[Live-demo] Does your application work on the click2try GISVM?
Cameron Shorter cameron.shorter at lisasoft.com
Sun Oct 11 15:23:35 EDT 2009
Alex, Simon,
Have you:
1. Fixed the problem on the VM supplied? If not please do so.
2. Fixed the geonetwork install script? If not, please either raise a
svn issue, (ideally with a work around) or update the script.
Alex Mandel wrote:
> Ah, the desktop icon using launchassist.sh is rigged specifically to the
> password user on the sudo command. That's probably why it didn't work.
> QGIS worked for me, didn't get a chance to test anything else yet for
> some reason my linux boxes aren't playing nice with the jvm versions I
> have and the site, so I tested briefly on a windows box which worked.
> Alex
> Simon.Pigot at csiro.au wrote:
>> Tried GeoNetwork - it doesn't work as far as I can tell because the permissions (for some reason) on /usr/lib/geonetwork are not owner user/group user!
>> ________________________________________
>> From: live-demo-bounces at lists.osgeo.org [live-demo-bounces at lists.osgeo.org] On Behalf Of Cameron Shorter [cameron.shorter at lisasoft.com]
>> Sent: Sunday, 11 October 2009 10:22 PM
>> To: SAIG Carlos
>> Cc: amr at saig.es; live-demo at lists.osgeo.org; 'Sergio Baños Calvo'
>> Subject: Re: [Live-demo] Does your application work on the click2try GISVM?
>> Thanks SAIG,
>> For the record, which application(s) did you test?
>> SAIG Carlos wrote:
>>> Hello Cameron.
>>> I logged in and it looks there are no problems.
>>> I would like to thank  all of you again because you are making a big effort
>>> to make all the things work out correctly. Thank you.
>>> Carlos Navarro
>>> cnavarro at saig.es
>>> Director Técnico de SAIG  // SAIG Technical Director
>>> www.saig.es -- Tlf: +34 954788876 -- info at saig.es
>>> -----Mensaje original-----
>>> De: Cameron Shorter [mailto:cameron.shorter at gmail.com]
>>> Enviado el: sábado, 10 de octubre de 2009 12:03
>>> Para: Tom Callaghan
>>> CC: Cameron Shorter; aneel.r at tecnics.com; 'Arun Sharma Tecnics'; Judit Mays;
>>> Etienne Dube; Simon Pigot; Andrea Aime; Hamish; Jorge Gaspar Sanz Salinas;
>>> Cédric Moullet; SAIG Carlos; Dane Springmeyer; klokan at gmail.com; Landon
>>> Blake; Anton Patrushev; Alex Mandel; Jody Garnett
>>> Asunto: Re: [Live-demo] Does your application work on the click2try GISVM?
>>> Live DVD packagers:
>>> The click2try team (who allow you to view a linux distribution in a web
>>> browser) have been busy packaging our GISVM and have it mostly working.
>>> We aim to have it released ASAP and definitely by Friday 16 October so we
>>> can put out a major press release to all international OSGeo users we know
>>> of.
>>> Could everyone please try logging on using the instructions below and see if
>>> you can get your application working as per Tom's instructions below.
>>> Note: do not stop the machine.
>>> Please report back whether you were successful or not. Any issues should be
>>> added to the issue tracker at:
>>> http://trac.osgeo.org/osgeo/query?group=status&component=LiveDVD&order=prior
>>> ity
>>> Issues I'm aware of are:
>>> * There are no icons for deegree
>>> * There is no mapserver icon
>>> * The "Start Mapnik & TileLite" icon is missing
>>> * There is no "MapTiler" icon
>>> I'm copying the install logs to:
>>> http://download.osgeo.org/livedvd/2.0.3-click2try/ (this is taking a
>>> while, but should be finished by the time you look at this)
>>> Alternatively, you can find them in the usual place on the click2try
>>> image at:
>>> /var/log/arramagong/
>>> Tom Callaghan wrote:
>>>> Hello Cameron,
>>>> I have setup an instance of the OSGeo VM on one of our development
>>> jukeboxes
>>>> at the URL http://scooter.dev.presage-tech.com.
>>>> Log in using
>>>> user id: osgeo
>>>> password: livedemo
>>>> Once logged in, navigate to My Dashboard/Applications Manager.  You will
>>> see
>>>> a VM named osgeo-gisvmsl-2.  Hilite that and click the red LAUNCH button.
>>>> This will connect you to the VM.  Please do not shut down this VM.  It is
>>>> currently running as a single layered appliance on a slower development
>>>> machine as I described in my previous email.  It will take a lot of time
>>> to
>>>> stop and restart it.
>>>> We put a simple quickstart guide that displays on our viewer window.  It
>>> has
>>>> login information for the VNC session and root access info.
>> Cameron Shorter
>> Geospatial Solutions Manager
>> Tel: +61 (0)2 8570 5050
>> Mob: +61 (0)419 142 254
>> Think Globally, Fix Locally
>> Geospatial Solutions enhanced with Open Standards and Open Source
>> http://www.lisasoft.com
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
Cameron Shorter
More information about the Live-demo mailing list
