstring.h:34: error: expected '=', ',', ';',
'asm' or '__attribute__' before 'qstringType'
15321:./psycopg/adapter_qstring.h:37: error: expected
15322:./psycopg/adapter_qstring.h:48: error: expected '=', ',', ';',
15324:./psycopg/adapter_binary.h:35: error: expected '=', ',', ';',
'asm' or '__attribute__' before 'binaryType'
15325:./psycopg/adapter_binary.h:38: error: expected
15326:./psycopg/adapter_binary.h:47: error: expected '=', ',', ';',
15328:./psycopg/adapter_pboolean.h:34: error: expected '=', ',', ';',
'asm' or '__attribute__' before 'pbooleanType'
15329:./psycopg/adapter_pboolean.h:37: error: expected
15330:./psycopg/adapter_pboolean.h:46: error: expected '=', ',', ';',
15332:./psycopg/adapter_pfloat.h:34: error: expected '=', ',', ';',
'asm' or '__attribute__' before 'pfloatType'
15333:./psycopg/adapter_pfloat.h:37: error: expected
15334:./psycopg/adapter_pfloat.h:46: error: expected '=', ',', ';',
15336:./psycopg/adapter_asis.h:34: error: expected '=', ',', ';', 'asm'
or '__attribute__' before 'asisType'
15337:./psycopg/adapter_asis.h:37: error: expected
15338:./psycopg/adapter_asis.h:46: error: expected '=', ',', ';', 'asm'
15340:./psycopg/adapter_list.h:34: error: expected '=', ',', ';', 'asm'
or '__attribute__' before 'listType'
15341:./psycopg/adapter_list.h:37: error: expected
15342:./psycopg/adapter_list.h:44: error: expected '=', ',', ';', 'asm'
15344:./psycopg/typecast_binary.h:36: error: expected '=', ',', ';',
'asm' or '__attribute__' before 'chunkType'
15345:./psycopg/typecast_binary.h:39: error: expected
15346:psycopg/psycopgmodule.c:51:22: error: datetime.h: No such file or
directory
15348:./psycopg/adapter_datetime.h:34: error: expected '=', ',', ';',
'asm' or '__attribute__' before 'pydatetimeType'
15349:./psycopg/adapter_datetime.h:37: error: expected
15350:./psycopg/adapter_datetime.h:52: error: expected '=', ',', ';',
15351:./psycopg/adapter_datetime.h:57: error: expected '=', ',', ';',
15352:./psycopg/adapter_datetime.h:62: error: expected '=', ',', ';',
15353:./psycopg/adapter_datetime.h:67: error: expected '=', ',', ';',
15354:./psycopg/adapter_datetime.h:74: error: expected '=', ',', ';',
15355:./psycopg/adapter_datetime.h:81: error: expected '=', ',', ';',
15356:./psycopg/adapter_datetime.h:90: error: expected '=', ',', ';',
15357:./psycopg/adapter_datetime.h:94: error: expected '=', ',', ';',
15358:./psycopg/adapter_datetime.h:98: error: expected '=', ',', ';',
15359:./psycopg/adapter_datetime.h:102: error: expected '=', ',', ';',
15360:psycopg/psycopgmodule.c:53: error: expected '=', ',', ';', 'asm'
15361:psycopg/psycopgmodule.c:54: error: expected '=', ',', ';', 'asm'
15362:psycopg/psycopgmodule.c:55: error: expected '=', ',', ';', 'asm'
15363:psycopg/psycopgmodule.c:56: error: expected '=', ',', ';', 'asm'
15364:psycopg/psycopgmodule.c:57: error: expected '=', ',', ';', 'asm'
15365:psycopg/psycopgmodule.c:60: error: expected '=', ',', ';', 'asm'
15366:psycopg/psycopgmodule.c:61: error: expected '=', ',', ';', 'asm'
15367:psycopg/psycopgmodule.c:62: error: expected '=', ',', ';', 'asm'
15368:psycopg/psycopgmodule.c:64: error: expected '=', ',', ';', 'asm'
15375:psycopg/psycopgmodule.c:103: error: expected '=', ',', ';', 'asm'
15376:psycopg/psycopgmodule.c:231: error: expected ')' before '*' token
15377:psycopg/psycopgmodule.c:238: error: expected '=', ',', ';', 'asm'
15378:psycopg/psycopgmodule.c:272: error: expected ')' before '*' token
15379:psycopg/psycopgmodule.c:384: error: expected ')' before '*' token
