[Live-demo] Installation issues of GISVM on xubuntu 8.04
Alex Mandel tech_dev at wildintellect.com
Tue Oct 6 18:41:53 EDT 2009
My guess is that they've already smoothed out bugs with running 8.04 on
Xen with their system. So they may not have time to test,debug and
install 9.04 under the timeline we're pushing for.
If the 3 errors posted earlier are most of it, that's not too bad.
I would say continue ahead with 8.04 if things seem to be working and
we'll aim for an upgrade down the line.
Alex
Cameron Shorter wrote:
> Aneel,
> What is the reason for using Xubuntu 8.04 instead of Xubuntu 9.04 or
> Ubuntu 9.04?
> While there is a good chance you will get it working on 8.04, you will
> likely run into a few errors as we have not tested with this release.
> Also, is it possible to upgrade to a later version of Xubuntu before you
> start the build process.
> Alex Mandel wrote:
>> Aneel wrote:
>>> Hello OSgeo Team,
>>> Let me introduce myself. I am Aneel from click2try team.
>>> I have tried to install GISVM on xubuntu 8.04 (32-bit) on Xen
>>> hypervisor. While installation of GISVM, i found below errors.  Please
>>> guide me to resolve these issues.
>> Are you using the trunk, or the 2.0.3 tag from svn?
>>> Error1:
>>> deegree_start.sh: FAILED
>>> md5sum: WARNING: 1 of 1 computed checksum did NOT match
>>> ERROR [install_deegree.sh]: download of deegree_start.sh failed.
>>> Finished: ./install_deegree.sh
>> Interesting, that just means that for some reason the hash check to
>> confirm the download failed.
>> Try:
>> cd /tmp/build_deegree
>> wget -c
>> http://download.deegree.org/LiveDVD/FOSS4G2009/deegree-2.2_tomcat-6.0.20.tar.gz
>> and then rerun the deegree script in the bin folder
>> sudo ./install_deegree.sh
>>> Error2:
>>> createdb: database creation failed: ERROR:  template database "-E" does
>>> not exist
>>> createlang: could not connect to database template_postgis: FATAL:
>>> database "template_postgis" does not exist
>>> UPDATE 0
>>> psql: FATAL:  database "template_postgis" does not exist
>> Ah there's an error on ln 92 of install_postgis.sh, it should read:
>> sudo -u $USER_NAME createdb -E UTF8 template_postgis
>> no -T, that was a mistake
>>> Error3: for install_desktop.sh
>>> CRITICAL **: Failed to init libxfconf: dbus-launch failed to autolaunch
>>> D-Bus session: Autolaunch error: X11 initialization failed.
>> To be expected, setting the background and screen stretch are coded for
>> XFCE in this particular case. Take a look in the install_desktop. These
>> steps can be done by hand and commented out.
>> ln 34-40
>>> Regards
>>> Aneel Kumar
>>> click2try
>> Thanks,
>> Alex
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
More information about the Live-demo mailing list
