[Live-demo] Installation issues of GISVM on xubuntu 8.04
Tom Callaghan tom.callaghan at click2try.com
Wed Oct 7 16:13:09 EDT 2009
Hello Cameron,
Aneel and Arun are both in Hyderabad India.
We are very close to having a development version for you to look at.  The
current development version is working on a single layered appliance.  This
means that every time we provision a new instance of the appliance for a
user it takes about 5 minutes to make a copy of the appliance for the user
to use.  When the user leaves and comes back into click2try, it does not
take that time to provision it again.  Aneel is currently working on
implementing it as a multi-layered appliance which simply means that each
time we provision a new appliance for a user, only a small copy-on-write
(COW) file is created.  This is what takes our provisioning down to 45
seconds.  I will set up the current development version for you to look at
inside our click2try environment.  I should have it finished by the morning.
Tom
-----Original Message-----
[mailto:live-demo-bounces at lists.osgeo.org] On Behalf Of Cameron Shorter
Sent: Wednesday, October 07, 2009 2:22 PM
To: tech at wildintellect.com
Cc: Tom Callaghan; Arun Sharma Tecnics; Live-demo at lists.osgeo.org
Subject: Re: [Live-demo] Installation issues of GISVM on xubuntu 8.04
Hi Aneel,
What country/timezone are you in? I haven't worked out a time when I'm
online at the same time as you.
Do you have a development version of click2try with Arramagong installed
that you are prepared to publish and let us try out? In particular, it
would allow us to point the script authors at this server, and rerun
their install script to see if they can fix their problems.
Alex Mandel wrote:
> 13532:dpkg: error processing
> /tmp/maptiler_downloads/maptiler_1.0.beta1_all.deb (--install):
> 13533: subprocess dpkg-deb --control returned error exit status 2
> 13537:ERROR: Installation of the MapTiler failed.
> Anyone know what the issue with th maptiler deb might be.
> Looking at the deegree error, it's minor, the md5 for the start script
> when an edit was made. It probably still works fine.
> Download error: [Errno -2] Name or service not known -- Some packages
> may not be found!
> As with most things in the Error section, a false error, the rpy
> installer appears to have worked.
> Those are the only things that stood out to me.
> At this point getting it online and letting us kick the tires seems to
> be in order, I don't see any show stoppers. Assuming you've tried to
> launch a few apps and they work.
> Thanks,
> Alex
> Live-demo mailing list
> http://lists.osgeo.org/mailman/listinfo/live-demo
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