15380:psycopg/psycopgmodule.c:400: error: expected '=', ',', ';', 'asm'
15381:psycopg/psycopgmodule.c:404: error: expected '=', ',', ';', 'asm'
15382:psycopg/psycopgmodule.c:410: error: expected
specifier-qualifier-list before 'PyObject'
15383:psycopg/psycopgmodule.c:414: error: 'Error' undeclared here (not
in a function)
15390:psycopg/psycopgmodule.c:415: error: 'Warning' undeclared here (not
in a function)
15397:psycopg/psycopgmodule.c:416: error: 'InterfaceError' undeclared
here (not in a function)
15404:psycopg/psycopgmodule.c:417: error: 'DatabaseError' undeclared
15411:psycopg/psycopgmodule.c:418: error: 'InternalError' undeclared
15418:psycopg/psycopgmodule.c:419: error: 'OperationalError' undeclared
15425:psycopg/psycopgmodule.c:421: error: 'ProgrammingError' undeclared
15432:psycopg/psycopgmodule.c:423: error: 'IntegrityError' undeclared
15439:psycopg/psycopgmodule.c:425: error: 'DataError' undeclared here
(not in a function)
15446:psycopg/psycopgmodule.c:426: error: 'NotSupportedError' undeclared
15453:psycopg/psycopgmodule.c:429: error: 'QueryCanceledError'
undeclared here (not in a function)
15460:psycopg/psycopgmodule.c:432: error: 'TransactionRollbackError'
15468:psycopg/psycopgmodule.c:446: error: 'PyObject' undeclared (first
use in this function)
15469:psycopg/psycopgmodule.c:446: error: (Each undeclared identifier is
reported only once
15470:psycopg/psycopgmodule.c:446: error: for each function it appears
in.)
15471:psycopg/psycopgmodule.c:446: error: 'dict' undeclared (first use
in this function)
15472:psycopg/psycopgmodule.c:447: error: 'base' undeclared (first use
in this function)
15473:psycopg/psycopgmodule.c:448: error: 'str' undeclared (first use in
this function)
15475:psycopg/psycopgmodule.c:453: error: 'struct <anonymous>' has no
member named 'docstr'
15477:psycopg/psycopgmodule.c:454: error: 'struct <anonymous>' has no
15479:psycopg/psycopgmodule.c:458: error: 'struct <anonymous>' has no
member named 'base'
15480:psycopg/psycopgmodule.c:459: error: 'PyExc_StandardError'
undeclared (first use in this function)
15481:psycopg/psycopgmodule.c:461: error: 'struct <anonymous>' has no
member named 'base'
15482:psycopg/psycopgmodule.c:463: error: 'struct <anonymous>' has no
member named 'exc'
15485:psycopg/psycopgmodule.c:469: error: 'Py_None' undeclared (first
15487:psycopg/psycopgmodule.c:475: error: expected ')' before '*' token
15488:psycopg/psycopgmodule.c:495: error: expected ')' before '*' token
15489:psycopg/psycopgmodule.c:519: error: expected ')' before '*' token
15491:psycopg/psycopgmodule.c:552: error: expected '=', ',', ';', 'asm'
15492:psycopg/psycopgmodule.c:552: error: 'main_interp' undeclared
15493:psycopg/psycopgmodule.c:553: error: 'PyInterpreterState'
15494:psycopg/psycopgmodule.c:553: error: 'interp' undeclared (first use
in this function)
15496:psycopg/psycopgmodule.c:556: error: invalid type argument of
'->' (have 'int')
15500:psycopg/psycopgmodule.c:580: error: expected '=', ',', ';', 'asm'
15501:psycopg/psycopgmodule.c:618: error: expected '=', ',', ';', 'asm'
or '__attribute__' before 'psycopgMethods'
15503:psycopg/psycopgmodule.c:682: error: 'PyObject' undeclared (first
15504:psycopg/psycopgmodule.c:682: error: 'module' undeclared (first use
in this function)
15505:psycopg/psycopgmodule.c:682: error: 'dict' undeclared (first use
in this function)
15507:psycopg/psycopgmodule.c:683: error: 'c_api_object' undeclared
15508:psycopg/psycopgmodule.c:693: error: 'connectionType' undeclared
