[Live-demo] Installation issues of GISVM on xubuntu 8.04
Aneel aneel.r at tecnics.com
Wed Oct 7 09:36:23 EDT 2009
Hello Cameron,
We have also working on xubuntu 9.04 with GISVM parallel.
Regards
Aneel
On Wed, 2009-10-07 at 06:34 +1100, Cameron Shorter wrote:
> Aneel,
> What is the reason for using Xubuntu 8.04 instead of Xubuntu 9.04 or
> Ubuntu 9.04?
> While there is a good chance you will get it working on 8.04, you will
> likely run into a few errors as we have not tested with this release.
> Also, is it possible to upgrade to a later version of Xubuntu before you
> start the build process.
> Alex Mandel wrote:
> > Aneel wrote:
> >> Hello OSgeo Team,
> >> Let me introduce myself. I am Aneel from click2try team.
> >> I have tried to install GISVM on xubuntu 8.04 (32-bit) on Xen
> >> hypervisor. While installation of GISVM, i found below errors.  Please
> >> guide me to resolve these issues.
> > Are you using the trunk, or the 2.0.3 tag from svn?
> >> Error1:
> >> deegree_start.sh: FAILED
> >> md5sum: WARNING: 1 of 1 computed checksum did NOT match
> >> ERROR [install_deegree.sh]: download of deegree_start.sh failed.
> >> Finished: ./install_deegree.sh
> > Interesting, that just means that for some reason the hash check to
> > confirm the download failed.
> > Try:
> > cd /tmp/build_deegree
> > wget -c
> > http://download.deegree.org/LiveDVD/FOSS4G2009/deegree-2.2_tomcat-6.0.20.tar.gz
> > and then rerun the deegree script in the bin folder
> > sudo ./install_deegree.sh
> >> Error2:
> >> createdb: database creation failed: ERROR:  template database "-E" does
> >> not exist
> >> createlang: could not connect to database template_postgis: FATAL:
> >> database "template_postgis" does not exist
> >> UPDATE 0
> >> psql: FATAL:  database "template_postgis" does not exist
> > Ah there's an error on ln 92 of install_postgis.sh, it should read:
> > sudo -u $USER_NAME createdb -E UTF8 template_postgis
> > no -T, that was a mistake
> >> Error3: for install_desktop.sh
> >> CRITICAL **: Failed to init libxfconf: dbus-launch failed to autolaunch
> >> D-Bus session: Autolaunch error: X11 initialization failed.
> > To be expected, setting the background and screen stretch are coded for
> > XFCE in this particular case. Take a look in the install_desktop. These
> > steps can be done by hand and commented out.
> > ln 34-40
> >> Regards
> >> Aneel Kumar
> >> click2try
> > Thanks,
> > Alex
> > Live-demo mailing list
> > Live-demo at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/live-demo
More information about the Live-demo mailing list
