[Live-demo] Installation issues of GISVM on xubuntu 8.04
Cameron Shorter cameron.shorter at lisasoft.com
Tue Oct 6 15:34:26 EDT 2009
Aneel,
What is the reason for using Xubuntu 8.04 instead of Xubuntu 9.04 or
Ubuntu 9.04?
While there is a good chance you will get it working on 8.04, you will
likely run into a few errors as we have not tested with this release.
Also, is it possible to upgrade to a later version of Xubuntu before you
start the build process.
Alex Mandel wrote:
> Aneel wrote:
>> Hello OSgeo Team,
>> Let me introduce myself. I am Aneel from click2try team.
>> I have tried to install GISVM on xubuntu 8.04 (32-bit) on Xen
>> hypervisor. While installation of GISVM, i found below errors.  Please
>> guide me to resolve these issues.
> Are you using the trunk, or the 2.0.3 tag from svn?
>> Error1:
>> deegree_start.sh: FAILED
>> md5sum: WARNING: 1 of 1 computed checksum did NOT match
>> ERROR [install_deegree.sh]: download of deegree_start.sh failed.
>> Finished: ./install_deegree.sh
> Interesting, that just means that for some reason the hash check to
> confirm the download failed.
> Try:
> cd /tmp/build_deegree
> wget -c
> http://download.deegree.org/LiveDVD/FOSS4G2009/deegree-2.2_tomcat-6.0.20.tar.gz
> and then rerun the deegree script in the bin folder
> sudo ./install_deegree.sh
>> Error2:
>> createdb: database creation failed: ERROR:  template database "-E" does
>> not exist
>> createlang: could not connect to database template_postgis: FATAL:
>> database "template_postgis" does not exist
>> UPDATE 0
>> psql: FATAL:  database "template_postgis" does not exist
> Ah there's an error on ln 92 of install_postgis.sh, it should read:
> sudo -u $USER_NAME createdb -E UTF8 template_postgis
> no -T, that was a mistake
>> Error3: for install_desktop.sh
>> CRITICAL **: Failed to init libxfconf: dbus-launch failed to autolaunch
>> D-Bus session: Autolaunch error: X11 initialization failed.
> To be expected, setting the background and screen stretch are coded for
> XFCE in this particular case. Take a look in the install_desktop. These
> steps can be done by hand and commented out.
> ln 34-40
>> Regards
>> Aneel Kumar
>> click2try
> Thanks,
> Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