15509:psycopg/psycopgmodule.c:693: error: 'PyType_Type' undeclared
15510:psycopg/psycopgmodule.c:694: error: 'cursorType' undeclared (first
15511:psycopg/psycopgmodule.c:695: error: 'typecastType' undeclared
15512:psycopg/psycopgmodule.c:696: error: 'qstringType' undeclared
15513:psycopg/psycopgmodule.c:697: error: 'binaryType' undeclared (first
15514:psycopg/psycopgmodule.c:698: error: 'isqlquoteType' undeclared
15515:psycopg/psycopgmodule.c:699: error: 'pbooleanType' undeclared
15516:psycopg/psycopgmodule.c:700: error: 'pfloatType' undeclared (first
15517:psycopg/psycopgmodule.c:701: error: 'asisType' undeclared (first
15518:psycopg/psycopgmodule.c:702: error: 'listType' undeclared (first
15519:psycopg/psycopgmodule.c:703: error: 'chunkType' undeclared (first
15521:psycopg/psycopgmodule.c:718: error: 'lobjectType' undeclared
15522:psycopg/psycopgmodule.c:735: error: 'pyDateTimeModuleP' undeclared
15525:psycopg/psycopgmodule.c:738: error: 'PyExc_ImportError' undeclared
15526:psycopg/psycopgmodule.c:741: error: 'pydatetimeType' undeclared
15527:psycopg/psycopgmodule.c:746: error: 'pyDateTypeP' undeclared
15529:psycopg/psycopgmodule.c:747: error: 'pyTimeTypeP' undeclared
15530:psycopg/psycopgmodule.c:748: error: 'pyDateTimeTypeP' undeclared
15531:psycopg/psycopgmodule.c:749: error: 'pyDeltaTypeP' undeclared
15532:psycopg/psycopgmodule.c:752: error: 'pyPsycopgTzModule' undeclared
15533:psycopg/psycopgmodule.c:758: error: 'pyPsycopgTzLOCAL' undeclared
15534:psycopg/psycopgmodule.c:760: error:
'pyPsycopgTzFixedOffsetTimezone' undeclared (first use in this function)
15536:psycopg/psycopgmodule.c:764: error: 'psycopgMethods' undeclared
15540:psycopg/psycopgmodule.c:776: error: 'psycoEncodings' undeclared
15544:psycopg/psycopgmodule.c:787: error: expected expression before ')'
token
15545:psycopg/psycopgmodule.c:788: error: expected expression before ')'
token
15546:psycopg/psycopgmodule.c:789: error: expected expression before ')'
token
15547:psycopg/psycopgmodule.c:791: error: expected expression before ')'
token
15552:psycopg/psycopgmodule.c:809: error: 'PyType_GenericAlloc'
15553:error: Setup script exited with error: command 'gcc' failed with
exit status 1
15637:psycopg/psycopgmodule.c:23:20: error: Python.h: No such file or
directory
15639:./psycopg/python.h:27:26: error: structmember.h: No such file or
directory
15640:./psycopg/python.h:30:4: error: #error "psycopg requires Python >=
2.4"
15642:./psycopg/psycopg.h:55: error: expected ')' before '*' token
15643:./psycopg/psycopg.h:56: error: expected ')' before '*' token
15644:./psycopg/psycopg.h:59: error: expected '=', ',', ';', 'asm' or
15645:./psycopg/psycopg.h:63: error: expected '=', ',', ';', 'asm' or
15646:./psycopg/psycopg.h:102: error: expected '=', ',', ';', 'asm' or
15647:./psycopg/psycopg.h:110: error: expected '=', ',', ';', 'asm' or
15648:./psycopg/psycopg.h:113: error: expected ')' before '*' token
15649:./psycopg/psycopg.h:116: error: expected ')' before '*' token
15651:./psycopg/connection.h:44: error: expected '=', ',', ';', 'asm' or
15652:./psycopg/connection.h:52: error: expected
15654:./psycopg/cursor.h:36: error: expected '=', ',', ';', 'asm' or
15655:./psycopg/cursor.h:39: error: expected specifier-qualifier-list
15657:./psycopg/lobject.h:36: error: expected '=', ',', ';', 'asm' or
15658:./psycopg/lobject.h:39: error: expected specifier-qualifier-list
before 'PyObject'
15660:./psycopg/typecast.h:35: error: expected '=', ',', ';', 'asm' or
15661:./psycopg/typecast.h:40: error: expected '=', ',', ';', 'asm' or
15662:./psycopg/typecast.h:43: error: expected specifier-qualifier-list
15663:./psycopg/typecast.h:58: error: expected specifier-qualifier-list
15664:./psycopg/typecast.h:65: error: expected '=', ',', ';', 'asm' or
15665:./psycopg/typecast.h:66: error: expected '=', ',', ';', 'asm' or
15666:./psycopg/typecast.h:69: error: expected '=', ',', ';', 'asm' or
15667:./psycopg/typecast.h:70: error: expected '=', ',', ';', 'asm' or
15668:./psycopg/typecast.h:75: error: expected ')' before '*' token
15669:./psycopg/typecast.h:76: error: expected ')' before '*' token
15670:./psycopg/typecast.h:79: error: expected '=', ',', ';', 'asm' or
15671:./psycopg/typecast.h:82: error: expected '=', ',', ';', 'asm' or
15672:./psycopg/typecast.h:86: error: expected '=', ',', ';', 'asm' or
15674:./psycopg/microprotocols.h:37: error: expected '=', ',', ';',
15675:./psycopg/microprotocols.h:48: error: expected ')' before '*'
token
15676:./psycopg/microprotocols.h:50: error: expected ')' before '*'
token
15677:./psycopg/microprotocols.h:52: error: expected '=', ',', ';',
15678:./psycopg/microprotocols.h:54: error: expected '=', ',', ';',
15679:./psycopg/microprotocols.h:57: error: expected '=', ',', ';',
15681:./psycopg/microprotocols_proto.h:35: error: expected '=', ',',
15682:./psycopg/microprotocols_proto.h:38: error: expected
15684:./psycopg/adapter_qstring.h:34: error: expected '=', ',', ';',
15685:./psycopg/adapter_qstring.h:37: error: expected
15686:./psycopg/adapter_qstring.h:48: error: expected '=', ',', ';',
15688:./psycopg/adapter_binary.h:35: error: expected '=', ',', ';',
15689:./psycopg/adapter_binary.h:38: error: expected
15690:./psycopg/adapter_binary.h:47: error: expected '=', ',', ';',
15692:./psycopg/adapter_pboolean.h:34: error: expected '=', ',', ';',
15693:./psycopg/adapter_pboolean.h:37: error: expected
15694:./psycopg/adapter_pboolean.h:46: error: expected '=', ',', ';',
15696:./psycopg/adapter_pfloat.h:34: error: expected '=', ',', ';',
15697:./psycopg/adapter_pfloat.h:37: error: expected
15698:./psycopg/adapter_pfloat.h:46: error: expected '=', ',', ';',
15700:./psycopg/adapter_asis.h:34: error: expected '=', ',', ';', 'asm'
15701:./psycopg/adapter_asis.h:37: error: expected
15702:./psycopg/adapter_asis.h:46: error: expected '=', ',', ';', 'asm'
15704:./psycopg/adapter_list.h:34: error: expected '=', ',', ';', 'asm'
15705:./psycopg/adapter_list.h:37: error: expected
15706:./psycopg/adapter_list.h:44: error: expected '=', ',', ';', 'asm'
15708:./psycopg/typecast_binary.h:36: error: expected '=', ',', ';',
15709:./psycopg/typecast_binary.h:39: error: expected
15710:psycopg/psycopgmodule.c:51:22: error: datetime.h: No such file or
directory
15712:./psycopg/adapter_datetime.h:34: error: expected '=', ',', ';',
15713:./psycopg/adapter_datetime.h:37: error: expected
15714:./psycopg/adapter_datetime.h:52: error: expected '=', ',', ';',
15715:./psycopg/adapter_datetime.h:57: error: expected '=', ',', ';',
15716:./psycopg/adapter_datetime.h:62: error: expected '=', ',', ';',
15717:./psycopg/adapter_datetime.h:67: error: expected '=', ',', ';',
15718:./psycopg/adapter_datetime.h:74: error: expected '=', ',', ';',
15719:./psycopg/adapter_datetime.h:81: error: expected '=', ',', ';',
15720:./psycopg/adapter_datetime.h:90: error: expected '=', ',', ';',
15721:./psycopg/adapter_datetime.h:94: error: expected '=', ',', ';',
15722:./psycopg/adapter_datetime.h:98: error: expected '=', ',', ';',
15723:./psycopg/adapter_datetime.h:102: error: expected '=', ',', ';',
15724:psycopg/psycopgmodule.c:53: error: expected '=', ',', ';', 'asm'
15725:psycopg/psycopgmodule.c:54: error: expected '=', ',', ';', 'asm'
15726:psycopg/psycopgmodule.c:55: error: expected '=', ',', ';', 'asm'
15727:psycopg/psycopgmodule.c:56: error: expected '=', ',', ';', 'asm'
15728:psycopg/psycopgmodule.c:57: error: expected '=', ',', ';', 'asm'
15729:psycopg/psycopgmodule.c:60: error: expected '=', ',', ';', 'asm'
15730:psycopg/psycopgmodule.c:61: error: expected '=', ',', ';', 'asm'
15731:psycopg/psycopgmodule.c:62: error: expected '=', ',', ';', 'asm'
15732:psycopg/psycopgmodule.c:64: error: expected '=', ',', ';', 'asm'
15739:psycopg/psycopgmodule.c:103: error: expected '=', ',', ';', 'asm'
15740:psycopg/psycopgmodule.c:231: error: expected ')' before '*' token
15741:psycopg/psycopgmodule.c:238: error: expected '=', ',', ';', 'asm'
15742:psycopg/psycopgmodule.c:272: error: expected ')' before '*' token
15743:psycopg/psycopgmodule.c:384: error: expected ')' before '*' token
15744:psycopg/psycopgmodule.c:400: error: expected '=', ',', ';', 'asm'
15745:psycopg/psycopgmodule.c:404: error: expected '=', ',', ';', 'asm'
15746:psycopg/psycopgmodule.c:410: error: expected
15747:psycopg/psycopgmodule.c:414: error: 'Error' undeclared here (not
in a function)
15754:psycopg/psycopgmodule.c:415: error: 'Warning' undeclared here (not
in a function)
15761:psycopg/psycopgmodule.c:416: error: 'InterfaceError' undeclared
15768:psycopg/psycopgmodule.c:417: error: 'DatabaseError' undeclared
15775:psycopg/psycopgmodule.c:418: error: 'InternalError' undeclared
15782:psycopg/psycopgmodule.c:419: error: 'OperationalError' undeclared
15789:psycopg/psycopgmodule.c:421: error: 'ProgrammingError' undeclared
15796:psycopg/psycopgmodule.c:423: error: 'IntegrityError' undeclared
15803:psycopg/psycopgmodule.c:425: error: 'DataError' undeclared here
(not in a function)
15810:psycopg/psycopgmodule.c:426: error: 'NotSupportedError' undeclared
15817:psycopg/psycopgmodule.c:429: error: 'QueryCanceledError'
15824:psycopg/psycopgmodule.c:432: error: 'TransactionRollbackError'
15832:psycopg/psycopgmodule.c:446: error: 'PyObject' undeclared (first
15833:psycopg/psycopgmodule.c:446: error: (Each undeclared identifier is
reported only once
15834:psycopg/psycopgmodule.c:446: error: for each function it appears
in.)
15835:psycopg/psycopgmodule.c:446: error: 'dict' undeclared (first use
in this function)
15836:psycopg/psycopgmodule.c:447: error: 'base' undeclared (first use
in this function)
15837:psycopg/psycopgmodule.c:448: error: 'str' undeclared (first use in
this function)
15839:psycopg/psycopgmodule.c:453: error: 'struct <anonymous>' has no
15841:psycopg/psycopgmodule.c:454: error: 'struct <anonymous>' has no
15843:psycopg/psycopgmodule.c:458: error: 'struct <anonymous>' has no
member named 'base'
15844:psycopg/psycopgmodule.c:459: error: 'PyExc_StandardError'
15845:psycopg/psycopgmodule.c:461: error: 'struct <anonymous>' has no
member named 'base'
15846:psycopg/psycopgmodule.c:463: error: 'struct <anonymous>' has no
member named 'exc'
15849:psycopg/psycopgmodule.c:469: error: 'Py_None' undeclared (first
15851:psycopg/psycopgmodule.c:475: error: expected ')' before '*' token
15852:psycopg/psycopgmodule.c:495: error: expected ')' before '*' token
15853:psycopg/psycopgmodule.c:519: error: expected ')' before '*' token
15855:psycopg/psycopgmodule.c:552: error: expected '=', ',', ';', 'asm'
15856:psycopg/psycopgmodule.c:552: error: 'main_interp' undeclared
15857:psycopg/psycopgmodule.c:553: error: 'PyInterpreterState'
15858:psycopg/psycopgmodule.c:553: error: 'interp' undeclared (first use
in this function)
15860:psycopg/psycopgmodule.c:556: error: invalid type argument of
'->' (have 'int')
15864:psycopg/psycopgmodule.c:580: error: expected '=', ',', ';', 'asm'
15865:psycopg/psycopgmodule.c:618: error: expected '=', ',', ';', 'asm'
15867:psycopg/psycopgmodule.c:682: error: 'PyObject' undeclared (first
15868:psycopg/psycopgmodule.c:682: error: 'module' undeclared (first use
in this function)
15869:psycopg/psycopgmodule.c:682: error: 'dict' undeclared (first use
in this function)
15871:psycopg/psycopgmodule.c:683: error: 'c_api_object' undeclared
15872:psycopg/psycopgmodule.c:693: error: 'connectionType' undeclared
15873:psycopg/psycopgmodule.c:693: error: 'PyType_Type' undeclared
15874:psycopg/psycopgmodule.c:694: error: 'cursorType' undeclared (first
15875:psycopg/psycopgmodule.c:695: error: 'typecastType' undeclared
15876:psycopg/psycopgmodule.c:696: error: 'qstringType' undeclared
15877:psycopg/psycopgmodule.c:697: error: 'binaryType' undeclared (first
15878:psycopg/psycopgmodule.c:698: error: 'isqlquoteType' undeclared
15879:psycopg/psycopgmodule.c:699: error: 'pbooleanType' undeclared
15880:psycopg/psycopgmodule.c:700: error: 'pfloatType' undeclared (first
15881:psycopg/psycopgmodule.c:701: error: 'asisType' undeclared (first
15882:psycopg/psycopgmodule.c:702: error: 'listType' undeclared (first
15883:psycopg/psycopgmodule.c:703: error: 'chunkType' undeclared (first
15885:psycopg/psycopgmodule.c:718: error: 'lobjectType' undeclared
15886:psycopg/psycopgmodule.c:735: error: 'pyDateTimeModuleP' undeclared
15889:psycopg/psycopgmodule.c:738: error: 'PyExc_ImportError' undeclared
15890:psycopg/psycopgmodule.c:741: error: 'pydatetimeType' undeclared
15891:psycopg/psycopgmodule.c:746: error: 'pyDateTypeP' undeclared
15893:psycopg/psycopgmodule.c:747: error: 'pyTimeTypeP' undeclared
15894:psycopg/psycopgmodule.c:748: error: 'pyDateTimeTypeP' undeclared
15895:psycopg/psycopgmodule.c:749: error: 'pyDeltaTypeP' undeclared
15896:psycopg/psycopgmodule.c:752: error: 'pyPsycopgTzModule' undeclared
15897:psycopg/psycopgmodule.c:758: error: 'pyPsycopgTzLOCAL' undeclared
15898:psycopg/psycopgmodule.c:760: error:
15900:psycopg/psycopgmodule.c:764: error: 'psycopgMethods' undeclared
15904:psycopg/psycopgmodule.c:776: error: 'psycoEncodings' undeclared
15908:psycopg/psycopgmodule.c:787: error: expected expression before ')'
token
15909:psycopg/psycopgmodule.c:788: error: expected expression before ')'
token
15910:psycopg/psycopgmodule.c:789: error: expected expression before ')'
token
15911:psycopg/psycopgmodule.c:791: error: expected expression before ')'
token
15916:psycopg/psycopgmodule.c:809: error: 'PyType_GenericAlloc'
15917:error: Setup script exited with error: command 'gcc' failed with
exit status 1
16267:Download error: [Errno -2] Name or service not known -- Some
packages may not be found!
16269:Download error: [Errno -2] Name or service not known -- Some
22877:  libglib2.0-dev libgpg-error-dev libjasper-dev
22917:** (process:31570): CRITICAL **: Failed to init libxfconf:
dbus-launch failed to autolaunch D-Bus session: Autolaunch error: X11
22921:** (process:31572): CRITICAL **: Failed to init libxfconf:
22958:2009-10-07 07:06:29 ERROR 404: Not Found.
22988:  libgpg-error-dev libjasper-dev x11proto-xinerama-dev libgeos-dev
More information about the Live-demo mailing list
